Page 10 of 78 FirstFirst 12345678910111213141516171819203560 ... LastLast
Results 226 to 250 of 1931
Thread: m52 Turbo Build
  1. #226
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have never logged anything in 7 years. Buy a good tune, put the right parts on a properly prepared motor and don't worry. But if you want to buy stuff and log the zeitronix is good and if you want to log and tune the megasquirt is good. I have some software -- bmwlogger but have never used it. I don't really have the time or the need.
    As for WB02, I liked the AEM that I ran. I have used a couple of Innovate and they seem to work fine for a while and then eat sensors. The same sensor is used on factory cars and guaranteed for 7 years so it should not fail in a year.
    For boost controllers I like the eboost2 but it is expensive now. I bought mine new for $300 in 2010. Not sure what I would use instead. A manual boost controller is inexpensive and effective.
  2. #227
    Virginia
    97' m52 turbo
    My $0.02 is to bit the bullet and buy a Zetronix kit.
    I have had AEM, plx, and innovate.
    Buying the zetronix kit starts a data logging system. Being able to log really helps not only seeing where your at, but help diag problems.
    Rpm, TPS, AFR, boost, fuel pressure, and also a user (I log methanol injection). Start out with a basic kit. Then add over time.
    Tapping into the factory harness is simple as hell.
    So many different opinions on this
    How's installation? pretty straight forward?
    Which one do you recommend?
  3. #228
    Virginia
    97' m52 turbo
  4. #229
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by 328iFun View Post
    Correct.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #230
    Virginia
    97' m52 turbo
    Correct.
    Thanks.
    Now im on the look out for a tablet mount for e36. And a tablet that has a serial port, who uses DB9 anymore anyway?
  6. #231
    Virginia
    97' m52 turbo
    Good Morning Everyone,
    Newest item on agenda: welding bungs/flanges for Lambda, BOV, MAF, etc...
    I'm toying around with the idea of just buying a welder doing it myself. Would have to be able to do aluminum though... Fairly new to welding, did a little in high school. But I'm thinking it would be more cost effective too purchase my own welder - This way I can make any changes as needed and fabricate as I please.
    A guy I work with does some welding and he was thinking that this unit would be sufficient:
    https://www.amazon.com/Lotos-MIG140-...elder+aluminum
    Any recommendations? I don't want to spend fortune but if its cheaper for me do myself then paying some else than I'm all for it. Always a plus to learn something new as well.
    What price range am I looking at to have someone do all of this work for me vs purchasing a welding machine?
    Thanks for all the help on this project, getting fairly close to throwing a bucket in the car and driving it
  7. #232
    Apr 2006
    Minnesota eh?
    86 325es
    That looks to be made by the same place as the eastwood welders. I have an eastwood 140 mig and its workable but its a piece of junk. I have had to take it apart and bodge it back together several times. The wording on that advertisement is kind of deceptive, you will need to buy the additional spool gun to be able to weld aluminum. Mig welding aluminum is not very desirable It is very difficult and doesn't really work on thin tubing. I would just find a used mig or tig welder like a miller. Mig welding steel is as easy as it gets. You can always make your charge piping out of steel and paint it or get it powder coated.
  8. #233
    Virginia
    97' m52 turbo
    Thanks for the advice.
    Aluminum is so much easier to work with before welding. Might just take the elbow to shop have them weld the 2 flanges. Shouldn't be too expensive.
    Onto exhaust, may have made a mistake with the 3 5/8 exhaust housing. Pretty sure that size piping isn't going to fit. Probably have to reduce it 3" or 2.5.
    Not to mention, which I think should have been one of the MOST easy parts of the project...
    Air Filter.
    I've tried fitting 2 through the limited space that I have to no avail. I was able to bend the K&N it fit width wise but was too long in height. I then tried a cone filter half the size of the K&N but it had steel caging around the filter so I couldn't get it too fit. So it looks like in order to change a filter I'm going to have to remove oil lines, remove exhaust, remove turbo.
    Unless:
    I use something like this, which Im about 90% will fit
    https://www.spectreperformance.com/c...rs-inline-cone
    Yeah, its sceptre (I know) unless anyone knows of any better similar types.
  9. #234
    Dec 2013
    Redmond, OR
    96 328IS, 08 IB E92 M3
    Not sure if it will help, as I don't know what sort of dimensions you are dealing with. I run this on my top mount setup. Its pretty stubby. Just trying to throw an option out there!
    https://www.summitracing.com/parts/vpe-10930
    Anthony Bartolini
    Loki Motorsports
    -2008 A30 E92 M3 6MT-
    -1996 328is Drift Car-
    Stock Internal M52
    M50 Manifold
    PTE 6262, ARP's, .140 MLS
    OBX T4 Top Mount
    Tial 44mm MVR
    Tial Q 50mm
    Open Dump Love <3
  10. #235
    Virginia
    97' m52 turbo
    Quote Originally Posted by Loki Motorsport View Post
    Looks like a legit filter. I got the conical filter I posted last to fit pretty well. Only concern is that its kind of small.
    Only other way I think with a normal size filter is to drop the turbo... which I really don't feel like doing but we'll see what happens.
    Times like these I wish would have went top mount.
  11. #236
    Apr 2006
    Minnesota eh?
    86 325es
    So you could have no filter at all because the turbo is an inch from the headlight?
  12. #237
    Virginia
    97' m52 turbo
    Nope, not just that.
    Back is starting to hurt from getting underneath the car, lol. Also, turbo bolts are so tight that it would probably take me about hour of cussing to get them off and an hour of cussing to get them back on. I mean this thing is tucked but it does fit extremely well, I will say that. SPA was definitely the way to go, thank you guys for the recommendation.
    I'm sure ill be happy I went bottom mount when out driving on a 90 degree + weather
    How do you feel about the conical air filter I posted earlier someguy? Do you think it will breathe well enough?
    Side Notes:
    AEM Meth kit will be here today! Pretty excited about that. I've read that its not the most reliable setup but I don't plan on using meth to raise boost levels. Should help cool the intake down with the turbo/filter being directly underneath the exhaust manifold and give me a little piece of mind.
    I'm only using 1 nozzle so I suppose the best place to put is in the intake boot somewhere. Not sure if I would get good results by tapping the manifold in a center location, not sure how well the mist will be distributed that way.
    Other things I've completed:
    3" down pipe mocked up, glad I don't have to run <2.5" piping - 3" exhaust guys, are you running a res? VA doesn't test exhaust gasses so I could get away with something that resembles a cat as long as there is a bung and o2 sensor somewhere near it. Any recommendations? I was thinking of doing a glass pack or reusing my Borla muffler? Any suggestions here? So I can get this stuff ordered
    Charge Pipe cut out for BOV, BTMAF
    I really want to remove smog pump assembly but I don't want get gigged at inspection for it missing. I wonder if they'd notice?
    Getting so close I can taste it =
  13. #238
    Dec 2013
    Redmond, OR
    Top mount problems 101 right here... Exhibit "A" lol
    This is one of the things that infuriated me the most about this build, to the point where I wanted to put the filter in a blender.
    I ended up using a mother forking 45* elbow off the inlet, and a section of pipe to put the filter down behind the front bumper.
    Anthony Bartolini
    Loki Motorsports
    Stock Internal M52
    M50 Manifold
    OBX T4 Top Mount
    Tial 44mm MVR
    Tial Q 50mm
    Open Dump Love <3
  14. #239
    Apr 2006
    Minnesota eh?
    86 325es
    I have no experience with spectre filters but it looks like a cork to me.
  15. #240
    Manchester, N.H.
    96 332IS 6466 turbo
    I like this op is getting things done. Must be young and have energy.
    1996 332IS
    Built 3.2
  16. #241
    Toronto, Canada
    E36 Turbo
    lol
  17. #242
    Virginia
    97' m52 turbo
    I'm not into spectre and its prob the least quality item in the build but it works and If I can replace it without removing everything, then hey, I'm all for it. There might be a better one out there somewhere, not sure. A smaller filter may work as long as It bends or flexes easily without being damaged.
    28 - not so young...
    Energy = Maybe a little. I've been in my garage everyday since this thread has started. This project is something I've always wanted to do since I've owned the car but I didn't have the funds when I was younger. Its pretty awesome to see it come together and I'm sure I'll get great satisfaction out of driving the car when its done.
    Looking to source a m52b28 or > to slowly build up. Its seem most of everyone on here goes with low comp pistons/rods/etc eventually. This way I can slowly work on it while I enjoy what I have now
  18. #243
    Manchester, N.H.
    96 332IS 6466 turbo
    Most salvage yards have M52's for around $250-350
    Do yourself a favor and ask for the trans too. Offer them $500 for engine/trans. Always have a spare trans with turbo e36
    1996 332IS
    Built 3.2
  19. #244
    Virginia
    97' m52 turbo
    I do have a salvage yard close by might have to do that
  20. #245
    Dec 2013
    Redmond, OR
    Aren't ZF's pretty darn stout? I haven't had any issues with mine yet at 245K miles.. OE Trans. The 1-2 mesh feels a little disastered, but it never pops out of gear or anything! Alot of the car's past year has been drifting as well.
    Anthony Bartolini
    Loki Motorsports
    Stock Internal M52
    M50 Manifold
    OBX T4 Top Mount
    Tial 44mm MVR
    Tial Q 50mm
    Open Dump Love <3
  21. #246
    Jun 2005
    New England
    Depends on how much power you have, how the power arrives, how you drive, whether you drag race. Many of us have broken zf320. A few have gone to vetrsg 420g or zf 6 speeds that can take more torque, a few have gone to domestic manual trans like the t56 magnum, and a few have gone to domestic automatics like the c4.
  22. #247
    Feb 2009
    Arizona
    1998 e36
    Ok at least you are making some progress, respect.
  23. #248
    Virginia
    97' m52 turbo
    AR .53 should be more low end
    Quote Originally Posted by hakentt View Post
    Thanks,
    All that is really left is a tuning package (injectors, MAF) connect piping, and monitoring hardware. Also have to replace dip stick o-ring as its leaking pretty badly.
    I'm going to post pics of my scavenge/oil return setup at some point, which is working great btw. Didn't have to tap any part of the engine.
    Drain from turbo -> Check valve before first SP inlet -> tubing to second s pump on the upper part of motor near intake manifold -> returned to cylinder head, vanos sprocket bolt replaced with flanged bolt. 2 pumps, I'll have some redundancy in case one decides to bite the dust.
    and I got to get one of these because I had an excuse
    Lincoln 180, not too shabby
  24. #249
    Virginia
    97' m52 turbo
    Today was an excellent day. Got everything buttoned up, fresh oil, cooling system bled, intercooler/piping installed, and confirmed no HG/head issues. Boost is not too far away...
    Been awhile since I uploaded some pics:
    Second SP, First SP is intalled where Raj recommended
  25. #250
    Dec 2013
    Redmond, OR
    How did you end up mounting your intercooler? Trying to figure out a better way to do mine, and yours looks nice and clean!
    Anthony Bartolini
    Loki Motorsports
    Stock Internal M52
    M50 Manifold
    OBX T4 Top Mount
    Tial 44mm MVR
    Tial Q 50mm
    Open Dump Love <3
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
