Page 33 of 78 FirstFirst ... 823242526272829303132333435363738394041424358 ... LastLast
Results 801 to 825 of 1931
Thread: m52 Turbo Build
  1. #801
    Virginia
    97' m52 turbo
    Quote Originally Posted by Butters Stoch View Post
    Wait till the point when you decide 550 isn't enough, and your buying $1600 clutches, and breaking 1-2 ZF transmissions a year .
    I can handle that
    Sounds like fun
  2. #802
    Virginia
    97' m52 turbo
  3. #803
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    I was directed to check out this post. I really hope my harness doesn't look like yours. No offense. I wish you the best of luck. I def know how you feel though, i just want my car to run right, but am having trouble spending any more cash on it.
    sorting through harnesses sucks.
  4. #804
    Virginia
    97' m52 turbo
    Quote Originally Posted by vr6dubny View Post
    It's really not hard to replace.
    It took me 45 minutes to remove It after I got the intake manifold off. Get a Bentley and label connections on the broken harness.
    If you need to borrow a Bentley I have one, pm me.
    And dont get discouraged! what problems are you having?
    If all else fails for me I'll get another car and swap the motor in and burn this one. Don't think it's gonna come to that though
  5. #805
    Virginia
    97' m52 turbo
    Went ahead verified timing for he'll of it
    Also got a awesome custom made O2 in the mail from butters, awesome dude
  6. #806
    Virginia
    97' m52 turbo
    Sorting through this today
  7. #807
    Vancouver, B.C., Canada
    '97 M3
    What a mess.
  8. #808
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    What is a custom made o2?
  9. #809
    Virginia
    97' m52 turbo
    Quote Originally Posted by rajicase View Post
    As smart as you are you could probably figure it out.
    Really only one thing on it you can modify
  10. #810
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by 328iFun View Post
    I'm trying to understand what the benefit is and why you need it?
  11. #811
    Virginia
    97' m52 turbo
    Was just extended and soldered
  12. #812
    Virginia
    97' m52 turbo
    So ran into more problems today, unresolved preexisting problems.
    The car would not energize the main, fuel, or any other equipment.
    It was stuck at the ECM phase.
    After messing with relays and a whole bunch of other crap I decided to test voltage at the jumper box where the power coming from the fusible link feeds.
    Got 12 at battery but 0 at terminal, bridged the connection which feeds the main relay to 12v constant and voila. The fuel pump and everything powered on.
    Dme is functioning as I have a check engine light
    New harness is on but I'm at a stand still until I can get a third camshaft sensor mines toast
  13. #813
    '97 M3
    The silicon impregnated fibreglass wrap wire protection and the Teflon wiring used for O2 sensors can handle the high heat near exhaust systems. I've had a non Teflon wiring harness melt and cause all kinds of issues, you may want to verify that wire was used.
  14. #814
    Virginia
    97' m52 turbo
    Will do
  15. #815
    Virginia
    97' m52 turbo
    Dont worry ladies and gentlemen shes comiing back to life
  16. #816
    Apr 2017
    Florida
    E36
    Make some progress today?
  17. #817
    Virginia
    97' m52 turbo
    Quote Originally Posted by Thompson501 View Post
    Yup, I think so.
    Relays are all coming on and I was able to connect to the obd connector under dash. Back to Square one.
    Now I just have to put it all back together and order a cam sensor
  18. #818
    Apr 2017
    Florida
    E36
    Sounds good
  19. #819
    Virginia
    97' m52 turbo
    Feels like its been a month before I post anything here but its only been a few days, ha.
    But an update for everyone, waiting on camshaft sensor and have to go to the scrapyard to grab an M50 manifold (mine looks terrible and I want to look nice and clean.)
    aside from the BMW, I picked this car up yesterday
    2000 VW Cabriolet 2.0l, Mechanic Owned
    and what a cool car it is! Guy took it as trade for one of my older HD sportsters that was rarely ridden. Thought you guys may be interested in it as it is German and actually a pretty neat little ride. Car has fresh paint, new lowered suspension, BBS Reps, New Top, Sound System, New sports seats/steering wheel, New exhaust with a decent muffler, and came with a ton of spare parts/original seats, etc... I would have never seen myself driving one of these 8 years ago, interesting how your taste changes as you get older. The motor looks super easy to work as there's a ton of room in there and parts appear to be relatively cheap. Would make a nice DD and I bet out would fly with some boost on it
    Anyway here a few pics:
    I hope to be back in the garage this weekend wrenching on the 328
  20. #820
    Virginia
    97' m52 turbo
    After driving the VW the e36 will always feel fast
  21. #821
    Apr 2006
    Minnesota eh?
    86 325es
    If a child of mine bought that Volkswagen I would stop buying them Christmas presents and write them out of my will.
  22. #822
    Virginia
    97' m52 turbo
    Lol
  23. #823
    Virginia
    97' m52 turbo
    I was a bit skeptical and always have been a bit skeptical of them.
    But honestly it's actually kind of fun.
    And the fiance likes it so that's all that really matters
    I traded a 883 sporster for it which wasn't ridden very often
  24. #824
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It's a girls car although I know an effeminate middle aged male chiropractor with a green one that looks just like it.
  25. #825
    Virginia
    97' m52 turbo
    Lol
    They say the samething about the boxster. (And I was about to trade for one, a 2000 actually). Condition was horrendous though. I would have spent absolute fortune fixing the thing up.
    And hold up... wasn't Britney Spears on a tabloid for an E36 when they rolled out? And I know youve seen some of the guys BMW put behind the wheel for there flyers. Can you say sweater vest?
    Funny thing is fiance can't even reach the pedals (yet).
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
