Yes, buy 3-5 gallons of VP M1 methanol. Then cut it yourself.
Sent from my E6782 using Tapatalk
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
Looking forward to running the meth.
I bought a flip down LCD head unit that has AV inputs. I plan to build a custom Mini ITX PC for data logging and digital gauges with an in car UPS. Tuner will able to remote in at anytime and make adjustments
I was reading Intake Temperatures the other night 46f ambient, Intake was about 86f. Be interesting to see the difference with Meth
Your turning into a toned down mild bry195.
1996 332IS
Built 3.2
Now that your going to become a meth head junkie. Let me fill you in on a little secret.
Buy a second tank, pick up a 3 way solenoid from eBay so you can toggle between tanks. Fill the second tank with 75/25 antifreeze/ water. Obviously heavy on the water. Then if you are getting chased by the police, flip the switch and you will have a James bond smoke screen. Bam.
1996 332IS
Built 3.2
What WG spring do you guys recommend?
Dang no one on the spring...
Drove the car again today after installing new manifold I tapped. No more vacc/ boost leaks
9 psi @ 11.8 AFR
No addtl oil at hg seam. And I think it was running down from the valve cover gasket anyway.
So a good day here in va. Good running car with 60 degree weather
Cut fenders. Waiting for flares: nice not to rub
nice job on the Taps, did you thread them with an 1/8" NPT? or just push hard and self tap? (I used a tap, not sure the outcome yet on leaks going to test Thursday)
what flares did you get? im soon realizing the magnitude of my paint Delma and might as well do them... looking for a not so aggressive look
I used 1/4 fittings with 1/4 -18 tap.
I tried hard tapping the last time... don't do it
I have felony form reps on the front and ores these for the rear. But comes with fronts that I'm not gonna use.
https://rover.ebay.com/rover/0/0/0?m...2F253310140419
Integrated my zeitronix zt 2 display into cluster. Has 4 viewable readings on it
Afr
Egr
Lamba
And 1 user input of choice.. boost etc...
Took quite a bit of trimming but I'm liking it
^ video of it booting up
97 Turbo 3.2L M3 - Cutring / ARP - RSI Top Mount - Gt4088r - ID1300 - Tial WG - 22RPD Tuned - 93 Octane - 3.5" Stainless
18 psi spring then I can run up to 36
Korrect?
Fax all the boots
Sent from my SM-G935V using Tapatalk
This ^
How do you mean?
Need MilKt to decode
20psi is a reasonable low boost setting. Anything less might as well be NA
Where zack?
Hey Zack, can we 20 PSI + Meth?
Maximum Boost, Corky Bell -
Considers that high boost? Am I missing something here? What book are you reading Raj?
Got home from work today saw the car sitting in the garage, even with cut fenders and not fully complete (to my liking) I have to drive it up and down the road when I get home from work. So much enjoyment
Thanks again everyone!
Ps. Thing does a nastay brun out
Probably not. That's why you MAKE IT LIKE IT.
Beat it into submission.
NO MERCY.
