Page 68 of 78 FirstFirst ... 18435859606162636465666768697071727374757677 ... LastLast
Results 1,676 to 1,700 of 1931
Thread: m52 Turbo Build
  1. #1676
    Nov 2013
    VA
    E36
    Quote Originally Posted by 328iFun View Post
    Lol,
    Yeah, the first time I took he failed it because of the power steering clamps, leaking fluid and the SRS steering wheel was removed. Fixed the leak and put the OEM wheel back on, car sat at his shop for 4 days before he even looked at it.
    Then tried to fail it because the wheels apparently are sticking out too far from the fenders so I removed the spacers at his shop and it passed.
    3,000 or so miles on the car, still on a 7 PSI spring with an EBC. I've hit 14 PSI under heavy load but it doesn't hit as hard with the 7lb spring
    Nice, luckily in my area we don't have emission testing (yet) otherwise I'd be screwed. By the time they enforce here my car will be an antique and I won't have to get it inspected at all, 2 years and counting.
    That antique privilege can't come soon enough. Haven't had safety inspection for a couple of years now for this very reason. It also helps that we don't have emissions in our side of town and cops have more important things to worry about....
  2. #1677
    Virginia
    97' m52 turbo
    Quote Originally Posted by bmw328m52 View Post
    +1
  3. #1678
    Virginia
    97' m52 turbo
    Guys, question:
    I have a second AEM Meth Nozzle sitting in my garage with no use... Was thinking about connecting it somewhere in the turbo intake to help cool it down. I already have 1 nozzle in the intake boot but was thinking having a second one installed would help cool the turbo.
    My question is where should the nozzle be placed for best effect? Weld a bung in the piping close to turbo, in the middle of the air filter, or right after the air filter?
    or use another one of these in my silicone bend:
  4. #1679
    Virginia
    97' m52 turbo
    Pretty sure I had a bit too much fun today with a buddy... Burnouts and what not.
    75% positive my clutch is gone at about 3k+ miles, gripforce stage 3.
    Car wont move, had to get a tow home. Guess I'll be pulling the trans and investigating :-(
    If it is the clutch, what do you guys recommend for a replacement ?
  5. #1680
    Virginia
    97' m52 turbo
    Little update for everyone,
    Went ahead and ordered and installed a lift, makes life SOOO much easier. I recommend MaxJax by Danmar; Good quality and even better customer service. Had the clutch removed in about 45 minutes or so.
    Should I be good reusing my flywheel and pressure plate? Clutch is toast, pics below
    Gripforce Stage 3 didn't hold up too well. Lasted me maybe 2,000 miles or so
    Sent from my SM-G960U using Tapatalk
  6. #1681
    Apr 2006
    Minnesota eh?
    86 325es
    If you put another ceramic puck disc in it will probably bed and work again for awhile, but any other friction material is going to die a fast death riding on those two. Mabey try a clutchnet disc.
  7. #1682
    Virginia
    97' m52 turbo
    went ahead an ordered another ceramic clutch kit
  8. #1683
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    It is a struggle to get 6 puck discs to last more than 15k miles in any car. They require you to slip it so much to leave smoothly without chatter, and then they don't have much wear material vs a solid disc.
    It looks like one of your pucks disintegrated causing the premature failure.
  9. #1684
    Virginia
    97' m52 turbo
    Quote Originally Posted by wgknestrick View Post
    15k isn't much. But isnt terrible as long as the fw and pressure plate remain good... not in my case though
    Mine was a result of several, and I mean several long burnouts one after another. Car wouldn't even move afterwords... I had fun so it's all good.
    Thinking about signing up for some technical driving courses nearby. There's no where around my area where I can and really get a feel for the car
  10. #1685
    Apr 2006
    Minnesota eh?
    86 325es
    A normal stock organic clutch works by creating an adhesion between the disc and friction surface just like a brake pad. It doposites a polymer film onto the flywheel surface which sticks to itself. Everything in the disc is softer than the flywheel so the friction surface doesn’t wear out, the disc does. A ceramic disc is much harder than the iron flywheel and pressure plate and it makes its friction by actually digging into the friction surface like tire studs on ice. It’s the equivalent of using a grinding wheel as a clutch disc. With a ceramic clutch the flywheel, pressure plate, and disc are all consumbles. Your new pressure plate and flywheel you ordered will also be going in the garbage in a year or two.
  11. #1686
    Virginia
    97' m52 turbo
    Makes sense.
    I guess I'll have to get a better job
  12. #1687
    Virginia
    97' m52 turbo
    Ordered this setup this go around.
    Was stage 3 previously, says this one is stage 4 but looks the same as the 3 to me?
    Not sure what would make it a 4
  13. #1688
    Jan 2017
    Metro Detroit, MI
    98 BMW 323is - 2.8T
    Looks to be an unsprung clutch disc. Would not recommend, as that will put significantly more shock load on the drivetrain. You'll start breaking trannys namely, with maybe a driveshaft or axle too. That's pretty much the only difference between most of the ebay stage 3 and 4 kits. Spring vs unsprung.
    Sent from my Pixel 2 XL using Tapatalk
  14. #1689
    Nov 2013
    VA
    E36
    friction surface and torque ratings are the same. Stage 3 is sprung while Stage 4 is unsprung. I think most would agree that a sprung clutch is better for the street. Unsprung when full track car.
  15. #1690
    Virginia
    97' m52 turbo
    Ready see how this unsprung clutch feels...
  16. #1691
    Virginia
    97' m52 turbo
    Got the car reassembled and just took her out. Felt great to drive it again, was sitting for about 3 months.
    How many miles do you all recommend for 'breaking-in' a ceramic clutch? There was no recommendation in the directions
  17. #1692
    Mar 2012
    Renton, Wa
    98 m3
    Most manufacturers say like 750mi is best but Atleast 500. I personally have never made it over about 5.....
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  18. #1693
    Apr 2006
    Minnesota eh?
    86 325es
    End of the driveway.
  19. #1694
    Nov 2013
    VA
    E36
    Most I've ever gone is like 40 miles lol. Also fx stage 3 and still no clutch slippin.
  20. #1695
    Virginia
    97' m52 turbo
    Yeah...
    I cant handle babying it much longer. Made it about 30 miles so far
  21. #1696
    Apr 2006
    Minnesota eh?
    86 325es
    Let’r rip tater chip.
  22. #1697
    Apr 2006
    Fall City ,Wa
    E36 Turbo, E39 M5
    Do it for Dale!
  23. #1698
    Nov 2013
    VA
    E36
    Yeah...
    SEND ITTTT
  24. #1699
    Virginia
    97' m52 turbo
    Could help my self......
  25. #1700
    Virginia
    97' m52 turbo
    F-it...!
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
