UPDATE: 4/26/2018 - Thread updated:
Hey Everyone,
I'm finally in a position where I can start building my own turbo system on my E36 and I'm pretty excited about it, well I'm actually in the process of restoring the entire car, so why not? I have my own shop with all the equipment I need and I also have alternate vehicle so I can really take my time on it and do it right. With that said, I've never built my own FI system before so any feedback or experiences anyone has had with the m5x/s5x motor is greatly appreciated. I intend to do all the work myself aside from tune (unless I can get some good advice on how to do that part myself). As far as piping I may look into getting my own welder/pipe bending equipment and taking care of that part myself as well.
That said about the car; its a 97 328i convertible with approx. 140,000 miles on it. the entire vehicle was recently stripped own to bare metal and primed by myself. I've had the car for quite some time and its been through quite a bit cosmetically as a Deer have decided to jump into it I believe 3 times now (hence the body work). The car will be repainted it's original color, Boston Green when it starts to warm up here in VA (will post pics of the body work later). Interior has been gutted as well and will be replaced as I find replacement parts that meet my standards.
My goals are; as long as the leakdown test proves my motor can handle a turbo is:
- 6-20 adjustable PSI
Yes.
- ARP Studs
Yes.
- Cometic Head Gasket
Went with cutring gasket/copper spacer via CES
- Clutch replacement when the head is off
Grip Force Stage 3 6 puck Ceramic Clutch and Chromoly Flywheel
- Top Mount Manifold: I've read some pretty bad stories about exhaust manifolds. If anyone has a good top mount manifold for a decent price please post links. I would like this part of the project to be the least time consuming. And I do have projector head lights and want to retain my AC compressor. Fiance would upset if I removed it
Went Bottom Mount with SPA manifold and rally road engine bracket
- GT35R Turbine
Nope. Precision 6262 Journal bearing
- Can't decide if I want to go to scrap yard and grab metal oil filter housing off an m50 yet for oil taps, any suggestions?
Tapped turbo drain from Vanos and drained to oil drain plug via 1/2npt flange fitting
- The car will be intercooled and I haven't decided on tuning yet, I've read a lot war chips and stand alone ECU's and I'm no in a rush to make a decision.
Treadstone 1235, fits nicely and went with 22RPD (zack) Tune
- 60lb injectors
Yes
- Walboro fuel pump, suggestions on this?
Walboro 255
- MAF, this could affected by tuning what I finally decide to go with as miller has a blow through maf
Blow through, comes with stock DME tune.
- As far the electronics; gauges and things of that sort. I'm not in a rush to make a decision on those. I feel that these items can wait after mechanics are sorted out.
Zeitronix ZT-2 for AFR and datalogging, Eboost street 2 for display and control, AEM for meth injection
Here are some pictures as the car sits now:
FINAL RESULT....
Read for more information.........
I embarked on a similar project a few years ago, take a look at the 97 BMW M3 thread in my signature. You should consider cutring head gasket and spacer over MLS. A Spa bottom mount cast iron manifold is popular and you can retain AC. Keep an eye on classifieds, used turbo tunes and parts always pop up there. I went with RK-Tunes and have been pleased with results and service. It appears you're not afraid of a project, so this should be no problem. Plan to spend $4-5k on the full turbo setup.
S52, OBD2 RK 60lb, cutring and spacer, ARP head studs, GT3582R, AA bottom mount, Tial 44mm WG, Tial QR BOV, Vibrant 3.5" IC, FX stage 4 clutch, hobbs switch meth injection, working AC, and 516 RWHP!
97 BMW M3 | 96 VW Passat TDI | 87 Porsche 930 | 92 Toyota Pickup | 00 S10 ZR2
I think I had read over your thread once before and I'm sure I'll be using it as a good reference point.. As far the B
bottom mount, I was really hoping to be able to pop the hood and see the turbine laying there BUT if Bottom will save me time and frustration than I don't see too much of a problem with it.
And I was thinking about doing cutring will probably seriously consider it.
I'm extremely anxious to get home and pull the head off... I've replaced a head once before I actually enjoyed and it wasn't too bad. I'll have to find the tools needed to do it though, should have kept them...
Have any links to the manifold by chance?
Don't bother with the metal oil filter housing. You will be feeding turbo from vanos line banjo bolt.
Walbro 255 pump cheap and good.
As for MLS vs Cutring/spacer.
Comes down to budget. If you can afford cutring get it. But $700 vs $450 with ARPs.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
That rockband garage is on point! I would look into an AEM 320LPH pump. I picked one up for about the same price as a walbro 255 when my 255 went bad last year.
Great, I was looking into that. I saw that there's adapter for relatively cheap, Ill probably go that route.
I'm going to look around for gaskets and get some prices. I plan on taking the front end of the car when I get home and I've already ordered the head removal tools.
Haha, thanks. My fiance and I will go out Jam out every once in awhile. She plays drums I usually have to persuade her though.
Looks like a good pump for a good price. Added to the list
saw this on panjo: https://www.panjo.com/buy/spa-turbo-...for-e36-336057
I'd just buy an OBD2 M52 60 lb blow through tune rather than mess around with the OBD1 Miller War Chip. A good tune will handle a GT35R on an M52 anywhere in your 6-20 psi range. I would do a bottom mount gravity drain manifold like the $500 SPA or, if the budget allows, the new twinscroll steedspeed for $1350. And spend the money on the cutring and spacer if you are thinking this motor might be longer term. There are plenty of cases of MLS gaskets going 20k or more miles if properly prepped, but a lot have eventually leaked for some reason.
I like, wonder if he'd take 500
That's good information. Will all the effort and money I'm putting into this car I would like it to last as long as possible and at this point I'm thinking the cut ring is the way to go.
You wouldn't happen to have links for the blow thru/gasket would you?
RK, Technica, TRM, CES all have tunes. I have used a Technique Tuning OBD2 60 lb blow through tune for the past 7 years with 4 different turbos, including a GT35R, to make anywhere from about 400 to about 700 rwhp without issue. CES sells Technique Tuning OBD2 tunes:
http://www.cesmotorsport.com/
You can probably order one through member Butters Stoch, who supports CES as you can see from his signature lines.
Did most of you guys take your cylinder head to be milled and cleaned?
100% yes on cylinder head you should put in new seals too. I've got a 64.5 mm bw sxe for sale if you want. It's a little bit large but would fit your application depending on manifold lol.
I would use a smaller, more responsive turbo for your power goals on your 2.8L. More like a GT3582R size turbo.
More than likely what ill go with...will be taking the head Monday to be resurfaced.
I was looking into ordering the gasket/spacer/rings and studs but I noticed there are different dimensions 84.5mm to 87mm? Does anybody know what would best for the m52?
Thanks for the help, I'm noob on a lot of this stuff but I'll eventually figure it all out.
Guys,
Would this http://www.ebay.com/itm/like/2722953...&ul_noapp=true be a good install for top mount?
that looks pretty nice for the price. Its mild steel so expect the paint to fall off and turn rust colored in a month. I noticed that the shock tower was beaten in on the picture for clearance so you might have to do the same depending on turbo. Looks like there are some different options for wastegate placement and such as the pictures show a few different configurations.
Thinking about getting this manifold today:
http://www.ebay.com/itm/Active-Autow...5YvzsZ&vxp=mtr
Its a used AA bottom mount. Anyone know anything about these and their functionality?
Also been looking into Clutches and have read that the F1 kits are holding up well for turbo applications. Can anyone confirm this? And are they using stage 1 or 2, etc...
Thanks for the help
http://www.ebay.com/itm/Garrett-turb...torefresh=true
What about this turbo, it's a garrett, used but a good price
$1000 for a used gt35r seems expensive to me.
