Page 2 of 78 FirstFirst 1234567891011122752 ... LastLast
Results 26 to 50 of 1931
Thread: m52 Turbo Build
  1. #26
    Virginia
    97' m52 turbo
    I offered him 750
  2. #27
    Manchester, N.H.
    96 332IS 6466 turbo
    Brand new gtw 6262 or gtw6265 is close to $1k BB.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  3. #28
    Aug 2014
    United States
    97 M3, 08 X3, 96 VW TDI
    Quote Originally Posted by 328iFun View Post
    Thinking about getting this manifold today:
    http://www.ebay.com/itm/Active-Autow...5YvzsZ&vxp=mtr
    Its a used AA bottom mount. Anyone know anything about these and their functionality?
    I've got an AA and that one looks quite different, odd WG port on it. It seems pricey, I got my stage 2 AA for $350 used
    Also been looking into Clutches and have read that the F1 kits are holding up well for turbo applications. Can anyone confirm this? And are they using stage 1 or 2, etc...
    Thanks for the help
    I went F1 stage 4 with chromoly flywheel, holds up well and good drivability.
    http://www.ebay.com/itm/Garrett-turb...torefresh=true
    What about this turbo, it's a garrett, used but a good price
    Seems high to me. I got a GT3582R and turbo blanket for $800 off craigslist.
    I saw a spa manifold, motor mount arm, and wastegate on the boosted e36 world classified facebook page today
    S52, OBD2 RK 60lb, cutring and spacer, ARP head studs, GT3582R, AA bottom mount, Tial 44mm WG, Tial QR BOV, Vibrant 3.5" IC, FX stage 4 clutch, hobbs switch meth injection, working AC, and 516 RWHP!
    97 BMW M3
    | 96 VW Passat TDI | 87 Porsche 930 | 92 Toyota Pickup | 00 S10 ZR2
  4. #29
    Virginia
    97' m52 turbo
    So I was cleaning the block today found an indentation near the rear outer wall. Kind of has me worried. Do you guys think it would cause any issues:
  5. #30
    Vancouver, B.C., Canada
    '97 M3
    Soon I will be selling a GTX3582R, Steedspeed open T4, Tial MVR and I can throw in a 3.5" down pipe with WG pipe. I made 660 whp with it. I'm not sure what it's all worth though.
  6. #31
    Virginia
    97' m52 turbo
    I'd be interested just let me know
  7. #32
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Don't worry about the indentation. Fill it with JB Weld if you want.
  8. #33
    Virginia
    97' m52 turbo
    Thanks for assurance...
    Got the tranny out today. Clutch, cut rings/studs are on order.
    Still looking for a spa setup for a good price.
  9. #34
    Mar 2013
    Upstate NY
    M3
  10. #35
    Virginia
    97' m52 turbo
    Quote Originally Posted by Mklock View Post
    Never heard of or used Panjo before, is it legit?
  11. #36
    Virginia
    97' m52 turbo
    I'LL give Panjo a try
    Will post pics when I get them in thanks for link man
    If anyone finds a good new used compressor for a good price let me know.
    Also looking for a good bottom mount down/charge pipe and intercooler setup
  12. #37
    Virginia
    97' m52 turbo
    I just realized I may be the first person on the forums that is doing a full restoration and turbo build at the same time.
    correct me if im wrong
  13. #38
    Jun 2003
    Cape Cod, MA
    95 M3
    is this a garage or your house, looks like a sick place to do some work!
  14. #39
    Virginia
    97' m52 turbo
    Quote Originally Posted by AntiHero View Post
  15. #40
    Virginia
    97' m52 turbo
    It's the garage at my house? I could probably live in it though considering as much time ive spend in it
  16. #41
    Virginia
    97' m52 turbo
    Turbo Drain -
    I've read that most bottom mount guys tap the oil pan above the oil plug. I'm pretty sure I don't want to pull the pan and the tap it. There have to be other options here?
    I was thinking of using a scavenge pump and either tapping the oil cap or a cylinder head bolt somewhere?
    Any suggestions?
  17. #42
    Feb 2009
    Hackettstown, NJ
    1998 328i
    I tapped my oil pan above the drain plug and I do not have smoke issues. Some have also used the drain plug as a drain for the turbo, but I don't have any experience with that.
  18. #43
    Manchester, N.H.
    96 332IS 6466 turbo
    Blow/open the drain plug out to 1/2NPT.
    1996 332IS
    Built 3.2
  19. #44
    Virginia
    97' m52 turbo
    Quote Originally Posted by Butters Stoch View Post
    10-4 will do, thank you
  20. #45
    Virginia
    97' m52 turbo
    Butters,
    I had read a post from awhile back about manifold vacuum routing (and connections that should not see boost I.E. PCV) by fly. He said he got some of the information from you.
    After reading what I understand is that any connections that lead from the manifold then to the head or block should disconnected from the manifold and then vented atmosphere?
  21. #46
    Manchester, N.H.
    96 332IS 6466 turbo
    You mean crank case ie valve cover/oil dip stick tube. Get rid of all that cyclone separator crap.
    1996 332IS
    Built 3.2
  22. #47
    Virginia
    97' m52 turbo
    Just take it out completely? Will do
    thanks again
  23. #48
    Virginia
    97' m52 turbo
    Ill be the proud new owner of a Garrett GT3582R sometime this week. Hopefully Thursday.
    http://www.ebay.com/itm/152445298251...%3AMEBIDX%3AIT - Got it for $950.01.
    I've prob spent 3.5K so far... geez.
    Will post pics on arrival
  24. #49
    Virginia
    97' m52 turbo
    I've been doing some research on Methanol and it seems to me that a meth setup will give me even more piece of mind.
    Anyone on here using one? If so who'd you go with and why?
  25. #50
    Ship, Pa
    Red Sled, RC51
    I've got an aquarist setup I'd sell you
    "Believe nothing you hear, half of what you read"
  1. e36 m52 turbo build
    By 022689e36 in forum Forced Induction
    Last Post: 11-12-2012, 09:47 AM
  2. e30 m52 turbo build
    By M50ethirty in forum Forced Induction
    Last Post: 06-29-2012, 10:38 AM
  3. Replies: 1
    Last Post: 01-21-2012, 02:33 PM
  4. Replies: 2
    Last Post: 05-07-2011, 03:26 PM
  5. Planning stage: OBDII M52 turbo build help
    By LTCol in forum Forced Induction
    Last Post: 08-06-2008, 11:17 AM
