Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 14 of 14
Thread: Perfect e36 wheel size
    Aug 2013
    Wooster, ohio
    1992 325i
    So I need some wheels. It's about time. I've never put aftermarket wheels on any of the 6 bimmers I've had but have researched many times and almost pulled the trigger( I like seeing the money in my bank and not on my car) but times have changed.
    The car is a 92 325i with 15 inch style 17s. I like the wheels alot. They're light, they look nice and are in good shape. But soon I will begin auto crossing and these won't cut it. I need tires but am just going to buy wheels while I'm at it.
    I want at least 17s. I'm thinking 17x7.5 to avoid any fitment issues when I lower the car. Will this fit ok with the correct tire? I will never go crazy low just bilstien with some lowering springs or decent adjustable coilovers. I won't be spending a whole bunch max 150 a wheel so don't suggest anything to fancy. The car is 25 years old and is worth nothing.
    Offset has me very confused. I can't find the offset for the style 17s. I don't want them to stick out or anything I'm thinking 38 to 42 somewhere in there.
    Here is the car now
    It will soon have a gloss black hood roof and trunk and painted black bumpers.
    Any suggestions and or information on sizes or fitment is much appreciated. Thanks in advance.
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Check out this article, it'll explain everything you need to know about wheel fitment and spacing.
    Wheel Fitment & Spacing Guide
    -Dmitry
    888.280.7799 | 6am - 5pm PST
    Mar 2006
    Buffalo
    99 Jeep Cherokee
    I would just find a used set of ds1 or ds2 wheels.
    I have a set of ds2's I may be getting rid of that are black.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    17" is the max I would recommend for this car, but keep in mind that 16" is not a bad option with a broader & cheaper tire spectrum available.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Below is a link to all the wheels we carry that fit your car. Keep in mind that the 17" will be a stiffer ride than the 15" OE set up. There are numerous options in both 16" and 17" listed. If I can help with anything let me know.
    https://www.tirerack.com/wheels/resu...&package=false
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The 96-99 M3 used 17x8.5 rear with 245/40/17 and 17x7.5 front with 225/45/17. Those sizes would be a nice upgrade. The 95M3 used 17x7.5 front and rear with 235/40/17 front and rear, which would also be a good upgrade and let you rotate tires front to rear.
    People more seriously into handling will often go 17 x 8.5 with 245/40/17 front and rear. They may combine 2 sets of rear wheels or buy aftermarket wheels like Apex ARC8 (that are lighter than the stock wheels). Any bigger risks rubbing under some conditions, and 245/40 fronts may require a spacer depending on suspension set up, so look into that further if interested.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    You need to be careful with the size of the tires and the offset and width of the wheels though. Some lower offset wheels can cause rubbing issues on the fenders.
    Colorado Springs, CO
    F30, E36 M3
    Hey Jim, on an E36 with 17x8 ET40 SSRs would you go 225/45 or 245/40? Dedicated summer/auto-x wheel set... like to stay square.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Quote Originally Posted by pjo33us View Post
    I would go with either the 225/45R17 or 235/40R17 all the way around. If I can help let me know.
    F30, E36 M3
    Thanks for answering... I was thinking 245/40 as that would still give me the same height as a 225/45, right?
    Also, separate note, and sorry of jacking this thread but, one of my SSR Integrals seems bent and has a very small stress crack. Is it worth it for me to try and fix it and if not ANY idea where I might find one? They have not been made in like 10 years or more.
    Jun 2005
    New England
    245/40 is a little fat for an 8 inch wheel but ok. I think it's the far end of the spec range and probably provides more grip but the sidewall won't feel as sharp. There is a debate on a similar size choice among racers using stock 17x8.5 wheels -- some run 255s and some 245s and I am not sure there is a definitive answer. BMW for example specified 235/40 for 17x7.5 for the 95 M3. Running 245/40 on 17x8 should be ok if 255/40 works on 17x8.5 and 235/40 works on 17x7.5.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    They will fit on the wheel but may need a little work on the fenders on the front. If I can help let me know.
    F30, E36 M3
    Thanks Jim you have been super helpful... I think I am pretty convinced to just go 225/45 all around... Which tire do you think is the best value for summer only (we can see pretty substantial rain) & an occasional auto-x? Conti Extreme Contact DW or Hankook Ventus V12 or ??? Seems like there are some pretty good deals out there.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    I still have some Conti DW comining into us on 04/04. It is better than the Hankook and they do have a 70.00 mail in rebate on the set.
  1. E36 Wheel Size
    By KNuss in forum 1991 - 1999 (E36)
    Last Post: 07-23-2008, 04:48 AM
  2. E36 Wheel Sizes
    By zuker in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-25-2007, 12:34 AM
  3. BMW e36 wheel sizes?
    By larful in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2007, 08:59 PM
  4. E36 wheels size/offset question
    By marek in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-22-2006, 11:13 AM
  5. e36 wheel size question?
    By gilesmortimer in forum 1991 - 1999 (E36)
    Last Post: 05-23-2005, 02:18 PM
