I have most of the parts out to remove may headliner but need advise on removing rear speakers and how to drop and take out headliner.
Rear passenger door will not open stated with out side handle not working now it will not open from the inside.
How do I get this to open I need to repair the window winder and repair door stuck at this point.
thanks
When I removed my roof rails I had to partially drop the headliner. I pulled the seal out from around the door & hatch openings then removed all the inside pillar mouldings and grab handles, visor, dome lights the back speaker covers on the roof snapped into the headliner, the speaker is screwed in to a bracket underneath the headliner. If you drop the Back of the headliner you can stick your hand towards each speaker grill to release the tabs on the grills that help hold up the headliner. Or remove the entire headliner you will have to remove the sunroof glass, because is cover some small screws. On the door I don't know
