Page 12 of 12 FirstFirst ... 23456789101112
Results 276 to 281 of 281
Thread: Should I Buy 1989 750il-160k-Looks Real Nice..
  1. #276
    Dec 2013
    Uppa US
    2003 325xi Wgn+Suburbans
    Summer is here, time to fix the sword. Where is it?
    And I just got my order from FCP, 2 idlers, 12 spark plugs, belts, wheel center cap badges, accelerator pedal pivot bushing, trunk struts.
    I think I'll replace the oil pan gasket today. I added 1 gallon of synthetic Rotella last week, and 3 quarts again after coming back from a 200 mile trip to Laconia Bike Week
  2. #277
    Jul 2016
    Chicago, Illinois
    02 540/6, 89 750iL, S60R
    That's a lot of oil, must be burning a lot too. Might want to switch to 15W50\10W60.
    http://www.nmia.com/~dgnrg/page_4.htm
    Quote Originally Posted by WBAD530i View Post
    M62 is an uncontrolled substance, and when abused can cause severe side effects. Do your drugs in moderation kids.
  3. #278
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Oil spec is usually not the problem. Oil consumption often comes from this http://bmwe32.masscom.net/sean750/vc.../VCVvalves.htm
    I had the same, made an oil catcher to test it, catched a lot of oil, changed to new crankcase ventilation and all oil consumption gone see my website under Fun and Upgrades >>>M70 PVC prototype
    http://www.ow.no/index.php?option=co...d=23&Itemid=13
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
  4. #279
    Jul 2016
    Chicago, Illinois
    Quote Originally Posted by shogun View Post
    Stem seals are M20-style and they can give problems too (I'm at 1\5000 mi) hence the need for a higher oil spec\additive or a proper fix.
    He'll have to check the VCVs when he reseals the manifold too. It could very well be the cause of his increasing oil consumption.
    https://www.fcpeuro.com/products/bmw...il-11151718713
    https://www.fcpeuro.com/products/bmw...il-11151718642
    https://www.fcpeuro.com/products/bmw...-6-11151720392
    https://www.fcpeuro.com/products/bmw...70-11151720393
    https://www.fcpeuro.com/products/bmw-engine-crankcase-breather-hose-connector-850ci-850csi-850i-
  5. #280
    Dec 2013
    Uppa US
    I never noticed blue smoke, and last year I sold an early 2000 Suburban with a 5.3 LS motor, and it would smoke like crazy if it was left at idle. An easy fix was a ported PCV valve, $5 and 5 Seconds, and it didn't help the problem much if any.
    I have a radiator cooling system pressure tester, but I need the adapter to screw it into the Overflow bottle. And Amazon is no help, they have everything you need, but their search engine needs to be fixed. Their shipping is always reliable, and I order from walmart.com and they always screw things up, their pictures and listing descriptions don't match the items.
    And the post office just lost a belt that I need for my lawnmower, typical. I order things from China and they arrive in a timely manner for pennies, listings that I see on eBay for tools or camera brackets. Some things work so well, and something barely
  6. #281
    Jul 2016
    Chicago, Illinois
    Quote Originally Posted by CORVAIRWILD View Post
    I replaced mine as preventative, it went from 1\3000 or so to 1\5000. I guess additives like Liqui Moly Oil Saver could get it up higher, but my oil's already out by then. It doesn't necessarily need to be smoking either. It could very well be giving the ghost, check it out when you do you plugs and the manifold. Could be as simple as a cracked hose.
    Also, remember to remove the plug on your HCV when you replace your stat so it can bleed. The car seems to have almost doubled the purchase price by now, so I guess it's a mini restoration at this point.
    BMW from the late 80's to the early 2000's had pretty much the same expansion tank thread, just generically look up for that adapter.
  1. Should I buy '90 750il?
    By Dualnames in forum 1988 - 1994 (E32)
    Last Post: 07-16-2009, 02:07 AM
  2. Should I buy this 750iL?
    By Swordsman in forum 1988 - 1994 (E32)
    Last Post: 02-25-2006, 10:05 AM
  3. MMS Tuning Cars...LOOKS REAL NICE
    By Khoalty in forum 2001 - 2006 M3 (E46)
    Last Post: 10-06-2003, 11:59 PM
  4. Should I buy THIS 325 this weekend LOOK!
    By blueIce in forum General BMW sponsored by Intercity Lines
    Last Post: 03-01-2002, 05:39 PM
