AIM ECU Bridge - CAN/RS232
The ECU Bridge makes it easy to get data from your car's ECU to your AiM SmartyCam or AiM dash display. Just a few simple wiring connections will get you up and running.
Connecting to the ECU allows the AiM unit access to data collected by your ECU (RPM, road speed, coolant temperature, and throttle position are typical; many ECUs offer much more information).
Details can be found here: http://www.aim-sportline.com/eng/products-car/engine-data-bridges/index.htm
List Date: 3/13/2017
For more info, click here to view the original listing: AIM ECU Bridge - CAN/RS232
This item is no longer available.
Bump
Dan Huberty
