95 M3 Avus/Black Slicktop 89k mi S52 lots of extras
For sale I have an Avus/Black 95 M3 Slicktop. It currently has a S52 out of a 99M3 w/89k miles on it with Schrick Cams. Chassis has approximately 200k miles on it. Most of the parts that can be bolted onto this car have either been replaced in the last 20k miles or were off of the donor car.
The car that the motor and many of the suspension parts came out of only had 72k miles on it when it was put into the 95. The entire suspension was swapped over to the 95 as the donor car had just had new control arms and had the trailing arms re-built. The only part of the donor car suspension that wasn?t used was the passenger side trailing arm as it was found to be bent from the accident it was in. I have new ball joints for it, but they haven?t been installed yet.
Car is in great Shape overall and should need no major maintenance any time soon. Almost all of the wear items and things that cause the common E36 problems have been addressed. Speakers sound great, almost no rattle from the door panels. All of the hoses were replaced when it was built. Has a current VA Safety Inspection and passes VA Emissions with the sniffer. Below is a list of all of the parts that have been added to the car.
Parts List:
Power Train
o S52 w/89k Miles and all new hoses and sensors
o Dr. Vanos Stage 1
o UUC Under Drive Pulleys
o RK Tuned
o Schrick Cams
o 3.5 MAF
o Bimmerworld 3.5 boot
o 24lb Injectors
o M50 Manifold Swap
o Stewart Water Pump
o New Thermostat/Metal Housing
o Mishimoto Aluminum Radiator
o Bimmerworld radiator Hoses
o New Fan Clutch
o Raceland Long Tube Headers to Custom 3in exhaust w Metal Core Cat and Vibrant Muffler
Drive Train
o UUC Lightweight Flywheel and M5 Clutch kit
o Metal Pivot Pin
o Custom Steel Trans Mount
o UUC Evo 3 Short Shifter W/DSSR
o Stainless Steel Clutch Line
o UUC Motor Mounts
o UUC Trans Mounts
Suspension
o D2 Coil Overs
o Vorshlag Camber Plates
o Power Flex Front Control Arms Bushings
o Black Apex ARC-8 17x9.5
o Turner Motor Sports Aluminum Diff Bushing
o Turner Motor Sports Aluminum Sub-Frame Bushings
o Hawk HPS Pads and New Blank Rotors w/~5k miles
o Stainless Steel Brake Lines
o SPC Aluminum Adjustable Lower Control arms
o Power Flex Rear Trailing arm bushing
o Rear sway bay reinforcements
Interior
o Black leather Manual Vaders
o Euro 3-Spoke Wheel
o 6x9 Speaker Adapters in the rear
o After Market Alpine Stereo
o AFR Gauge
o Motorized Vent Windows w/center console switches
o Illuminates M Shift Knob(Not Hooked Up)
Exterior
o Glass Projector Headlights w/35w HIDs
o New Front Bumper
o Just painted the bumper, nose panel, hood and roof
Now there are a few bad things with the car, but overall I would say they are pretty minor.
? Car has had paintwork now and previously. At some point it looks like something hit the roof and there was some repair work done. That original repair work and paint work wasn?t great and needed to be fixed. In addition to that the person I bought the car from clipped a deer that the person in front of him hit. This messed up the bumper that was replaced and put a dent on the driver?s door.
? Small hole in the driver?s side Vader, about an inch long from the seat belt puncturing it.
? At some point in its life someone thought it would be a good idea to rivet ugly fake wood grain to the door and rear panels. I have replacement rear panels, but I don?t want to touch the door panels because they don?t make any noise
? Both Door Lock tumblers are flakey and need to be fixed. I have left this as I just use the trunk to unlock, and as I?ve said I don?t want to tempt fate by removing the door panels.
? Needs rear alignment, after putting on the replacement rear control arm it needs a rear alignment, but I?ve just been waiting to do that until I can get the ball joints replaced.
List Date: 3/11/2017
For more info, click here to view the original listing: 95 M3 Avus/Black Slicktop 89k mi S52 lots of extras
This item is no longer available.
Bump
****Official E36 M3 Addict****
-96 Estoril M3 Built S52 w/ GTX3576R/Schricks &Technica Motorsports Tuning & Lots of Other Goodies currently under construction(Forever)
-97 Cosmos, OEM+
-97 Silver M3/4/5, 95 Daytona Voilet M3, 95 Black M3 , 98 Estoril 4Dr & 99 Estoril 2Dr, 92 318i Vert - Pandemic Ward Victims
Bump
-97 Cosmos, OEM+
Nice car, I bet it's pretty stout. I think you'll be pretty hard pressed for that amount, but GLWS.
Bump with a price change
-97 Cosmos, OEM+
-97 Cosmos, OEM+
Bump, price drop $13,000
-97 Cosmos, OEM+
-97 Cosmos, OEM+
-97 Cosmos, OEM+
There any rust on the car?
Christopher
STX 197
1997 328is
Ahhh my cars twin
― George Orwell
I miss this car..
E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
*RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
