Results 1 to 6 of 6
Thread: STOMP TEST 1991 850i manual
    Aug 2011
    Tampa, FL
    2002 M5 & 1991 850i 6spd
    Does anyone know how to complete the stomp test on a manual car? I have been looking for an answer but have yet to find one?
    Deutschland
    1998 BMW 740i
    If you find out let me know. I have never been able to get the stomp test to work in my manual car.
    Aug 2002
    Woodbine, Maryland
    supercharged 95 318i
    I think the stomp test is the same for all pre-OBDII BMW's. Ignition on, stomp throttle to the floor five times within five seconds, count the flashes to the get the four digit code. See more here http://www.pelicanparts.com/BMW/tech...de_Reading.htm.
    On my '95 3 series the stomp test worked in the past and then would not work when I tried it recently. I found the throttle cable had stretched/loosened so when I stomped the gas pedal it did not fully open the throttle. The TPS (throttle position sensor) did not send a WOT (Wide Open Throttle) signal to the computer. I adjusted the cable and the stomp test works again.
    So, if you cannot get the stomp test to work, check the throttle cable and then the TPS.
    Jul 2016
    Chicago, Illinois
    are slow
    The timing of the stomps is a pain, seems to be more difficult in M70 cars.
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I can get the stomp test to read out codes, but I cannot clear them using the 10 sec step.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    For that I always have in my glovebox a Peake code reader, small, convenient and helps in most cases https://www.pelicanparts.com/BMW/tec...ading/pic3.jpg
    reads, resets.
  1. 1991 850i manual for sale
    By p2kusa in forum 8 series
    Last Post: 11-30-2012, 12:35 PM
  2. Failed Emissions Test 1991 850i
    By Grant850i in forum 8 Series (E31)
    Last Post: 05-27-2012, 07:52 PM
  3. E31 1991 850i 6 speed manual. $9500 OBO
    By jselig in forum 8 series
    Last Post: 04-19-2011, 06:17 PM
  4. BMW 850i 1991 Owners Manual
    By Vassiliosathens in forum 8 Series (E31)
    Last Post: 02-04-2010, 09:12 PM
  5. FS: 1991 850i 6-spd manual in Long Beach, $12,000
    By reddragongti in forum Non Specific BMWs (Classics, Exotics, MINIs)
    Last Post: 06-21-2008, 11:09 PM
