Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 4 of 4
Thread: Problem with Bridgestone Potenza 245/45RF18
    Mar 2017
    NJ
    2013 BMW 535i xDrive
    I recently purchased a 2013 BMW 535i xDrive. The dealer said they installed brand new tires and rims. The tires, Bridgestone Potenza 245/45RF18, appeared new. I have put 20K miles in the last six months that I have had the car. The front tires appear to be still fine, with plenty of tread, however, the rear tires are completely worn. Although I did not rotate the tires, I cannot explain such an extreme difference in the wear. The car has been driven with care and without reason for the severe wear on the rear tires. I am trying to find the warranty information but I believe it should be 40K miles. The wear is fairly even across the tires and although it might benefit from an alignment, I don't think it would prevent with the accelerated wear.
    See pictures on this Twitter link pic.twitter.com/WRmZkzgTwS
    [IMG]pic.twitter.com/WRmZkzgTwS[/IMG]
    Thanks in advance for any ideas and comments.
    Jim
    Boston
    2009 335i xDrive
    Makes sense to me. You're drivetrain is heavily biased to rear wheels when no loss of grip is detected. 20k is a lot of miles with no rotation
    Boston
    2009 335i xDrive
    Your drivetrain is heavily biased to the rear (>80%?) without loss of traction . 20k miles is a lot with no rotation. Sounds about right to me.
    You need to do a 4 wheel alignment and replace the 2 bad tires. You should be able to have them prorated. Good luck.
    Using Tapatalk
  1. Replies: 2
    Last Post: 02-27-2007, 04:53 PM
  2. Any experience with Bridgestone Potenza S-02 Pole Position Tires?
    By Zubehor in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-10-2006, 07:14 PM
  3. Replies: 14
    Last Post: 12-14-2004, 01:16 AM
  4. WTB Bridgestone Potenza 245/40/17
    By JohnD in forum Wheels and Tires
    Last Post: 12-29-2003, 04:49 PM
  5. Replies: 3
    Last Post: 11-06-2003, 04:20 AM
