Originally Posted by
dhelmer
Recently purchased 2013 328I. Have noticed that the speedometer reads 4 to 5% higher. Speedometer reads 80mph when actual speed is 76mph. Called dealer to see if speedometer could be calibrated and was told no calibration could be done and that higher readings than actual was normal. Has anyone experienced this? Can't believe BMW would produce a vehicle with an inaccurate speedometer.
As has been said, this is normal, but wheel size also effects the reading. If it bothers you, you can go with a different diameter tires to adjust the reading.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
