Results 1 to 14 of 14
Thread: 530 to 540 Suspension Compatibility
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Question... would 540 OEM suspension work in a 530? I looked up the part numbers on real oem and they are different but I am not sure why that is and what the difference is?
    E39 WhatsApp Chat Gruppe
    Apr 2015
    United States
    2003 540i6 M-Sport
    Different materials because of different steering boxes and subframe designs.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    The rears should be more or less the same in theory, but the front has a completely different suspension design due to the different steering boxes.
    1995 525i 5-speed - Thread
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    The sway bar links are definitely different, so the sway bar has to be different.
    Raleigh, NC
    SR-71 Blackbird
    Technically speaking the suspension would have remained the same between an I6 and a V8, but due to the stearing gearbox, they had to move the thrust control arm behind the front axle. The front sway bars are different too. Pretty much that's all the differences between the two suspensions. Everything in the rear is basically the same.
    Middle of a corn field
    E39 hamster/ruberbandPWR
    I can hear the 530i screaming...
    "Help, I am under the knife...!"
    I sure hope the 530i is not becoming a parts car...
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Even if the struts do fit (I've heard somewhere that they physically do, but never tried myself), they are designed for completely different weights of engine/subframes. Just putting M5 struts on a 540i will make the front end raise up and look like a 4x4, so I can only imagine on what it does to go from the I6 with aluminum subframe and R&P steering to V8 with steel subframe and recirculating ball steering box. I also know that the strut mounts on top have much different heights and different designs. The I6 has a much shorter mount if I recall than the 540i. I can tell you that you're way better off just getting new suspension that is properly sized/damped for the car.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    Oregon/Ukraine
    Quote Originally Posted by Jason5driver View Post
    Unfortunately it has in some aspects, like checking part functionality to rule out needing to buy other things. My plan was to put lowering springs on the 530 and the coilovers on the 540 but I don't have the stock suspension. If the rear stuts will work then that's great, I'll just need front 530 struts.
    Albany, OR
    2003 540i/6 M-Sport
    Quote Originally Posted by blackknight530i View Post
    I question this as the 540i M-Sport and the M5 have the same struts.
    2003 BMW 540i M-Sport: 6-speed swap, BC Racing Coilovers, DUDMD Tune, M60 Intake Manifold, Custom Exhaust, Polished M-Pars,
    Technical Graphite Trim w/ cupholder delete, E46 M3 tri-color stitched steering wheel,
    Dyno'd @ 253whp/291wtq (dynojet) before intake manifold swap
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by bE34ST View Post
    I'm pretty sure that's not correct, but even if the struts are the same, the springs definitely aren't. People have been misinformed if they are told they are the same, because several people have put M5 front suspension on 540is and found the front end to rise up about 1" or so.
    Ok, so strut does seem to be the same, but like I said, the springs are not, which is why the front rises when running M5 springs on 540is.
    -Paul
    Quote Originally Posted by RuskiE39 View Post
    Do the BC's have their own strut/ shock mounts?
    I should be able to use the BC's on the 540i.
    You just need the OEM 540i front strut bearings and washers.
    Nov 2010
    Charlotte, NC
    He would likely still want to get correct springs for a 540i. I think they are the same coilover though, just different spring rate and upper mounts.
    -Paul
    Albany, OR
    2003 540i/6 M-Sport
    I have M5 lowering springs on my 540 and they sit just as they should. Interesting, I've never even thought about that.
    Nov 2010
    Charlotte, NC
    I found your post in a discussion specifically about this that mentioned the springs up front were different, but struts were the same.
    Sent from my SM-N910V using Tapatalk
    -Paul
  1. The 530 to 540 thread (M60B30 to M60B40)
    By Aradaiel in forum 1988 - 1996 (E34)
    Last Post: 02-19-2013, 01:41 AM
  2. 530 to 540 swap new computer or just new chip?
    By 94530inh in forum 1988 - 1996 (E34)
    Last Post: 07-29-2008, 09:12 PM
  3. Need help. what to buy a 530 or 540
    By yonkers10566 in forum 1996 - 2003 (E39)
    Last Post: 05-14-2007, 02:28 AM
  4. 530 or 540 compare to 325, 330?
    By jjlee in forum 1988 - 1996 (E34)
    Last Post: 05-23-2005, 11:55 PM
  5. Upgrade E39 540 suspension to Sport or M5?
    By 540guy in forum 1988 - 1996 (E34)
    Last Post: 11-11-2004, 08:51 PM
