Results 1 to 17 of 17
Thread: EWS III bypass or trickery.
    Apr 2013
    Chicago Burbs
    e39 m5, 72 duster
    I have read threads on this and I still have not figured it out so I am going to ask for some help here. It is hard because I think most e39's have an earlier EWS that has a simple input from the ignition switch for start and then an output wire and you can just connect them to bypass. I have a wire that gets 12v all the time the black wire which I think is the output to the starter relay, and then a bunch of small wires. I know one wire goes to the DME and then one normally goes to the trans module or some sort of shift position switch but I think in my case it goes to my clutch switch. The rest I am not sure yet. I have not looked into it much because not one of these wires gets 12v when you hit the start position which is why I cannot figure this out. Most of what I have read has been on e46 forums and it seems like they are saying the ignition switch has a black/brown wire that goes to the DME and gives it some sort of signal and then the DME gives a rolling code to the EWS. Maybe on the CAN BUS network, I am not sure. I also read on e46 fanatics that it is easy to bypass! You just connect pins 1 and 2 together! But it does not say if they need to be cut so they no longer enter the module or if they need to be connected together and stay in tact everywhere else, what color they are, and the connector is not numbered either so I do not know. I cannot find what I am looking for on the WDS either. So does anyone know if that is correct about pins 1 and 2 and if so which wires are they and how does it need to be done? If that is not correct can someone explain on this system works? I would love to keep the EWS working for everything but I am at the point where if the body stuff still works I am fine with bypassing for the starter. Here are some pics of my EWS and the connector that goes to it and thank you for any help you can give. -Joe
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Will move it to the E39 section
    Apr 2013
    Chicago Burbs
    e39 m5, 72 duster
    Well from what I understand most e39's are EWSII so I may get more help in the e46 section but this is a problem directly related to an engine conversion too...
    Jan 2005
    Japan
    o.k., then I will move it back to engine conversion
    Feb 2017
    Los Angeles
    Bmw 735i
    Need help please see image E32
    Hey shogun having problem with my e32 changed oil pan gasket and time cover gasket upper/lower. New tie rods and control arm bushings and motor mounts. Unfortunately my car still has a leak and now my alignment is off pretty bad the tires are slightly inward and makind a screeching sound I'm guessing due to the tied rod work. Alignment place is suggesting I get new control arms before alignment.... does this sound normal and what's can yhe leak be. See image
    Need help bad anyone there
    Apr 2013
    Chicago Burbs
    e39 m5, 72 duster
    The leak can be a lot of other things including a front or rear main seal. Always start up high and work your way down. BMW valve cover gaskets are notoriously leaky and will get all the way down to the pan. Control arms would be a good idea, they are probably right.
    Somewhere, USA
    2000 “560i”
    PM sent.
    S.F.
    Feb 2017
    Los Angeles
    Bmw 735i
    ThAnks just ordered the parts from pelican online. When I changed the oil pan gasket I changed timing cover gasket and cam seal. Valve cover not leaking. So that Takes out those gaskets. So thats leaves which seal ?? Rear?
    Apr 2013
    Chicago Burbs
    e39 m5, 72 duster
    Okay, just so this is searchable: My EWS was all enabled because it sends a signal to the DME via a purple black wire and gets nothing from the dme to the EWS so the DME being gone does not matter. The red wire into the EWS gets key on 12V, when the EWS says the right key is in and all systems are go it gives power to the black wire which is the source power for the starter relay. The starter relay ground trigger(yellow brown I think), a 12v start signal from the ignition barrel (black yellow on the mss52DME for the M5), and then that black violet wire from the EWS for the everything is okay signal. When it gets word from the EWS that everything is okay, the next time you hit the start signal with the key it will ground the starter relay and let it rip. So I added a relay to change that positive 12v signal to a ground for that triggers the factory relay and boom problem solved with a ews that still functions like stock. I think I am going to take it a step further and take the "everything is okay signal" and wire that to the ECU relay for added security in a way that won't be published so even if you hotwire the EWS wires it still will not start.
    Somewhere, USA
    2000 “560i”
    Quote Originally Posted by get dustd View Post
    Glad to hear you have it figured out!
    S.F.
    Apr 2013
    Chicago Burbs
    e39 m5, 72 duster
    Thanks, the e46 guys have a similar situation with a black brown wire instead of black yellow just for reference. This information does not seem to be out there. The EWS I and II are easy but III might have only been in M5's and later model stuff.
    Philadelphia, PA
    2005 M3 & 2004 330i
    What exactly are you trying to do?
    Bypassing the clutch switch part can be done with relatively simple wiring (though it's even easier to just disable it in software). Bypassing the engine immobilizer part can't be done with just wiring - the DME software has to be modified. Without the DME modification, even if the starter engages, the engine won't start (fuel and/or spark are cut depending on the exact car we're talking about). In the case of the E39 M5 (assuming that's the car you're talking about), it's just a 1 byte change to bypass that lockout. Would take all of 5 minutes to flash.
    MS43 (525i, 530i) is pretty easy too.
    Oct 2008
    West coast
    '00 540 6.0/4L80e/S480
    Quote Originally Posted by TerraPhantm View Post
    Good info, but I believe he has an LS swap going on an M5. I have to assume that means he M5 DME no longer exists.
    Aug 2018
    Bend,Oregon
    bmw 325xi, bmw 540i
    picture diagram
    can you please upload a picture or diagram
    Aug 2018
    Bend,Oregon
    bmw 325xi, bmw 540i
    picture of the relay you installed please
    please share a picture of how this looks hooked up
    May 2019
    Dalton
    323i2000 2002 325i
    Pictures pleas on how u did the install
    Aug 2022
    Columbus, Ohio, USA
    04BMW 525i & 03BMW 325i
    Help my headache is surmounting into a bomb
    [QUOTE=TerraPhantm;29627744]What exactly are you trying to do?
    MS43 (525i, 530i) is pretty easy too.[/QUOTE
    Ok so then my question is where do I need to change that byte information so that the vehicle gets it's fuel and spark? I have an 03 325i that once had a key issue then I found Amazon and the key programmer and a new key that I with tons of headaches learned how to properly program it ... Then two years later here we are again however it started as a starter going bad then it sizzled of course and that was replaced well while the car sat for a few months due to some medical issues and I had my 525i for backup the battery went dead and the car satbdormant for some time causing the key to "disassociate" itself from the car ... Well I no longer have my key programmer as I lost it in a storage unit sale! I do however have the tunerpro and and MS4x Flasher and went and done an ews bypass and checksum correction and such all done on a bench setup and in the car through OBD2.
    AFTER DOING THAT go figure I now have no spark or fuel but I have starter turning over!
    Now I have the two bigger black wires jumped in the socket and the ews module unplugged ... Hopefully that's correct or do I leave the module in? Because the module when installed gives me a wrong rolling code with crank and without installed all codes cleared I get just crank obviously no rolling code issue. I'm ready to send her to the scrap heap as it's been down 7 months dealing with this little issue but lI ove my little 325 as everyone comments on it's great engine sound and beautiful exterior coloring and such she's just really pissing me off so if you know the bytecode I need to change in MS4x-flasher or tuner pro or in my hex editor or what have ya even bmw scanner never locking or in inpa or yeah I have all the softwares and such plus I've now ordered an eeprom chip clip with USB chwhatever the rest is lol to go direct into the chip if i must as i saved all of my bins for ews from when i programmed the key before
  1. EWS 3.3 bypass or delete, can it be done?
    By ross1 in forum 1995 - 2001 (E38)
    Last Post: 11-05-2014, 09:12 PM
  2. EWS II Bypass
    By twacker in forum 1992 - 1999 M3 (E36)
    Last Post: 02-09-2005, 05:02 PM
  3. ACS type III's or Hamann HM2's?
    By one in forum BMW Rides & Events
    Last Post: 12-18-2004, 09:31 AM
  4. WANTED ACS rims III 18 or 19
    By fso in forum Wheels and Tires
    Last Post: 08-06-2004, 11:35 AM
  5. WTB: AC Schnitzer Type III 18s or 19s w/ or w/o tires........
    By Slvr328IS in forum Wheels and Tires
    Last Post: 01-08-2003, 03:34 AM
