Results 1 to 5 of 5
Thread: N63 Owners - When did your oil consumption issues start?
    Edmonton, Canada
    2012 550i x drive
    Did most people with issues have then right away or can it happen at any time? For those who fixed it, was it the guides? I am good at 40k miles on my 2012, or at least the instrument panel guage said right full, 10k miles after the last change. Of course the guage might be looking for 8.5qts so it could read full even it had burned one off. Either way this seems to be a lot better than some are experiencing. I am just curious to know if the typical oil burning tends to start at a particular time.
    LOL at BMW saying 2.5qts is normal because the car is a turbo.I have owned a bunch of FI vehicles, only one which ran stock boost, and none of them burned a quart in between oil changes.
    Edmonton, Canada
    2012 550i x drive
    55k miles now and no oil use. I know its not that much, but with all the N63 grenade info out there it is reassuring that 550i doesn't = doomed. Runs like a champ although the injectors are the noisiest I have ever owned.
    Dec 2010
    eastvale, ca, usa
    '08 E92/'07 E90/'99 E36
    Check your turbo oil lines...most probable culprit.
    Sent from my aPhone using Tapatalk
    Edmonton, Canada
    2012 550i x drive
    Quote Originally Posted by WIN3Srz View Post
    What would I be looking for? Like vibrating against the turbo or engine components or the line itself being crimped or restricted?
    Dec 2010
    eastvale, ca, usa
    Quote Originally Posted by nuck View Post
    My boss's 550i required a quart refill once a month until the dealer replaced the turbo line, which solved his oil consumption problem.
  1. E39 Straight 6 guys. When did your oil leaks start? Where?
    By ilandbetter in forum 1996 - 2003 (E39)
    Last Post: 03-21-2010, 11:04 PM
  2. So, when did your alternator go out on you?
    By D Unit in forum 1992 - 1999 M3 (E36)
    Last Post: 10-22-2007, 02:26 PM
  3. When did your right rear bearing fail, and was it first?
    By bigbilly in forum 1991 - 1999 (E36)
    Last Post: 06-22-2007, 06:31 PM
  4. 530i Oil Consumption Issue
    By tobyport in forum 1996 - 2003 (E39)
    Last Post: 04-25-2007, 09:21 PM
  5. If/ when did your catalytic converter die on you?
    By ponq in forum 1991 - 1999 (E36)
    Last Post: 12-02-2003, 07:39 PM
