I picked up a 6speed swapped e38 2 years ago. now it's time to go through emissions but the car won't pass as i thinks it has been reflashed but the gear selector was still hooked up? I just need to pass emissions. I don't need Cruise reverse lights etc . If someone in the New England or east coast can help me get through this that would be excellent . I've seen the posts about jumping things etc .. would rather just have someone do the work . Thanks in advance . Ben
moved to E38 forum
If it's been flashed properly gear selector wouldn't be in place or connected or jumped to make the car believe it's in N or P
You may want to go thru flashing and coding sequence yourself from the beginning as if you did the swap, that way you will make sure everything is properly coded/flashed/whatever.
Also if it wasn't flashed correctly, that means it might be running on old wiring configuration, ignition specifically. You will want to check rewiring EWS and ignition in order to work with 540i dme flash.
So the Check Engine light is on? Sounds like just the "wire twist" was done. To get the SES light out to proper wire changes will need to be made and a DME flash will have to be done.
You could check with your inspection station to see if they will pass it because its a transmission code instead of an emissions code.
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
Does anyone know someone in or close to Norwalk CT that does programming and coding? I'm sort of in the same boat..
If it's just coding needed you should be able to do it remotely...
Hartford is an hour from me. I need to get rid of the heater circuit malfuntion codes that are producing the CEL.
Sent from my VS990 using Tapatalk
I'm in the market for a laptop and some BMW software. I don't like depending on people.
nope.
Thanks.
Sent from my iPhone using Tapatalk Pro
Matthew M.
North Carolina, USA
1997 840Ci | 2001 740iL | 1985 308GTSi Quattrovalvole
np just do a quick search on eBay. he may not be selling them atm but idk
heres a similar one , i literally just searched " laptop with bmw software "
http://www.ebay.com/itm/BMW-Laptop-T...MAAOSwnHZYfS0S
Thanks for the link. That looks like a nice deal.
Matthew M.
North Carolina, USA
Thats a great deal.
I can code, but I'm about 15 min south of hartford, so quite a ways from Norwalk.
OP did you buy Derek's blue E38 manual swap? I coded that thing. I thought all was good?
that thing is for sale right now btw
https://newlondon.craigslist.org/cto/5990801038.html
haha 7k? good luck.
You guys make me laugh. An hour drive? That's like going down the street for us westerners, even in LA. Sitting in LA traffic for an hour is normal here. I drive 1.5 hours to work if I have to go in morning traffic. Just drive...
I think if you connect RI and CT together they're still smaller than all of the LA/San Diego metro area.
