Yes it's on. What kind of circuit testing would you suggest? I would definitely give it a shot.
Abel, I found one from the local CL parts junky for 40 bucks. Does it matter what letter is printed on it or if it comes from a manual or automatic? He has quite a few them so I'll have a choice.
~Mike
It doesn't matter. But everything will be easier if it comes out of a 328. Auto or manual. The internal flash was written for both auto and manual. You would align ews, clear adaptations, clear codes. Done.
I will take the cover off the bad dme today to look at it a little.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
I'd sure like to figure out exactly how rubbing those wires together managed to ignite a cylinder. It seems to me that would have to mean the coil wiring and the cam sensor wiring are both melted down somewhere deeper in the harness? Which would bring us to Greg's suggestion of testing the wiring. Otherwise, might not the problems recur with the new DMEs, on both cars?
Chris Powell
BMWCCA 274412
It was explained to me as it happening inside the DME circuitry. Of course I'd like to know more too. It has happened before to Dave Markert too. Which is why it led to such a quick diagnosis.
No blown fuses, no anything else.
-Abel
ok, so, i just got a look at the wiring near the connector where you pulled back the cover. wow! (i was looking previously on my phone and it didn't show the detail as well). i think i can even see corrosion on the wire strands themselves.
as to the circuit testing - i was just thinking basic power/continuity tests to verify the integrity of the harness just so you don't have a melted spot someplace along the way....
abel or chris - with the DME unplugged from power, would it be worth checking resistance on the appropriate pins? i'm just wondering if that would allow a confirmation that the driver failed....
I still have the bad DME,... (gave them a good one... some trade). I can run minor tests. I pulled the covers and there was no apparent visible damage for a few minutes of looking at it.
-Abel
ahh, understood - mostly just curious if we can find any kind of 'smoking gun.'
Certainly, all the smoke has been let out of the system...
Chris Powell
BMWCCA 274412
And congrats on hitting your 1000th post!
Chris Powell
BMWCCA 274412
Man I really wanted this to be this easy.... Turns out, its not. I picked up a DME and Abel walked me through the EWS sync. I still have the same exact problem.
Now what?
~Mike
Like I said in the email, I'm VERY curious to find out. Can't believe there's more to this. Mine was fixed with the DME. Wonder if there are more harness issues.
Mr. Shadowpuck your microphone is loud and clear.
-Abel
Looking for a diagram of an m52 harness so I can see what pins to check for continuity........
otherwise internal engine components??
~Mike
I have three wires. I should have 5 volts going to the sensor. So if I test the 3 wires, and find the two power wires, that would leave one left which should be the signal wire. I could then test continuity from that wire back to the DME. I found a chart that says it could be pin number 43. Am I on the right track here guys?
~Mike
Going over a diagram (thanks Abel) I found my wires that needed to be checked. Last night I didn't really have any time to work on it, but I did manage to disconnect the plug and pull it up through the manifold so I could get a multimeter to it. I didn't have time to test continuity, but I tested for voltage and visually checked the harness. I found two of the three terminals producing 2.5 volts. That's all I got. When I would test the other terminal, I could hear a relay clicking? I wasn't putting any power to anything, just checking two wires for power. That part seemed weird to me. Anyway, today after work I should be able to test all the way to the DME harness.
I keep reading generic machanic web pages about this code and most all of them say a bad crank sensor can cause this. They also all say check the wiring before replacing the sensor. I think after I confirm the wiring is good, I'm going to replace the crank sensor......
~Mike
I tested for continuity to the DME and all was fine. I put my old DME back in.
~Mike
And any difference?
-Abel
Continuity won't account for any other shorts, unless you crosscheck continuity across different pins. If it's still a short.
-Abel
I checked across all of them. There is definitely no shorts in the wires from the connection to the DME plug. I checked the other 2 pins after confirming the one had continuity, to make sure two of the three wires were not shorted.
~Mike
Hi Mike,
Let me just double check; I see that the factory ETM's pin out has an error anyway. (It shows two wires as being inputs to the DME from the cam sensor)
You tested pin 64 of the DME plug (black wire) to pin 2 of the cam sensor plug?
You tested pin 43 of the DME plug (brown) to pin 3?
And pin 65 (Yellow) to pin 1?
(Just to make sure we're on the same page)
http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
Did you do the voltage test with key on, engine off, DME grounded, cam sensor not plugged in? If so, try plugging in the cam sensor, and then backprobe the wires for voltage.
And what have you done about those melted wires? I'd find it hard to believe that all the damage to those wires was confined to the area outside the shield, since the damage was SO complete there.
Chris
Chris Powell
BMWCCA 274412
Ok. Took a min to eat breakfast
With the cam sensor plugged in, I get no voltage with the key in position 2. If I unplug the sensor, the voltage goes back to 2.5 volts.
~Mike
