I cleaned mine at self car wash, I jacked the car up on one side and power washed the underside, it works well that way
Instagram.com/nordmanmg
Your current situation is not your final destination
E39 WhatsApp Chat Gruppe
Never had any problem with any of my cars by washing my engine either way
Nice. I use citrus degreaser as much as I can and then save some brake cleaner for the "nuke option" for which I wear a mask and try to minimize. But dayum it does just dissolve everything easily, even if its nasty harsh and bad for the enviromentz.
Your car doesn't even look too bad for an M62. I put off my upper timing cover gaskets for so long mine was a horrible sludgefest when i finally got to it. Completely awful.
Yeah the car washes around here are all "NO BUCKET WASHING!!! NO ANYTHING EXCEPT GIVE US MONEY AND GTFO!!! QUICKLY!!!!" Can't imagine what they'd say if you pulled out a jack and started a project like that. Maybe during off hours when nobody is there but they all have cameras now, I wouldn't put it past some of them to come down and yell at you anyway even if it was 10PM and there wasn't another customer in sight.
Agreed. You'll always hear "NEVER PRESSURE WASH YOUR ENGINE!" but I have my own lightweight pressure washer, and as long as you're not just totally completely stupid about it, never seems to be an issue for me. I mean if you WERE stupid about it and shoved the nozzle right into the electrical bits or other more fragile bits, sure, you could fork stuff up good, but as long as you intelligently keep a distance from those things, I find you can get up close and personal on some the worst hard parts (ex: nooks and crannies of oil pan and PS pump...) with zero issues...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
The self car washes around here have a button for 'engine wash', I like the idea of doing it from underneath, sort of like a reach around, lol.
I usually go there, swipe the card, rinse engine with those green stuff, put washer away and then jack the car with factory jack, spin steering wheel to the jacked side, and wash it from top, then bottom, then if needed doing the same on the other side. It not that long of a wash time wise too
Usually I try to avoid all electrical connectors, I wash them but quickly, and then engine bay All around
Ugh there was so much caked on sludge near the oil pan I literally used a flat head to just scrape it out. I also definitely have a upper timing cover leak, can see very faint oil drops leaking down the side of the just cleaned metal frame
I'll need to tackle that and anything else that shows signs of leakage because I'm loving this 540 more and more... I've already cannibalized the shift knob, steering wheel is next and I don't know how long i can wait before taking the coilovers from the 530.
UPDATE:
Super easy swap, and everything is plug n play, no modification required. 01 540 sport wheel (dual stage) fits into 02 face lift 530 (dual stage) and vice versa. You only have to worry about production year march 99 single stage air bag wheels. No airbag lights or anything, just MAKE SURE you disconnect the battery before you d/c the airbag.
Before:
After:
(no the car is not slower with a 5 speed ZHP shift knob)
And on a separate note, not a drop of power steering fluid under the car (or oil), this morning. I am excited to be a contributing member of society.
#GreenPlanet
#HugaTree
#ItWasTheCarBeforeMe
I have the round sport steering with bag that I still need to swap into my car.
The round sport wheel and bag have been laying in my garage for quite a while now, I just don't know how to install it.
Ughhhhhh... went to go into town and about a block down the road the car just died on me... I turned it back over and turned right and it died AGAIN.... the only way I could keep it alive was by giving it gas... it seems to surge low into the 200 RPM's and then spikes to about 1400 RPM. I thought it might be the battery so I swapped the battery from the 530 and it's still doing the same thing but now that it's warmed up its not dying, just surging a tad. Any ideas? IACV?
Yours does not have ICV since it's a tu. Check your intake tube for a vacuum leak.
Had the same problem with my car last winter. Some how oil had gotten on the MAF which caused me to stall out. I cleaned it off with MAF cleaner and all has been fine since.
If that doesn't fix it, you probably need a new MAF or have a vacuum leak somewhere.
I would scan codes to check as well.
I'd try and swap in a known working MAF to see if that's the issue. Otherwise it could be a pretty big vacuum leak somewhere in the intake manifold. The intake manifold gaskets are known to cause similar issues once they stop sealing properly. My Range Rover had that issue with its M62tu— on cold mornings the idle was a little unsteady and it would go away once warmed up.
1995 525i 5-speed - Thread
Just found this... going to clean the MAF as preventative.
Actually, now that I think about it, my 2000 540it idled kinda badly when I first bought it— it actually stalled a few times at red lights. I bought a brand new Bosch MAF and that solved my problem completely. At this point I just buy a new MAF every time I buy an M62tu-powered vehicle. MAFs aren's super expensive so it's worth it IMO.
Yeah, disconnecting the MAF is a good way to see if it's actually working or not. I remember my 1995 750il ran super rough so I disconnected each MAF (it had two) until I found the one that wasn't doing anything. Once I found the dead one I replaced it and the engine ran perfectly.
Awesome, thanks! It seems to be running much smoother after spraying down the MAF and fixing that little rubber Gasket. It was literally folded over itself.
I saw something kinda nice in a post here but I can't remember where right now where the member with his car on the lift tented or hung a tarp loosely under the car with bungees. The tarp slanted to the rear or maybe out of the door - that way he could spray the undercarriage down and then wash, even pressure wash with the drainage directed to the door or where ever. I could definitely do this at my garage to was the undercarriage.
But I like clean as well....
Found the tenting.....
http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
"The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
