Page 11 of 11 FirstFirst ... 234567891011
Results 251 to 268 of 268
Thread: Ruskie Has Joined HO8
  1. #251
    Raleigh, NC
    SR-71 Blackbird
    How did you get to the electric fan fuse from outside the car??? It's right behind the glove box.
  2. #252
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Quote Originally Posted by auaq View Post
    Most people said to lie down, upside down and you can pull it out but there was no way I could get my long scrawny arms inside there to grip it so i just got just outside the passenger door so i could reach one hand in there and pull it out with my fingers.
    E39 WhatsApp Chat Gruppe
  3. #253
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Yep, it don't compute. The fans fuse is a 50amp fuse next to a 40amp fuse, in a holder behind the plastic relay box, behind the glove box, under the dash, inside the car.
  4. #254
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Really long arms?
  5. #255
    Jul 2016
    Chicago, Illinois
    are slow
    2002+ is a bit different, the twin fuse holders face upwards. Pry at them with a flathead screwdriver and reinsert at an angle, takes about 1 minute total.
  6. #256
    Oregon/Ukraine
    Quote Originally Posted by XAlt View Post
    Yes, exactly. Its not hard if you are in the correct position.
  7. #257
    Albany, OR
    2003 540i/6 M-Sport
    Quote Originally Posted by RuskiE39 View Post
    That's what she said.
    2003 BMW 540i M-Sport: 6-speed swap, BC Racing Coilovers, DUDMD Tune, M60 Intake Manifold, Custom Exhaust, Polished M-Pars,
    Technical Graphite Trim w/ cupholder delete, E46 M3 tri-color stitched steering wheel,
    Dyno'd @ 253whp/291wtq (dynojet) before intake manifold swap
  8. #258
    Oregon/Ukraine
    Quote Originally Posted by bE34ST View Post
    Cool signature specs, bruh.
  9. #259
    Raleigh, NC
    SR-71 Blackbird
    Pretty sure even the 2000's have the twin fuses in the same manner. My electric fan in my 2001 M5 (09/2000) had a blown motor. The fuse is right behind the glove box just like in the 02-03 models. Both 40/50A fuse facing upwards and hard to reach. Before I sold my 2003 530i I swapped out the elctric fan into my M5 and popped in another fuse, and it's been working great ever since. Definitely sounds like you've got a blown motor. A brand new OEM fan is going to cost you around $400 or so. If possible I would try and get a used one either from online or from a local junk yard (50/50 chance it might actually work just fine).
  10. #260
    Oregon/Ukraine
    Yeah, that's what i'm saying.. if you find the sweet spot the fuse is really easy to get out, i'm jus saying I could not access it lying down upside down on the floor. But anyways, that is what I plan on doing, finding a junkyard fan or something used. This isn't a crucial component that will cause harm to the engine, i've been running this car without an electric fan just fine for the past few months. Thanks again for the input!
    Oh and by the way, I did test the fan by d/c'ing the fan and popping in the fuse, all worked fine, no overheating or strange smells. Just need to source a fan now.
  11. #261
    Jul 2016
    Chicago, Illinois
    are slow
    "But muh AC system damage." I've idled with the A\C on for 30+ minutes no problem without the aux fan.
  12. #262
    Oregon/Ukraine
    Haha, i've used AC maybe 3 times so far this summer. I'm more of a windows down kind of guy.
  13. #263
    Raleigh, NC
    SR-71 Blackbird
    As long as you're moving and there is a constant airflow to the condenser then your a/c will be working fine. Only in stop and go traffic with ambient temps exceeding 95+ C then your a/c high side pressures are going to escalate and will eventually halt the operation of your compressor. You may also experience rising engine temps too, so be aware of that.
  14. #264
    Jul 2016
    Chicago, Illinois
    are slow
    Herro?
  15. #265
    Raleigh, NC
    SR-71 Blackbird
    *95f
  16. #266
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    How people lived back in the days without AC's?! Lol
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  17. #267
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by NordmanMg View Post
    I have no idea. I drove all day today in temps ranging from 60 to 105 F, and I was at a chill 68F the whole time. Lovely.
    BMW fans are expensive because they are built with a PWM module controlling the motor. Aftermarket PWM modules are still unreliable and expensive (annoyingly); like $150. Add in the E39-specific fan housing and the fan motor, and BMW likes to charge big bucks for their fans. I'd recommend going with an OE supplier like Behr.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  18. #268
    Jan 2015
    Tempe, AZ
    1995 525i/5
    For what it's worth, I got an E39 Behr aux fan from Rock Auto for $180 last year.
    1995 525i 5-speed - Thread
  1. The 2002 has joined the PBMW club
    By Villanuevas_BMW in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-20-2006, 02:29 AM
  2. New car has joined my stable
    By 99bmw740il in forum 1995 - 2001 (E38)
    Last Post: 11-22-2004, 05:48 PM
  3. AutoVisuals' AutoSharp Pen has joined the party... Any member reviews yet?
    By MDabney in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 04-28-2003, 11:58 AM
