Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
Thread: HPDE Brake Pads
  1. #26
    Atlanta, GA
    1999 m3 and 740iL
    Wow, just went to the fcpeuro site and it's true. Gonna grab some rotors and pads as well.
  2. #27
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Quote Originally Posted by 5speed300 View Post
    Try and beat me to it!
  3. #28
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    I dunno man, i think you're taking advantage just a bit there. Keep that up and they'll end the policy.
  4. #29
    Springfield, IL
    Quote Originally Posted by TXBDan View Post
    It strangely says in their policy about track car use? Might be good for business since I am certain to only use FCP for all MY parts if that is the case!
  5. #30
    Nov 2005
    MA
    https://www.fcpeuro.com/page/lifetime-guarantee
    Well shit. It even says brake pads used on track. That's insane.
    Too bad they don't sell tires! (like mentioned in their FAQ)
  6. #31
    Springfield, IL
    I know. Blows my mind and changes the game!
  7. #32
    New England
    E36 M, E32 740i/6, 997 S
    The reality is that so few people are ever going to come looking for replacement parts that I'm sure it works out fine for them. I can't imagine I will ever have to replace most of the parts I've purchased from them for the remainder of my ownership. I can see them excluding certain parts from the policy in the future though.
  8. #33
    Apr 2002
    Broomfield, Colorado
    Thanks for that - I buy from FCP all the time - better get a set of DTC-70s before they change their minds!
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
  9. #34
    Springfield, IL
    Quote Originally Posted by CoMZ302 View Post
    Think it was only dtc60s.... i better check again.
  10. #35
    Aug 2014
    United States
    Estoril M3/4/5
    So for about $750 I can have
    -brembo blanks x4
    -dtc-60 f&r
    -redline 5w40 engine oil
    replaced for life?
    waaaat? im pissed i didnt know sooner!
  11. #36
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    The FCP replacements do sound pretty sweet, but you do have to consider the fact that you have to remove the pads/rotors to send them back to FCP and wait for replacements. Unless you do something weird and buy two sets of everything...and swap them back and forth...or something...
  12. #37
    LV, USA
    335i
    anyone looking, I have a set of E36 M3 R4 pads for sale, $120 shipped, brand new in the box
  13. #38
    Nov 2005
    MA
    PFC08s are continuing to not cut it. It was about 85F and sunny this past weekend and i could only get 4-5 laps before they'd fade and i have have to dial it back for a lap. 2-3 times a session i'd blow a turn because they failed to stop. I think i need to either add some ducting or switch back to Hawk DTC-60s. I do like the feel of the PFC08s and i also kind of like their better modulation and lesser initial bite. I think it forces me to carry more speed through turns. ha. I'm going to look into ducting i think.
  14. #39
    Apr 2013
    Alabama
    1995 M3 Coupe
    That's crazy, I've never had issues with fade out of the 08's, hell the more heat you get in them the harder they brake...for me at least. The only issue I ever had was using them too much and not hard enough and would leave some deposits on the rotors. No ducting on mine, did get rid of the stock rotor backing plates if that makes a difference.
    1995 M3...Screwed
  15. #40
    Nov 2005
    MA
    That is weird. I also don't have stock backing plates. I can't find a ton of info/complaints about fade with them. I don't know what else to think though. Pedal stays firm, no ABS engagement. No issues with deposits or vibrations. Rotors looks good, smooth. Its as if i had grease on the rotors or something, just way reduced braking friction/force. Never had the issue with the Hawks. The issue happens running NT01s which i also ran with the Hawks without issue. Also of course happens on R1-Ss, but i never ran them with the Hawks.
    If i back off for just a couple braking zones/turns, they come right back.
  16. #41
    Nov 2014
    Atlanta
    1996 BMW M3/2/5
    You mention no ABS engagement, how is that a product of the pad? Isn't more related to the driver?
  17. #42
    Nov 2005
    MA
    Quote Originally Posted by mindspin311 View Post
    Its a product of no braking force!
  18. #43
    Springfield, IL
    I must say if it was me, i would sell them and buy another set of dtc's. This is counter from all my experiences with PFC product, but maybe you can threshold brake better than the rest of us!
    Cooling ducts blow if you like to turn more than 30 degrees off center. Just something else i have to check/maintain. Would also consider a paint pen to mark the calipers to check temp ranges you are hitting....
  19. #44
    Jun 2017
    4x4
    Pagid RS-4-4
  20. #45
    San Diego, CA
    98 M3, 03 540it M-Sport
    I use PFC Z Rated pads on my e36M and they do street/autocross/HPDE duties. Great performance for the price, no noise, middle of the road dust, great performance. Don't forget to bleed your brake fluid every year if you're doing these schools.
    '98 M3 5spd - '03 540it 6spd M-Sport
  21. #46
    Montreal
    2002, e30 M3, 535
    Quote Originally Posted by QtheGenius View Post
    I might even suggest before every event. ;-)
  22. #47
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Quote Originally Posted by Jab31169 View Post
    Smearing deposits on the rotors is a sign of overtemping the pad. Some pad compounds smear deposits more than others, but if it happens - definitely a sign you were right up on the upper upper end of the operating range or slightly beyond it.
  23. #48
    Apr 2013
    Alabama
    1995 M3 Coupe
    Quote Originally Posted by Def View Post
    Im sure I was, it was my first event in the car with those brakes and in the heavy braking zones I was using like 60% of the brakes from way out and then trying to apply another 30% as I got closer as opposed to getting in closer and using 95% of the brakes and getting back off them.
    1995 M3...Screwed
  24. #49
    Nov 2005
    MA
    bmw 330
    .....were replaced SS front lines, switch from type200 to SRF fluid,.....
    How often do you have to change the SRF brake fluid ?
  25. #50
    Nov 2005
    MA
    Quote Originally Posted by BryDog View Post
    This is my first year running it, but from what i gather, it should last all year. It has a very high wet boiling point so can deal with some moisture absorption. I have three weekends on it so far and nothing has changed pedal feel or performance wise.
  1. Couple Quick HPDE Brake Pad Questions
    By 2005 330iZHP in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-26-2015, 05:04 PM
  2. FS: E39 brake pads - perfect for HPDE!
    By SonOfWMB in forum Georgia sponsored by Harrison Motorsports
    Last Post: 02-19-2009, 01:09 PM
  3. Brake Pad Upgrade - 7th HPDE
    By M3Alpine99 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-05-2007, 03:32 AM
  4. Brake pad question for HPDE
    By e36IndyM3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-05-2007, 03:37 PM
  5. HPDE Brake Pads- SBS ProTrack or Satisfied GranSport 5 any good?
    By Fastech in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-08-2005, 10:21 PM
