1972 BMW 2002tii Race Car
1972 BMW 2002tii Spec Sheet
VIN 2761248 built to USA on March 23rd, 1972 delivered Aril 25th
Original Color was Inka paint code 022, inka metallic now
SCCA ?ITA? and BMWCCA ?K? prepared
Fabrication History
This vintage 2002tii has been a track vehicle for years after being professionally built in the early 80s. The car shows superb fabrication including a 6-point cage with gussets at bends, support footings at body contacts, cross-bracing, 360 welding evidence, and even the front control arms were professionally seam-welded. The interior was striped and painted Inka with no carpets, headliner, insulating tar, and other flammable materials. Recent SFI 45.1 safety padding on bars, fire bottle on the tunnel, window net, battery behind the passenger seat, tow hooks, dropped sub-frame, fuel cell, adjustable coil-overs with Konis, custom lower air dam with brake feeder ports. A clean, rust-free, well-built race car sitting on new Toyo Proxes RR all around. Over the years records were kept in a big binder.
Race History
This car was originally thought to have been built in the Southeast, then later campaigned by Haner Haus in Santa Rosa, California. Documents show an overall win in a 12 car field at Sears Point, in March of 2006. In August 19, 1996, Haner took 2nd in class and 6th overall in a field of 27 at Laguna Seca. In February of 1997, Haner took the race win at Sears Point. This car has set poles and the fastest lap in class at Sears Point, California. In 1998, Mark Ekstien bought the BMW to campaign in BMWCCA K-prepared races for a few years, then shipped it to Euro to run for a few years. When he came back he put under cover on it in his garage. I bought the car and readied it for the track in the spring of 2016.
Body/Exterior
? Rust free body (some body fill for race dings), de-chromed except for bumpers, windshield trim, driver?s window trim, rear accent trim, and rear emblem.
? Paint color is inka metallic - custom
? Vintage style black Vitaloni exterior side view mirrors
? Hella H4 European lightweight headlights
? Custom front air dam with twin brake ports and cooling hoses
? Delete gas filler side port (Race fuel cell with a pre-filter and large post filter)
? Mounted AMB direct wire transponder, lighted switch on the dash
? Fender lips rolled
? Race hood locking pins, rear glass jettison tabs
? Single driver?s windshield wiper
? Front and rear windows are safety tabbed down
Cockpit - Interior
? Bare painted metal interior except nice vinyl door cards and rear side cards, with original dash-less glovebox
? 6-point professionally fabricated roll cage, all new SFI 45.1 black padding
? Recaro one-piece racing seat with aluminum mounting brackets, mounted to the roll bar on an adjustable locking channel, pin locked
? Simpson 5 point restraints (older)
? Simpson window safety netting (older)
? Momo race steering wheel
? Momo weighted shift knob
? rear view - Wink 4 panel racing mirror
? 5 gauge custom VDO instrumentation: tach, water temp, oil pressure, exhaust temp, fuel level (no speedometer)
? Lightweight passenger seat and restraints (older)
? OMP ? oversize aluminum race pedals - clutch and brake
? tunnel-mounted fire extinguisher
? tunnel mounted brake bias valve with dry and wet settings set
? optima PC925MT battery marine box mounted in right rear foot well
? ATL 5 gallon fuel cell ? I think needs a bladder
Race Suspension
Front
? Adjustable front coil over suspension with race springs, Koni dampers on tii struts/spindles
? Custom adjustable front sway bar ? looks like IEs? (set at furthest setting with urethane bushings)
? Seam welded front lower control arms
? Wiechers-Sport front upper strut bar
? Custom adjustable camber and caster plates (make) Ride height, springs and camber/caster were a sorted. (Though, I believe the car needs rake adjustment.)
Rear
? tii rear boxed trailing arms
? tii cross member
? the rear sub frame mounts inverted to raise the sub frame by ? inch
List Date: 2/27/2017
For more info, click here to view the original listing: 1972 BMW 2002tii Race Car
This item is no longer available.
