Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 7 of 7
Thread: Recommended Tires for Apex ARC-8
    Nov 2015
    World
    '04 M3 and '06 MC ZCP
    Hello,
    I'm looking into getting a set of tires, but I don't know what size. I'm, without a doubt, getting the Michelin Pilot Sport 4s, but I don't know what tire size. The front are Apex ARC-8 ET35 19x8.5" and the rear are Apex ARC-8 ET33 19x9.5". Any recommended size that you'd use? Thank you.
    Sincerely,
    F 18 Hornet
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    235 to 255 front width, 255-275 rear width.
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Check out the link below for wheel fitment and spacing, it's a great, easy to understand guide.
    http://www.pelicanparts.com/techarti...el_Fitment.htm
    -Dmitry
    888.280.7799 | 6am - 5pm PST
    Aug 2013
    1999 BMW M3 Coupe
    Depending on the clearance on your particular car and the tire choice (some tires are wider than others), probably 245's in front and 265's in back.
    Nov 2015
    World
    Got it. Thank you.
    Quote Originally Posted by TostitoBandito View Post
    Thank you for the response. The car is stock minus the rims, intake, exhaust, and ECU flash (the suspension was changed to KSport but was set to the height of the suspension from when the car left the factory). The tires I'm planning are the Michelin Pilot Sport 4S.
    Jul 2006
    Pittsford, NY
    various
    match the diameter to whatever you have stock.
    If you increase diameter you will increase ride height, increase the chance of rub and decrease acceleration due to worse gearing.
    __________________________________________________
    Cars
    Jun 2005
    New England
    Yes, always look at tire diameter when changing widths. Tire Rack has specs. Try to maintain as close to original as possible and also as close a ratio as possible on any front to rear difference. If you go wider, you will need to drop aspect ratio.
  1. Recommended tire for SoCal driving?
    By maim3r in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-22-2009, 02:12 AM
  2. Recommendation Tires for my wife's 330ci
    By ph0ngvu in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-19-2007, 12:28 PM
  3. Recommend tires for '02 325Xi
    By BMW Newbie in forum 1999 - 2006 (E46)
    Last Post: 10-03-2006, 08:29 PM
  4. Recommend tires for my ZHP...
    By jorbon in forum 1999 - 2006 (E46)
    Last Post: 08-13-2006, 12:57 AM
  5. Largest size or recommendations (Tires for 325i)
    By ///M4life in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-09-2003, 12:48 AM
