Results 1 to 2 of 2
Thread: Barn find resurrection with brake problems!
    Feb 2017
    Roseville, CA
    1987 528e
    Hi Guys,
    New to this sight but not new to BMW's. I recently purchased a 1987 528e with 109K miles that has sat under a protective layer of dirt since 2009. Had to be rescued! FINALLY got it to start with new Motronic 1.0 brain, speed and reference sensors, new battery, new fuses, new relays, new OBC relay box, you get the idea. Starts but runs like crap so replacing fuel injectors after replacing fuel pump, filter, new inlet boot and hoses, timng belt, hoses, belts, etc. NOW, the brakes!!! Front brakes were seized so bought replacement rotors, pads, rebuilt calipers, brake lines. Went to bleed and got the "hard pedal" syndrome. Little fluid through the calipers but super hard pedal. Bought a pressure unit to bleed that way but still little fluid (milky) through the calipers. This is an ABS car so not sure if next steps are Master Cylinder replacement, ABS unit rebuild??? Looking for some help as I know this is not the first time this issue has come up. Have enjoyed reading and learning from this site.
    1987 528e (current project)
    2004 645ci (daily driver)
    2000 328i (Sons new car)
    2006 330ci (Daughters new car)
    2002 325ci (ex-wifes car)
    1987 325e (project in waiting)
    1984 735i (long gone but a great ride)
    1978 320is (the first)
    Jul 2016
    Chicago, Illinois
    are slow
    Most likely the master cylinder and bomb. If you push hard enough, can you get it to hit the floor?
    Anyways, disconnect the two abs wires leading up to the brakes, I doubt they'll be the issue.
    MyE28.com knows these cars the best, so I suggest you check them out for your project and for speedy responses.
  1. problems with brake light
    By Huma in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2006, 03:53 PM
  2. Please help me with my brake problem!
    By sawbones in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-16-2005, 08:09 PM
  3. problem with brake bedding
    By BmirOwnz in forum 1991 - 1999 (E36)
    Last Post: 04-03-2004, 01:26 AM
  4. Problems with brake dust!!! Stupid BMW's!!
    By Spubar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-23-2002, 09:09 PM
  5. please help with brake problem!!!!!!!
    By steve m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-06-2001, 04:07 PM
