Results 1 to 5 of 5
Thread: What do I need to flash F25
    The Plains
    MaxPsi M3
    I recently replaced the RDC antenna on my X3 and it needs to be encoded to work. I currently have ISTA+ and Esys with a ENET cable. However, ISTA + requires an ICOM cable to program the modules. I've played with ESYS and got it working, but I'm not sure if flashing the RDC will encode the antenna. Would I be able to encode it with ISTA P or will Esys be able to do it? Any input is appreciated, thanks.
    Jan 2016
    Ca
    2001 525it
    Find a shop that has what you need have them code it
    Jul 2004
    Houston, TX
    36 Cylinders
    You need to code, not flash, with Esys in order to code the module.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    The Plains
    MaxPsi M3
    Got it done finally. For anyone else in the same boat with a corroded antenna. The RDC antenna on the F25 X3 is just behind the rear passenger wheel. It takes about 5 seconds to disconnect the old one and replace it with a new one. Then it needs to be encoded. Using Esys: (derived from BMW-4-Life's directions on bimmerfest for another ecu)
    Once connected : -
    Expert Mode-Coding
    Read FA
    Activate FA
    Read SVT
    Select the 'RDC' ECU
    Detect CAFD for SWE
    Choose the CAFD you want
    Click Code
    So basically it's injecting a CAFD file into the module since there wasn't one before.
    Thanks for the help.
    Jan 2020
    NY
    2012 x3
    Great info sir !!! I'm needing to inject my VIN into a replacement DSC / ABS unit. Do you know which module it's in ?
    Many thanks, KB
  1. What do I need to do smth. like this?
    By Filip75 in forum Off-Topic
    Last Post: 09-04-2002, 02:20 PM
  2. What do I need to change my stock lever to an M3 lever?
    By Ben 93 325is in forum 1991 - 1999 (E36)
    Last Post: 07-21-2002, 12:23 AM
  3. what do I need to do a m3 motor swap in a 89 E34
    By RavinsE34 BMW in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-10-2001, 09:05 PM
  4. what do i need to mak my own cai?
    By Bmw Rollin' in forum 1991 - 1999 (E36)
    Last Post: 06-04-2001, 09:24 PM
  5. What do i need to get city lights?
    By 325iGuy in forum 1991 - 1999 (E36)
    Last Post: 05-24-2001, 11:53 PM
