Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
I've driven over 100 miles with the larger master cylinder in. It has had zero effect on the abs/dsc system.
Trevor
81 Delorean,B28F
-Paul
2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers, Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
So Z8 MC is bigger? I thought it is same size/capacity
Instagram.com/nordmanmg
Your current situation is not your final destination
Bore size(piston size, internal size) of the Z8 mc is 27mm instead of 25mm. The port thread on the Z8 is m12 instead of m10. That's what the adapter is for. Just so I didn't have to make a new flare on the hard line.
Trevor
81 Delorean,B28F
A quick question. Did you use 750 or 740 carriers for this?
I'm just getting a list of all the parts I want for mine.
Cheers
Jamie
Update: I didn’t know you can just click on this PB icon and it will lead you to the photos, lol
Hey Trevor, I was wondering if you still have all the pictures you posted here before?
If so, can you text them to me?
Let me know , thank you
OP, can you PM the pictures so I can repost it for everybody using my imageshack account?
"Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
Trevor
81 Delorean,B28F
Trevor
81 Delorean,B28F
I have no idea why the pics rotated during the upload. Just tilt your head.
The only problem I have, and I'm not sure of the source, The ECS aluminum hats do not center on the E38 hubs correctly. I'm not sure if the replacement bearings have a shorter center shoulder or the rotors just have a deep relief on the back of the hat. I can center the the disc with the taper wheel bolts then tighten the retaining screw.
The OE disks may fit just fine.
Trevor
81 Delorean,B28F
Trevor
81 Delorean,B28F
I learned something new today. There is a guy on Facebook and he put X5 e70 brake master cylinder/brake booster assembly on his E38, and the thing is - X5 MC have 27mm Front bore and 22mm rear.
Master Cylinder itself won’t fit E38 booster, but X5 brake booster is bolt-on to E38 firewall
http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
"The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
The e60 M5 is 27/22. I need to measure the e60 rear piston to see it's size compared to the stock size. If they are the same I think too much bias will be on the rear. If it's bigger then I might consider looking into the different booster.
Trevor
81 Delorean,B28F
Good morning, there is a discussion on Facebook in regard to brake upgrades for the E31 8 series and this E60 brake thread was mentioned. So I thought I would read through it because I am still looking for a rear brake upgrade for my '91 850i.
I just finished piecing together parts and upgrading the front brakes. I am using 4-pot Brembos, adapters, custom hoses I had made locally, and ECS Tuning E92 M3 360mm two-piece rotors.
I also had a leaking master cylinder and the E31 cylinder is not available so I used an E32 25mm vs 26mm on 850. It bolted right on and seems to work fine. So with this brake upgrade I reduced weight approximately 8 pounds per corner even though rotors are 36mm larger.
Brakes work extremely well now with maybe an inch of pedal travel if that much. I'm just using stock off-the-shelf Bosch pads.
I'm still interested in upgrading the rear brakes but I cannot seem to find any adapters available to use the large 4-pot Brembos and a rotor that will work with the emergency drum brakes. Ceika does have a kit if I cannot piece together one of my own.
