Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 75
Thread: E60 M5 front brakes
  1. #26
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    In case anyone was looking for a cheap set of front and rear e60 m5 brakes: http://www.m5board.com/vbulletin/sho...d.php?t=552337
    Sent from my SM-N910V using Tapatalk
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  2. #27
    UAE
    Merc R129, E31, Jag XKR
    Any negative driving behavior if you install fronts only?
    "Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
  3. #28
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by spitfire980 View Post
    I haven't been up in the mountains since but just around town and interstate ramps they are amazing. I brake hard into a corner and realize I'm losing too much speed to even get to the corner.
    The rears right now are 750's with OE pads, I can't wait till the e60's and Hawk pads are on. Hopefully this week.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
  4. #29
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Quote Originally Posted by 007008 View Post
    Careful, if your rears are to strong they will cause ABS to chime in and you will lose on stopping distance))
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  5. #30
    UAE
    Is there any booster/master cylinder difference between the V8 and the V12?
    I have a 750 so will pedal travel be any different from your 740?
  6. #31
    Greenville, SC
    01 749iM/6 sporty
    Realoem shows the same master cylinder for E39, E38, and E53.
    Trevor
    81 Delorean,B28F
  7. #32
    Greenville, SC
    01 749iM/6 sporty
    I've taken about 7mm off the brackets. They started at 19mm and are now just short of 12mm thick. 12mm is also the thickness of the ears on the hub, so it should be fine. I've gained a bit more rotor clearance by grinding the inside of the bracket.
    To deal with the bolt size I found some inserts, the bracket hole gets enlarged to a M16x2 thread and then the insert has m10x1.5 thread of the stock e38 bolt.
    Trevor
    81 Delorean,B28F
  8. #33
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Needs a prettier caliper with that Beaut of a rotor
    2000 740i Sport
  9. #34
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by cazal740i View Post
    Well, until I buy a mini mill and am able to fabricate caliper brackets I just have to live with these.
    Trevor
    81 Delorean,B28F
  10. #35
    Greenville, SC
    01 749iM/6 sporty
    And under the category of one thing leads to another, I guess I need a different master cylinder. I know the pedal travel is longer, but once you get use to it its not a big deal. I would like it to be as correct as possible.
    I found a site that lists bore sizes and the E38 has a 25.4 bore. E65 has a 26.99 and the E60 also has 26.99.
    Now looking at Realoem and google pics the E60 mc looks completely different to the e38. The e65 looks like and uses the same reservoir as the e38.
    There is a E60 and a E65 at my local pull a part. I'm gonna go get the E65 mc and compare it to the e39 m5 mc that I still have.
    On that part site it shows a second bore size, e38 20.6, e65 20.64 and e60 22.2. Not sure if that's the rear circuit or just a secondary. E60 and E65 share the same rear caliper so that bore size shouldn't matter.
    Trevor
    81 Delorean,B28F
  11. #36
    Sep 2014
    '01 DINAN7 '03 M5
    E38/39/60 they all have similar looking rear knuckles, I was wondering if E60 knuckle can be used on E38 control arms
    difference can be in arm length but with adjustable both upper arms it would work
  12. #37
    Greenville, SC
    01 749iM/6 sporty
    I took the e39 mc apart (same part as the e38) front bore is 25 and rear bore is 20. So, since the E60 M5 and the e60 545 use the same mc and the e60 545 and the e65 use the same rear caliper, putting a e65 mc on this set up should be the ticket. That is if the e65 mc mounts to the e38 booster. The pedal feel should be just fine. I'm guessing the e60 chassis has more rear bias built in.
    Or, just looked up a Z8. It uses the same booster as the e38 and on the site that list bores it shows to be a 26.99 and the z8 uses the same rear calipers are the e38 so the rear bore should be 20.
    A little more looking turned up the Z8 mc is indeed 27 and 20 and it is also the same mc used on Land Rovers
    Trevor
    81 Delorean,B28F
  13. #38
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Trevor- isn't there a proportioning/bias valve somewhere in the system for the rear. I have not looked for a while but there used to be one on the drivers side mounted to the frame rail about at the drivers seat. Since the ABS system is on the passenger side it might be over there now, which ever side the brake line runs from front to rear.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  14. #39
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by TxDarth View Post
    I don't believe so. The MC has 3 ports. 1 comes from the pre-charge pump. 2 goes directly to the DSC (one from the big bore and the other from the smaller bore). Then each wheel gets a line from the DSC. Realoem doesn't show any other valves.
    It's just the bore size that makes the bias.
    Some brakes systems use a 2 pistion mc. Each circuit runs one front and the opposite corner rear. Then you would have a proportioning valve on the rear.
    If you search the BMW Z8 part#34316754880 you'll get very limited and expensive options like $466, The Land Rover part#SJJ000040 gets more options and also lists the
    TRW pn# PMN219 which can be found for $150.
    Trevor
    81 Delorean,B28F
  15. #40
    Mar 2004
    Tyler, Tx
    I think/believe the master has two ports for safety reasons - if one fails the other should maintain enough to stop at least once. The DSC must do the proportioning for the rear brakes, if it is different than the front, then it might be the same same..........
  16. #41
    Greenville, SC
    01 749iM/6 sporty
    There are 6 ports on the DSC V, H, VR, VL, HR, HL. The big bore line goes to V and the small bore goes to H.
    V- Vorderradaufhängung (front suspension)
    H- Hinterradaufhängung (rear suspension)
    VR-front right
    VL-front left
    HR-rear right
    HL-rear left
    Trevor
    81 Delorean,B28F
  17. #42
    Greenville, SC
    01 749iM/6 sporty
    I agree that is the purpose of the 4 port LF/LR RF/RR setup.
    Trevor
    81 Delorean,B28F
  18. #43
    Mar 2004
    Tyler, Tx
    So it does sound like it does the proportioning..............if there is any difference.
  19. #44
    Greenville, SC
    01 749iM/6 sporty
    The Z8 master cylinder came the other day and I put it in today. Changing the MC is a real pain. There isn't enough room to pull the MC with the booster bolted to the wall and there isn't room to remove the booster completely. I guess the plastic cowling has to come out also. With the booster loose and tilted up I was able to get it back together. A test drive around the neighborhood the pedal is about an inch higher, so I guess mission accomplished.
    Only outward difference between the E38 and Z8 MC is the port threads. m10x1 and m12x1
    With this adapter available at Oreilly's
    The stock line fits fine. The Z8 is 27mm
    The E38 MC is 25mm
    The second bore is 20mm
    Trevor
    81 Delorean,B28F
  20. #45
    Sep 2014
    '01 DINAN7 '03 M5
    VR-front right
    VL-front left
    HR-rear right
    HL-rear left
    Always wanted to know what those ment, I'll remember this
  21. #46
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Strictly genius Trevor. You r the king of part # cross referencing
    Sent from my SM-N910P using Tapatalk
    2000 740i Sport
  22. #47
    Greenville, SC
    01 749iM/6 sporty
    its something I learned in the watercooled VW world. German makers are good about reusing certain items and leaving dimensions and locations the same. For instance... The Corrado VR6 is called a mk2.5 chassis. It's based on the mk2 Golf but has the suspension and drivetrain from the future mk3 chassis.
    Trevor
    81 Delorean,B28F
  23. #48
    McKean township Pennsylva
    1999 M3 , 1999 328is
    This all looks very nicely done!
    Current fleet:
    1999 BMW e36 M3
    1999 BMW e36 328is with rotary valve engine head
    1999 Oldsmobile Eighty Eight
    1990 Jeep Comanche Eliminator
    1962 Austin Healey Sprite
  24. #49
    UAE
    Got myself all 4 calipers and rotors for $470 on ebay!
  25. #50
    Sep 2015
    United Kingdom
    1999 740i M Sport
    Is it necessary to actually do the rears? Would I be ok doing the fronts & leaving 750 ones on the rears?
  1. E60 M5 Front Brake Calipers - No Longer Available
    By legoman67 in forum Brake Kits, Rotors & Pads
    Last Post: 12-02-2013, 12:39 AM
  2. Oem E60 M5 Front Bumper Cover
    By Corra in forum BMW Parts For Sale
    Last Post: 12-25-2006, 06:22 PM
  3. 1995 M5 Front brake pads needed
    By don sutton in forum 1988 - 1996 (E34)
    Last Post: 08-24-2006, 12:37 PM
  4. will E39 M5 front brakes fit E34 M5?
    By TireFryer in forum 1988 - 1996 (E34)
    Last Post: 01-06-2006, 02:36 PM
  5. Feeler.....///M5 Front Brakes...FS
    By theDogger in forum 1988 - 1996 (E34)
    Last Post: 05-27-2005, 10:56 PM
