Results 1 to 25 of 75
Thread: E60 M5 front brakes
    Greenville, SC
    01 749iM/6 sporty
    E60 M5 front brakes
    Since Tyler's S62 conversion is having some part delays I decided to tackle this project that has been laying here for a few weeks.
    ECS 2 piece E60 M5 rotors. I bought a pair of calipers on Fleabay for $250.
    Mock up....
    I used 1/16 bits of aluminum to space the bracket off the rotor, 1/16 was perfect to center the pads on the rotor face.
    The mounting face is in the correct spot it's just the holes that are in the wrong spot
    Luck would have it I had a center punch that was the perfect size
    E38 bolt center is 112mm
    All I have is a drill press. I checked the level and square of the table to the drill bit. A little shim and it was perfect. I used a couple of C-clamps to hold the bracket solid. I bought the drill bit and tap from a machine shop and tooling supplier here in town. Quality bits cut through this steel like butter.
    I bought new lines but ended up using the existing E38 lines. The E60 rotors have 2 retainer screws but the e38 hub only has one. Which is where the only issue comes in. I'm not sure if the E60 center bore is just slightly larger or the ECS hats are a bit large or what. The slop causes a small vibration since the rotor can shift a bit. I'll add the second screw or install a couple of hardened dowel pins.
    All in all I like it and massively cheaper than the Brembo GT set. Plus now I have one more genuine M part on my non-M car.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    Nice Job, BTW did u fill in the OEM holes with oem bolts for rigidity?Here is Pkroton`s E60 write up back in 2007- - - Updated - - -http://www.bimmerboard.com/forums/posts/878049/
    2000 740i Sport
    tmaxx445's Avatar
    tmaxx445 is offline E38 6 Speed Club Member! BMW CCA Member
    Dec 2010
    Greensboro, NC
    '05 M3, '03 X5, '01 740i
    E60 M5 front brakes
    Looks great Trevor!
    What is the piston bore diameter though; does it seem okay with the stock master?
    2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
    2005 M3 Coupe
    / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
    2003 4.6is X5 / Stock /
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by cazal740i View Post
    Not yet. Ran out of time this evening. I'll cut down some old VW lug bolts to fill the holes.
    Quote Originally Posted by tmaxx445 View Post
    Looks great Trevor!
    I'm not sure yet. I only have 5 miles or so. I'm gonna bleed them again and see what happens once the pads fully seat.
    Trevor
    81 Delorean,B28F
    Edmonton, AB, Canada
    97 740iL 03 525iT 03 530
    Nice!
    Quote Originally Posted by 007008 View Post
    As a note, with the e60 Brembo hats I only run the one retainer screw. Once the lug nuts are in, rotor does not shift
    Craig
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Looks great Trevor!
    I don't see why not, my original MC works with 8pot front and 4pot rear BBK Setup
    Instagram.com/nordmanmg
    Your current situation is not your final destination
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    Quote Originally Posted by NordmanMg View Post
    It's a great questions to ask none the less. The only thing I now wonder is if the OP plans on upgrading the rears as well otherwise, the whole brake bias will be thrown off. This is why it's important to upgrade with brakes that have been tested like the 750 upgrade, or Brembo, Stoptech, etc. you get the picture.
    Mar 2008
    Thousand Oaks, CA
    2007 Alpina B7
    MAx , you have 8 pot front and 4 pot rears.. Sure it works fine for you, glad you don't have to upgrade the MC but have you taking the car on a windie mountain up or down? Im sure you`ll get some brake fade with OEM MC
    2000 740i Sport
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Fabian - Two things cause brake fade, well maybe three - pads and rotors getting hot and the brake fluid itself getting hot and boiling. The master will cause a pressure problem if too small for the total piston sizes and amount of fluid pressure required to cause travel....
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
    Sep 2014
    '01 DINAN7 '03 M5
    Oh trust me, I drive the hell out of them week after I installed them, there is a lot of nice curvy roads up here in Colorado, and they work great,
    and I drove few long distance trips to Illinois and Texas and haven't had any issues
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by cdh View Post
    Nice!
    Craig
    I do have a wicked vibration from 40mph-50mph. I thought this was due to the rotor shifting on the center bore. I took the wheel off and Nope, still centered. I do however think I found the source of the vibration. I have spacers on the front which I always thought were 12mm. Turns out they are 10mm but have center bore lip. This rotor hat is fractionally thinner than the other rotor and the spacer, I think, is pressing on the center bore instead of laying flat.
    Trevor
    81 Delorean,B28F
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    I can tell you now that it's the 10mm spacer. Same thing happened when I tried 10mm ECS spacers on my e39. 12mm made it sit flush.
    Sent from my SM-N910V using Tapatalk
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    Sep 2014
    '01 DINAN7 '03 M5
    Quote Originally Posted by blackknight530i View Post
    I had same thing with 13mm hubcentric spacers (74->72) it disappeared after I did E60 hubs and got wheels on directly
    Greenville, SC
    01 749iM/6 sporty
    I took the spacers off and the vibration is gone. While holding the spacer on I couldn't get a .002 shim in but putting a bolt in one hole I could see the spacer tilt.
    Pedal travel is no more than before, at least I can't tell a difference. I will bleed them again just to make sure. The car does shed speed awfully quick now and I still have to install the Hawk HPS pads on the rear. I do want to do the e60 rears but that will come later. Fitting those calipers require a machine shop.
    I believe the carriers are cast steel which means I can weld them. So the plan is to grind bolts into a cone shape, thread them in and fill the hole with weld making it solid. Then build up the surface around the bolts so the mount ears sit on solid flat surface.
    Other than that I'm happy with it and even with the higher priced ECS rotors I'm into this set from about $1300.
    Trevor
    81 Delorean,B28F
    Mar 2016
    Norway
    E38 S62
    only need to make 2 new holes or did you mill down the bracket to get the correct offset?
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by Norwegian E38 View Post
    The offset is correct. Just need new holes but they are not on the same plane as the e60 ones.
    I'm in the process of fitting the rears. They are not as simple as the fronts. A couple of things I don't like in the write ups that exist.
    The rotor rubs the backing plate and once the carrier bracket is milled down it's only 9mm thick.
    The holes in the e38 knuckles need drilled out to fit the larger thread size in the brackets making the lugs even thinner, which I also don't like.
    Oh, and there is also the larger parking brake shoes to fit. And of course the cables have different style ends.
    The good news is I have a plan for all of these issues. The brackets are at the machine shop right now and I have a few bits on order to hopefully solve the issues.
    Trevor
    81 Delorean,B28F
    Alpine 7even's Avatar
    Alpine 7even is offline The King Of E38 Custom BMW CCA Member
    Mar 2011
    Haymarket VA
    e38 iL, F-e38 iL, e23 L7
    Fantastic work trevor as usual!
    -2000 iL Individual. VF Supercharged at 12psi, Dinan MAF and TB, 6spd 420g swap, Euro under body guards, strong strut, N62 engine cover, Hydro trunk, Full suspension mods, Brembo F+R big brakes, custom headliner/interior, Bi-Xenon headlights, wide screen nav/mk4, Custom splash screen (I make them), coded video module with custom made harness, reverse camera, Intravee II, factory rear screen entertainment console, rear comms armrest, rear blower, seat back tables and writing tablet, all euro options coded on etc.
    -1997 iL. Pioneer 8500nex double din/Avic navigation, swc and dsp still functional. Reverse camera, full suspension upgrades, leather dash, console and door cards, rear blower, Re-upholstered seats, facelift sport contour seats, heated steering wheel, 750 front brakes, custom cup holder replacing the front ash tray, all euro options coded, headliner in black, rear headliner MID console.
    Jun 2012
    Long Island
    00 750iL 01 S8 96 Vette
    very nice work. does anyone have any sort of adapter bracket or adapter parts to allow the M5 caliper to hang correctly? I would love this mod on my '00 750iL (I know the 750 brakes are already upgraded from the factory, but they still require a lot of leg force when stopping, since it's a heavy car - and that's with new pads, rotors, and brake fluid). Im hoping this mod would make a big difference in stopping power.
    WTB the following Highline/Individual parts for my 2001 750iL in Black (updated Apr 2016):
    -front sport seat-back cushion
    -rear U.S. entertainment armrest with radio/MID/seat/phone/shade/etc controls
    -rear digital climate control with rear blower and black leather housing/console
    -glovebox and rear right 2001 LHD 750iL wood trim with flag inlay; maybe the dash pieces too
    Ryan
    NYC
    01 740iL & 92 GTI
    Wow.. nice work!
    No BITCHASSEDNESS!!
    VA
    E63AMG/Z31/Tacoma/F31
    Great mod, Trevor!
    Mar 2016
    Norway
    E38 S62
    thank you
    i dont look forward to mount rear brakes.
    i got mine m5 calipers yesterday, and OMG they are HUGE!!!
    getting some zimmerman discs, at aprox 350$ each...
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by serious7series View Post
    no there is nothing that I've seen. Very few have been done. In the last pic I posted is the caliper bracket sitting on top of the knuckle's mounting ears. The 2 need to occupy the same space, so something has to be cut away.
    Here is the size difference in the parking brake shoes
    Yes, I know the shoes look terrible. I have new ones. These are off my e39 m5 which happens to be the same as the e60 ones
    Trevor
    81 Delorean,B28F
    Mar 2016
    Norway
    E38 S62
    Greenville, SC
    01 749iM/6 sporty
    a lot of bmw uses same shoes as m5
    http://bmwfans.info/parts-catalog/34416761293/
    Looks like the E38 was the last to use the older smaller style.
    Trevor
    81 Delorean,B28F
    VA
    When I installed the m5 rear bbk on my e39 528 touring, the stock shoes worked fine inside the m5 rotors. The outside diameter was the same but the m5 shoe was wider. Just a little tidbit of info.
  1. E60 M5 Front Brake Calipers - No Longer Available
    By legoman67 in forum Brake Kits, Rotors & Pads
    Last Post: 12-02-2013, 12:39 AM
  2. Oem E60 M5 Front Bumper Cover
    By Corra in forum BMW Parts For Sale
    Last Post: 12-25-2006, 06:22 PM
  3. 1995 M5 Front brake pads needed
    By don sutton in forum 1988 - 1996 (E34)
    Last Post: 08-24-2006, 12:37 PM
  4. will E39 M5 front brakes fit E34 M5?
    By TireFryer in forum 1988 - 1996 (E34)
    Last Post: 01-06-2006, 02:36 PM
  5. Feeler.....///M5 Front Brakes...FS
    By theDogger in forum 1988 - 1996 (E34)
    Last Post: 05-27-2005, 10:56 PM
