does anyone know offhand what i'd need for spacers to run the wheels described on a 325iX, aside from adaptors?
1986 325eS - cosmosblau, soldOriginally Posted by stevie30
1990 325i sedan - bronzit, sold
1984 318i coupe - delphin, sold
1987 325iS - zinnoberrot, sold
1988 325iS - zinnoberrot, sold
1989 325iX sedan - zinnoberrot, current project/daily
That would depend on the offset of your rims too as I believe ix came with 15" weaves stock.
Also, I am sure you may even find an answer with a little search on r3vlimited.com.
You won't need spacers, but you must be very careful with your tire selection. Your wheel will be sticking out further compared to stock setup and you may experience issue with the sidewall of the tire rubbing inner fender lip. 20mm is a lot when it comes to offset. If you are planning to run adapters, you will add the thickness of your adapter to that 20mm offset difference. In short, if I understood you correctly, your idea is not likely to work.
