Results 1 to 7 of 7
Thread: RPMS Weird
    Nov 2016
    New Hampshire
    BMW 1999 323i
    RPMS Weird
    HELP!! I have a 1999 323i and when the car gets to about 50mph and I press the gas to accelerate a little more but not enough to shift down, the rpms slowly drop and don't raise much more (between 2k-2.5k rpms) no matter how much I push the pedal down. When I press it enough to shift down to 4th the rpms go to about 3k but then drop to 2.7k-2.8k and then start to climb. It's bugging me so much and someone told me it's normal but I don't feel like it is. HELP!!
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the forum!
    Sounds like a pedal failure, however you will have to pull codes and post them up to be sure of it.
    Do you have any lights on the dash? Also pull all codes and post them up, as each one will be a clue as to what has broken.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Nov 2016
    New Hampshire
    BMW 1999 323i
    Okay I'll have to take it to mechanic to see codes. What part of the pedal do you think is doing this?? Do you think it could be the throttle body or throttle position sensor?
    dworthy's Avatar
    Nov 2010
    The TB on the M52TU has an electric stepper motor to open the throttle, there is not TPS in a sense. The throttle in this car is a "drive by wire" type, so there is no actual connection.
    The other thing that comes to mind is the stepper motor is failing. Again codes will help with this as you car has over a dozen different computers.
    Darin
    Current:
    Past:
    M-Flight Member
    Nov 2016
    New Hampshire
    BMW 1999 323i
    Okay, someone told me on another forum it could be the transmission or tourque converter. I hope it's neither of those. Would the stepper motor be expensive to fix? I'll get codes asap
    dworthy's Avatar
    Nov 2010
    Depends if you go new or used. Speculation without any codes is exactly that, so let's wait for the codes to know for certain. Just make sure they scan all the computer DME; EGS; ABS/DSC; ect. At times there can be codes in one ECU that will affect others, but won't be stored there. Ever word from the code is important, so either get a screenshot or write everything down.
    For example a MAF code can be stored in the EGS (Transmission ECU) but not in the DME.
    Darin
    Current:
    Past:
    M-Flight Member
    Nov 2016
    New Hampshire
    BMW 1999 323i
    Okay I will make sure I do all that. BMW's are very complicated haha. I'll get back to you on the codes. Thanks again!
  1. rpm weirdness...
    By PHARMDVIPER in forum 1991 - 1999 (E36)
    Last Post: 08-15-2009, 08:35 AM
  2. Weird smell at higher rpms/speeds
    By swervin lanes in forum 1991 - 1999 (E36)
    Last Post: 03-11-2005, 01:57 AM
  3. weird noise at 5000-5500 rpms...
    By Cosmos96 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-07-2004, 03:41 PM
  4. weird sound at low rpms
    By EFU in forum 1992 - 1999 M3 (E36)
    Last Post: 06-23-2004, 08:01 PM
  5. rpm's acting weird on my new 95 m3...
    By AllEyezOnMy325 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-01-2003, 06:32 PM
