Results 1 to 6 of 6
Thread: Should I remove underhood insulation to eliminate MOUSE NEST problem? Replace it?
    Jun 2015
    Spokane, WA
    2006 BMW 330Ci Coupe
    Question Should I remove underhood insulation to eliminate MOUSE NEST problem? Replace it?
    Due to a lack of garage space, I park my 2006 BMW 330Ci outside. Mice have nested in the underhood insulation over the wintertime, and regularly shred the foam insulation pad into pieces. When I parked the car in late November, maybe 1/10th of the pad was chewed up but now in late February (when the road ice is gone) about 1/4 of the insulation is shredded. A mechanic noticed that some wires in the engine bay had slight chew marks.
    Should I just remove the entire insulation pad to eliminate the mice nest problem? I'm not sure what the pad is there for anyway -- is it to allow the engine to warm up more quickly in the wintertime or to suppress engine noise? I don't want to set out rodent poison because we have cats & owls in the neighborhood and I live in a rural area (with a large number of field mice).
    I have driven the car hard at times at the local racetrack road course in the summertime, and I would imagine that removing the underhood insulation would help keep the engine cooler. What do you recommend?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    The pad is there to protect the paint of the hood, and to keep the noise down.
    You can either replace the pad, with another one from a junkyard car, or buy a new one from around $100 bucks P/N: 51488193941. Just as an FYI, all E-46's use the same pad with the exception of the M-3.
    Here in Germany we have Marders, they too like to chew on wires and insulation. What I do for my outside cars, is get dog hair, and stuff a handful into old pantyhose. Just hang a couple of these around the engine bay, and the critters will stay away.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Michigan
    2005 325Xi
    I removed mine for the same reason about 3 years ago. No problems since.
    Sent from my SM-G360V using Tapatalk
    Michigan
    2005 325Xi
    P.S. i do notice steam coming off the hood after driving in the rain, but otherwise, no issues.
    Jan 2016
    Ca
    2001 525it
    Well removing the hood pad is not the real worry, the real worry is the mice might start eating things more important, like wiring, also the mice urine can be bad for your health, so be carefull. Remember those campers a number of years ago that were staying in those cabin tents at Yosemite and they caught a very bad virus from the mice droppings.
    Feb 2013
    California
    '06 zhp coupe
    Got rid of mine and replaced it with a dynamat type hoodliner.
  1. Should grab or needed parts to remove from my 540i parts car
    By whiteghost1 in forum 1996 - 2003 (E39)
    Last Post: 11-14-2016, 10:11 AM
  2. Removing underhood insulation adhesive...
    By LarryM in forum 1976 - 1989 (E24)
    Last Post: 08-22-2011, 10:04 PM
  3. Replies: 3
    Last Post: 01-16-2011, 04:02 AM
  4. removing tranny, need to use engine support? and replace exhaust?
    By ECBAOBAO in forum 1992 - 1999 M3 (E36)
    Last Post: 06-18-2007, 10:36 AM
  5. Removing the hood edge insulation to evacuate heat
    By paul e in forum 1992 - 1999 M3 (E36)
    Last Post: 08-08-2003, 12:59 AM
