I just got a new obc and light bar and the light bar doesnt light up. hole is too small to probe to test for power. Any i deas? My old obc with a half broke screens light bar worked untill i put the new one in. Now neither light up. any ideas?
You can go to your fuse box and make sure the fuse is good I believe is fuse number 12 , also you can look inside the slot where the light bar goes and make sure that the 2 prong at the end that make contact with light bar are not bent, another thing I did was I took 2 paper clips and bend one end straight then stick that end carefully into the light bar where the prongs inside the obc will go in. You should have 2 clips one on each of the little square holes then grab a 9v battery and touch against the clips if the bulbs come on then your light bar is good and the problem is something else.
