I'm trying to get flush tires, what size do you guys recommend
One that fits the wheels properly.
Interested in vintage cars? Ever thought about racing one?
Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!
How the tires fits depends on the offset of the wheel it's mounted on.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
Agreed, focus on wheel offset.
I roll a +23 15x7 with 205/55. It looks pretty "flush" to me.
