Page 7 of 9 FirstFirst 123456789 LastLast
Results 151 to 175 of 219
Thread: E36 S54 swap, E46 M3 cluster
  1. #151
    UT
    98 M3/4/5
    Awesome
    98 Estoril ///M3 4/6
    S54 swap CSL
  2. #152
    UT
    98 M3/4/5
    2 week bump
    S54 swap CSL
  3. #153
    Northern CA
    1998 M3/4/5
    I made decent design progress over the past few days. Is it same to assume most people are not retrofitting MK60 DSC?
    It also appears that ABS/ASC on OBD1 cars has no speed output that can be used to drive the cluster. I'll need to translate the pulses from the diff sensor.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  4. #154
    Jul 2016
    Holmdel NJ
    1997 M3 S54, 2006 M3,
    I personally wasn’t looking to retrofit the DSC, but I can’t speak for everybody.
  5. #155
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Quote Originally Posted by gpeterson View Post
    No DSC here either. Also I think many people waiting are Obd2 chassis e36's. But I could be wrong.
  6. #156
    Northern CA
    1998 M3/4/5
    Thanks for the feedback guys. I'm trying to balance component count/complexity/cost with flexibility. Looks like not a big deal to build in speedometer translation (for OBD1 support/fewer wires for OBD2).
    Does anyone care about check control support? I had removed the OBC from my car and implemented it with the E46 cluster but that probably won't be part of the production boards. If you want the cluster to display external temp you would need to add a 2nd sensor.
    I'll provide an input for the BC stalk button so you can cycle through clock/temp/mpg. You could use some other button or add the stalk with button if you don't have the 18-button OBC.
  7. #157
    Northern CA
    1998 M3/4/5
    Schematic is done, working on board layout + enclosure selection now.
    I also had a mod fix my mis-spelling of the thread title.
  8. #158
    Northern CA
    1998 M3/4/5
    Forgot to mention - schematic does not have support for E46 A/C pressure sensor, will rely on E36 pressure switch. The pressure sensor option wasn't popular with the CAN board and provided benefit only when used with E46 compressor, radiator outlet temp sensor, and PWM fan controller.
  9. #159
    New England
    E36 M, E32 740i/6, 997 S
    I was hoping to integrate the Mk60 if possible but I'm not sure how much more work that would be, or if there would be another way to do so separately.
  10. #160
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by cohny View Post
    I decided the board will support swaps with or without MK60.
    It is quite a bit of work for full DSC (new wheel speed sensors, yaw/lateral acceleration sensor, steering angle sensor, custom brake lines, E46 M/C with pressure sensors, Z3M S54 booster). You also need an E46 cluster with VIN that matches MK60 or CAN board programmed to emulate a few more cluster messages.
    Board design has been completed, I should be able to complete firmware and start bench testing in 2 weeks or so.
  11. #161
    UT
    98 M3/4/5
    awesome work
    S54 swap CSL
  12. #162
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    So would we be sending you our clusters? How will this work?
  13. #163
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by mitch500 View Post
    Not necessary, but I'll probably offer a cluster coding/mileage correction service at some point. The board will sit between your E36 cluster connectors and the E46 cluster. A few additional wires (CAN, A/C, etc) will be required.
    The cluster physical mods will be DIY.
  14. #164
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Cool! Thanks. Looking forward to it.
  15. #165
    Jul 2016
    Holmdel NJ
    I seem to be perfectly timed with your production. Hoping to have my engine in within two weeks
  16. #166
    New England
    So the ABS unit and the cluster need matching vins? Correct me if I'm wrong but isn't the swap slightly less complicated if you only want the ABS and not the DSC functionality?
  17. #167
    Northern CA
    1998 M3/4/5
    Yes, if you want DSC to work. ABS is fine without receiving the cluster messages and I've been told it works fine without the yaw/lateral acceleration sensor and steering angle sensor.
  18. #168
    Northern CA
    1998 M3/4/5
    PCBs arrived today, components arrive Wednesday, I should be bench testing Thursday.
  19. #169
    UT
    98 M3/4/5
    How is it looking GP?
    S54 swap CSL
  20. #170
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Bump, any update?
  21. #171
    Aug 2008
    Tampa, Florida
    96ti, 98 328i, 04 530i
    Waiting diligently also 👌..
  22. #172
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Any news on this gp?
  23. #173
    Mar 2018
    Arizona
    1998 328I
    I would love to use the e46 cluster on my ls swap :P
  24. #174
    Tampa, FL
    97 E36M3 S54
    So who wants to start taking bets if this will be done before the 2 year mark?
  25. #175
    UT
    98 M3/4/5
    3 week bump
    S54 swap CSL
  1. E46 E46 M3 or E36 S54 swap Section 1 for catless headers
    By MPWRCPE in forum Engines, Performance Parts & Software
    Last Post: 02-10-2021, 10:09 AM
  2. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 04:25 PM
  3. FS: Lots of parts - E36 radio, amp, interior switches, E46 M3 cluster, etc.
    By themadrussian in forum Car Audio & Electronics
    Last Post: 08-30-2009, 04:24 PM
  4. E36 M3 Stuff + E46 M3 Cluster
    By Braymond141 in forum BMW Parts For Sale
    Last Post: 07-17-2006, 11:22 PM
  5. E46 M3 Cluster Fit in E36?
    By bdifc in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2006, 11:19 PM
