Page 4 of 9 FirstFirst 123456789 LastLast
Results 76 to 100 of 209
Thread: E36 S54 swap, E46 M3 cluster
  1. #76
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    updates? im interested as well.
  2. #77
    Jun 2017
    Oakland, CA USA
    1994 BMW 318is
    I'm interested in this as well as I'm also doing a S54 swap. But its in a 1994 318is with no ASC. Wanna see what the few possible options are.
  3. #78
    Northern CA
    1998 M3/4/5
    Finally made some progress on PCB design today, hope to order a batch within the week and begin testing in ~3 weeks.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  4. #79
    UT
    98 M3/4/5
    Yes!!!!!!
    98 Estoril ///M3 4/5
    S54 swap
  5. #80
    Dec 2005
    gilbert,az
    86 el camino, 95+98 m3
    Awsome!
  6. #81
    UT
    98 M3/4/5
    With this news I pulled the trigger on a cluster I had been watching on eBay, fabulous
    S54 swap
  7. #82
    New England
    E36 M, E39 M, E34, & E32
    Are there any advantages to the E46 cluster as far as getting the OBD II plug up and running for emissions purposes?
  8. #83
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by cohny View Post
    You don't need the cluster (or my CAN board) to have a functional OBD2 connector. You will need either for a functional CEL and to provide the proper CAN messages that will allow the evap monitor to set (if the DMTL pump is installed).
  9. #84
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    E36 S54 swap, E46 M3 clsuter
    Edit:
    Just read this thread from start to finish. Count me in for the e46 cluster conversion.
  10. #85
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by mitch500 View Post
    Edit:
    Yea, I have a feeling the cluster conversion will be more popular than my CAN boards, at least for the E36.
    It will be a bit more work & cost in terms of buying/fitting the cluster and adjusting the mileage. I may offer a service to adjust mileage but it would be easier to buy a cluster with lower mileage than desired and use the conversion board to "drive" the cluster at a calculated speed & interval to bring it up to where you want.
  11. #86
    Dec 2005
    gilbert,az
    So this might be a dumb question as I've been interested in this since the first day I saw it? I would want this in my 95m. Should I buy a e46 m cluster in the mean time to convert it over or ?
  12. #87
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Aapex05 View Post
    Have you swapped a S54? I'm working on a solution to make the E46 M3 cluster work in an E36 with a swapped S54.
  13. #88
    Jun 2003
    San Jose, CA
    '02 M Coupe, '12 C4 GTS
    I'm also interested in this as a possible way to deal with not being able to source a replacement S54 Z3M coupe cluster, since it's sort of an S54-swapped E36 with some left-over E30 parts...
    '02 M Coupe
  14. #89
    UT
    98 M3/4/5
    My cluster arrived today
    S54 swap
  15. #90
    Dec 2005
    gilbert,az
    Gotcha. I honestly just wanted the cluster in my e36. I have a separate e36 looks like is going to now get a s54. On to the classifieds!
  16. #91
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Any updates on the progress?
    Sent from my SM-N950W using Tapatalk
  17. #92
    Northern CA
    1998 M3/4/5
    Working on it again today.
    I'm probably going to rely on the ABS/ASC/DSC (whichever is installed) to drive the speedo. The diff sensor output is electrically compatible but the frequency is not. It may be possible to re-code the cluster but I'm taking the easier route for now.
  18. #93
    Jul 2003
    Texas
    1997 M3/4/A
    Updates?
  19. #94
    UT
    98 M3/4/5
    how are we doing on this GP?
    S54 swap
  20. #95
    Northern CA
    1998 M3/4/5
    I just started the car with the cluster connected. Things worked as expected but I still have to run a few wires and finish some programming. I'll post pictures as I make more progress.
  21. #96
    UT
    98 M3/4/5
    Quote Originally Posted by gpeterson View Post
    YES!!! way to go, good work
    question, is this going to be something we need to send in our clusters to you to do or is this more like a "how-to"?
    S54 swap
  22. #97
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    I concur, excellent and much appreciated work.
  23. #98
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Sweet! This going to be great!
  24. #99
    Tampa, FL
    97 E36M3 S54
  25. #100
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by TH3 Shifty View Post
    Should be "how-to" unless you want your cluster mileage corrected. That can be DIY as well though.
  1. E46 E46 M3 or E36 S54 swap Section 1 for catless headers
    By MPWRCPE in forum Engines, Performance Parts & Software
    Last Post: 12-28-2017, 02:51 PM
  2. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 04:25 PM
  3. FS: Lots of parts - E36 radio, amp, interior switches, E46 M3 cluster, etc.
    By themadrussian in forum Car Audio & Electronics
    Last Post: 08-30-2009, 04:24 PM
  4. E36 M3 Stuff + E46 M3 Cluster
    By Braymond141 in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 07-17-2006, 11:22 PM
  5. E46 M3 Cluster Fit in E36?
    By bdifc in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2006, 11:19 PM
