Page 2 of 9 FirstFirst 123456789 LastLast
Results 26 to 50 of 219
Thread: E36 S54 swap, E46 M3 cluster
  1. #26
    Tampa, FL
    97 E36M3 S54
    Very cool! (I need to start looking for a cluster...)
  2. #27
    UT
    98 M3/4/5
    Yeah I'm going to buy a cluster now! awesome work, I hope a "mostly" plugin play can be accomplished
    98 Estoril ///M3 4/6
    S54 swap CSL
  3. #28
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by TH3 Shifty View Post
    I got one from ebay for $130. SMG/manual doesn't matter as it can be coded.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  4. #29
    Mar 2001
    FL
    E36, E46
    Practically foaming at the mouth for installed pics
    '99 Estoril Blue + Dove Grey ///M3 coupe
    '04 Jet Black + Cinnamon ///
    M3 coupe
  5. #30
    Northern CA
    1998 M3/4/5
    I've spent time on the fuel gauge issue and it is a bit of a pain. The E36 uses left & right tank sensors wired in series to a single cluster input, E46 cluster has inputs for each sensor. Of course the sensor resistance varies per chassis and the E46 expects a different resistance from the left & right sensors when full.
  6. #31
    Northern CA
    1998 M3/4/5
    Looks like I have a good solution for the fuel level gauge, need to so some real testing with the E36 level sensors.
    I'm also 90% sure the speedo issue can be solved by re-coding the cluster and wiring it to the E36 diff sensor.
  7. #32
    Northern CA
    1998 M3/4/5
    I have the hardware (currently on a breadboard) and software working with a cluster on my desk. Will be soldering it up on a proto board for some in-car testing soon, will know if the speedo works with E36 diff sensor and fuel level stuff is good shortly after.
    I've been trying to find a source for the E36 cluster PCB connectors X16, X17, and X271. I *may* have found 2 of them, will need to order some to verify.
  8. #33
    Tampa, FL
    97 E36M3 S54
    Awesome progress man! I PM'd you but you may have missed it, would you like me to still sample E36 DME speed with a scope?
  9. #34
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by M52 POWER! View Post
    I think I'm good - should be able to test the cluster in car over the weekend, going to try to make it work with speedo diff sensor since it already runs to the E36 cluster.
    At this point I have the proto board with essential features (fuel level, high beam/turn/fog indicators, dimmable illumination) working. I need to hit a salvage yard to get another set of E46 cluster connectors tomorrow then I'll be testing in the car. I'm not worried about A/C and check control integration as I've already done that on other projects and the proto board was getting crowded. Once I know the speedo & fuel level work correctly in the car I'll find a solution for the E36 cluster PCB connectors, create a board layout, and get some boards ordered. I'd guess it will be 3-4 weeks before I have something ready for purchase.
  10. #35
    UT
    98 M3/4/5
    1st in line!!!!
    S54 swap CSL
  11. #36
    Northern CA
    1998 M3/4/5
    So... I started to test fit an E46 cluster into a spare E36 dash. Someone told me you can unclip the top "spoiler" part and grind down the ribs on top to make it slide right in the E36 dash. Turns out it takes quite a bit more grinding. Not a deal breaker, but more effort than expected.
  12. #37
    UT
    98 M3/4/5
    post pics of what you did
    S54 swap CSL
  13. #38
    Mar 2001
    FL
    E36, E46
    Quote Originally Posted by gpeterson View Post
    maybe 3D printing a new hood is feasible nowadays..?
    M3 coupe
  14. #39
    Northern CA
    1998 M3/4/5
    Still have some fitting to do, hopefully today.
    Quote Originally Posted by jvit27 View Post
    The hood goes away and cluster still needs trimming, nothing to print as we need to make the cluster smaller, not fill gaps.
  15. #40
    Mar 2001
    FL
    E36, E46
    Err, a new outer case perhaps then? Something E36 compatable to insert the guts into.. just thinking out loud for a more finished option..
    M3 coupe
  16. #41
    Northern CA
    1998 M3/4/5
    I spent more time on the housing and am pretty close, pictures coming soon.
    I also ran into an issue with the fuel level part of my circuit when testing in the car, will have to re-work it a bit.
  17. #42
    Tampa, FL
    97 E36M3 S54
    GPeterson,
    Will the E46 LCM be required for this?
  18. #43
    Northern CA
    1998 M3/4/5
    GPeterson,
    Nope, no LCM required. I thought about it at the beginning and quickly realized it complicated things and added little value.
    BTW - my in-car testing today was fine in regards to turn signals and the high beam indicator. Turns out the E36 cluster is what makes the clicking sound when the turn signals are on so no double-clicks when running the E46 cluster.
  19. #44
    Northern CA
    1998 M3/4/5
    I spent a bit of time on the fuel level issue today and am not satisfied with my initial approach. I have some digital potentiometer ICs on order and will try using them to simulate the two E46 level sensors.
  20. #45
    Tampa, FL
    97 E36M3 S54
    So does this mean you need to take the E36's single level sensor and duplicate it x 2, or is there some scaling that needs to be accounted for between E36/E46?
    I was provided the entire E46 M3 fuel pump assembly which includes level sensor, would using that specific level sensor be of any benefit? Or, I'm assuming the tanks physical size determines its scaling values.
  21. #46
    Northern CA
    1998 M3/4/5
    Some scaling must be done as well. The E36 has a pair of sensors wired in series giving about 20ohms empty and 500ohms full. Here are the E46 sensor specs:
    Left side: Empty = 70 Ohms (+/- 1.2), Full = 310.2 Ohms (+/- 3.6)
    Right side: Empty = 70 ohms (=/- 1.2), Full = 394.5 (+/- 4.5)
  22. #47
    Northern CA
    1998 M3/4/5
    E46 cluster housing in E36 dash, it is a tight fit and needs a bit more sanding but getting close:
  23. #48
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Looks great!
    BTW have you had an issue with Brake level warning? E36 is activated opposite E46 / Z3M. I have a warning light when everything is ok and the light will go out if I encounter low fluid. You should be seeing the same thing?
  24. #49
    Tampa, FL
    97 E36M3 S54
    Nice progress. I was just thinking, you should call the adapter the "S54 to E36 CANalog converter" lol...
  25. #50
    Northern CA
    1998 M3/4/5
    What I have working now is really a k-bus LSZ/CCM emulator. I've been working on the final schematic and will add CAN connectivity so that a swap without DSC can control the cluster ABS/DSC lamps.
  1. E46 E46 M3 or E36 S54 swap Section 1 for catless headers
    By MPWRCPE in forum Engines, Performance Parts & Software
    Last Post: 02-10-2021, 10:09 AM
  2. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 04:25 PM
  3. FS: Lots of parts - E36 radio, amp, interior switches, E46 M3 cluster, etc.
    By themadrussian in forum Car Audio & Electronics
    Last Post: 08-30-2009, 04:24 PM
  4. E36 M3 Stuff + E46 M3 Cluster
    By Braymond141 in forum BMW Parts For Sale
    Last Post: 07-17-2006, 11:22 PM
  5. E46 M3 Cluster Fit in E36?
    By bdifc in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2006, 11:19 PM
