I've had a S54 in my E36 for a while now and am using the CAN board (that I build/sell) to make A/C and the check engine light functional.
I'm interested in fitting an E46 M3 cluster and have begun working on it. Why?
-9k tach with warm up lights
-oil temp gauge
-cruise indicator (yes, I have working cruise control)
-clock (my E36 OBC has been removed)
-functional fuel consumption/range display
-low oil level indicator
-DSC indicators (I retrofitted MK60 DSC)
-check control icons
Why is the E46 cluster swap not popular?
-requires physical modification to fit (not really a big deal, will post photos soon) solved
-many indicators (high beam, turn signals, fog, check control) are driven via k-bus that doesn't exist in the E36 solved
-A/C: E46 IHKA & cluster communicate via k-bus solved
-dimming requires PWM signal from LSZ solved - at least on my 2003+ cluster, dimming set via k-bus
-speedometer won't work with E36 diff sensor, needs pulsed signal from DSC (*may* work with E36 ASC, will find out) solved, possibly a few options
-fuel level gauge won't work with E36 level sensors solved
-mileage correction solved
I've started working on hardware & software to send k-bus signals to the cluster from the relevant E36 components. I've got all of the messages figured out and have a cluster on my desk for testing. I'll be updating this post as I make progress.
Update - it works!
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
Subbed af. I would love to put one in mine as well because of the looks of them and also for the extra rpm I will need displayed.
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
2jz..gotta start somewhere.
I'm in for this!
98 Estoril ///M3 4/6
S54 swap CSL
Great to officially kick this off! LMK if there's anything at all I can help you test etc...
Awesome! Would be nice to get timing and amplitude and two speeds, maybe 20 & 50mph?
This diagram says ASC connector pin 15 at ASC or the DME is the one - http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf.
Garry is the man.
Dave
'18 RAM 2500 Laramie Cummins
'15 Pure White VW Touareg TDI
///'95 Avus M3 S54B32 Race car -- 2022 ProAutoSports PS1 Champion
///'72 Chamonix 2002 (Restoration project)
Quick test - pulling the speedo input down with a 50% 200hz square wave produces about 20mph:
1khz was about 100mph.
I'd consider the speedo issue solved by one of these methods:
1 - E36 ASC output may be fine, would just require running a single wire, will know once someone hooks a scope to their E36 ASC. Even if the factor is different that may be fixable with a cluster re-code.
2 - I'll make the hardware capable of converting the diff hall sensor output to the cluster input.
I just figured out the cluster dimming as well, it uses the k-bus on 2003 and newer clusters.
I am very interested in seeing this work. I like the Z3M cluster, but would love the warmup lights and the oil temp gauge. Also the M Track mode icon on the DSC lamp since I've coded that in.
Mileage correction-- PM cyberkaa. He is a wizard at that and can do E46 cluster as well as E36 and Z3M S54. He's also local, which is a plus.
What may be a big ask is converting (without cut/splice) E36 3 connectors to E46 2 connectors. Plug and play would be great!
"Fear disturbs your concentration" -Sabine Schmit
1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
Sooo first inline for this!
S54 swap CSL
Awesome info. In to see where this goes!
I personally just solder to these points - don't even have to disassemble the cluster fully
Though if the cluster comes with an M35080 V6, then an X-PROG won't work (R270 does however). My 05 M3 cluster didn't have a V6, but the 04 330i cluster did, so YMMV.
In my experience the tamper dot doesn't light up as long as there's a VIN stored and an LSZ isn't present (or if an LSZ is present, it matches the stored VIN). Worst case you could probably just send whatever K-bus signal the LSZ sends with the VIN to eliminate the dot.
You can also adjust the tire scaling factor with NCS Expert if you want to use the E36 ASC output (or even the diff output).
Thanks for the info! I was hoping to do things without removing the needles.
Yea, I figured worst case would be query cluster for mileage via diagnostic bus and send the value back when asked for it via k-bus.
Yes, I was looking at ncsdummy and noticed it can be coded. I haven't hooked a scope to the diff output to see if it could be wired directly but will take a look when I can.
Getting E36 ASC output would require running another wire as that is something that is not fed to the E36 cluster. No big deal as some A/C and (optional) check control signals will need to be wired up, but my goal is to make the end product plug in as much as possible.
One other interesting thing - the turn signal messages sent to the E46 cluster are just an off/on and the cluster takes care of the blink rate. It even makes its own clicking noise. I don't have the cluster in my car yet but I imagine it would be annoying to hear both the E36 relay and E46 cluster clicking (and blinking) at different rates. I'm thinking I can somewhat solve via interrupts & software so that each blink of the E36 lights sends the turn signal on at rising edge and turn signal off at falling edge. If there is still an annoying audible difference in the clicks I may just kill the noise in the cluster (brute force or coding? tbd)
My next step will be the fuel level gauge. The E36 has 2 resistive sensors wired in series and the E46 has 2 resistive sensors with discrete signals to the cluster. Shouldn't be a big deal to hook up some pots to both clusters and figure equivalent voltage levels.
Not definitively, but if you can read the m35080 and not erase it, it's probably a V6.
My x-prog still hasn't arrived and I'm impatient, so I backup up the cluster (using pasoft), disassembled it, and replaced the M35080 with a new one. It was easy since the board didn't the coating on it. The most time consuming part was re-aligning the needles during assmembly.
I was able to restore & write the VIN (using pasoft) and now have a 0 mile cluster with a VIN that matches my DME & MK60 ABS:
I also re-coded it to remove the seat belt warning beep and go from SMG -> manual. Pasoft won't write the mileage so I'll probably emulate the LSZ message to set it.
Setting the mileage (in KM) via LSZ message works.
