Page 1 of 9 123456789 LastLast
Results 1 to 25 of 209
Thread: E36 S54 swap, E46 M3 cluster
    Northern CA
    1998 M3/4/5
    I've had a S54 in my E36 for a while now and am using the CAN board (that I build/sell) to make A/C and the check engine light functional.
    I'm interested in fitting an E46 M3 cluster and have begun working on it. Why?
    -9k tach with warm up lights
    -oil temp gauge
    -cruise indicator (yes, I have working cruise control)
    -clock (my E36 OBC has been removed)
    -functional fuel consumption/range display
    -low oil level indicator
    -DSC indicators (I retrofitted MK60 DSC)
    -check control icons
    Why is the E46 cluster swap not popular?
    -requires physical modification to fit (not really a big deal, will post photos soon) solved
    -many indicators (high beam, turn signals, fog, check control) are driven via k-bus that doesn't exist in the E36 solved
    -A/C: E46 IHKA & cluster communicate via k-bus solved
    -dimming requires PWM signal from LSZ solved - at least on my 2003+ cluster, dimming set via k-bus
    -speedometer won't work with E36 diff sensor, needs pulsed signal from DSC (*may* work with E36 ASC, will find out) solved, possibly a few options
    -fuel level gauge won't work with E36 level sensors solved
    -mileage correction solved
    I've started working on hardware & software to send k-bus signals to the cluster from the relevant E36 components. I've got all of the messages figured out and have a cluster on my desk for testing. I'll be updating this post as I make progress.
    Update - it works!
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
    Jkpgt96's Avatar
    Jkpgt96 is offline One of those JZ swappers BMW CCA Member
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    Subbed af. I would love to put one in mine as well because of the looks of them and also for the extra rpm I will need displayed.
    1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
    2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Jkpgt96 View Post
    Are you running a S54 or the 2JZ in your signature? I'm focused on making things work with a S54 swap & MSS54 DME, anything else would be a lot more work to emulate all of the CAN messages.
    Jkpgt96's Avatar
    Jul 2012
    St. Louis, MO
    2JZ 95 M3
    2jz..gotta start somewhere.
    UT
    98 M3/4/5
    I'm in for this!
    98 Estoril ///M3 4/5
    S54 swap
    Tampa, FL
    97 E36M3 S54
    Great to officially kick this off! LMK if there's anything at all I can help you test etc...
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by M52 POWER! View Post
    Would be nice if someone with an E36 and oscilloscope could capture the ASC pulsed speed output, it may work fine with the E46 cluster. I'd try but my ASC has been replaced with E46 MK60 DSC.
    Tampa, FL
    97 E36M3 S54
    Quote Originally Posted by gpeterson View Post
    I just so happen to have an oscilloscope I use at work and stock ASC. If you can give me pinout locations I can get that for you!
    Northern CA
    1998 M3/4/5
    Awesome! Would be nice to get timing and amplitude and two speeds, maybe 20 & 50mph?
    This diagram says ASC connector pin 15 at ASC or the DME is the one - http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf.
    Jan 2003
    Free America AZ
    German ones
    Garry is the man.
    Dave
    '15 Pure White VW Touareg TDI - The M hauler
    ///'95 Avus M3 S54B32 -Stripped, caged @ 2681#
    ///'90 Calypso 325ic (70K miles)
    ///'72 Chamonix 2002 (Restoration project)
    ///'87 Alpine 535is
    Northern CA
    1998 M3/4/5
    Quick test - pulling the speedo input down with a 50% 200hz square wave produces about 20mph:
    1khz was about 100mph.
    I'd consider the speedo issue solved by one of these methods:
    1 - E36 ASC output may be fine, would just require running a single wire, will know once someone hooks a scope to their E36 ASC. Even if the factor is different that may be fixable with a cluster re-code.
    2 - I'll make the hardware capable of converting the diff hall sensor output to the cluster input.
    Northern CA
    1998 M3/4/5
    I just figured out the cluster dimming as well, it uses the k-bus on 2003 and newer clusters.
    Tampa, FL
    97 E36M3 S54
    Got it, I should be able to get this done by end of week.
    Mar 2006
    Menlo Park, CA
    95 M3 & Legacy Manwagon
    I am very interested in seeing this work. I like the Z3M cluster, but would love the warmup lights and the oil temp gauge. Also the M Track mode icon on the DSC lamp since I've coded that in.
    Mileage correction-- PM cyberkaa. He is a wizard at that and can do E46 cluster as well as E36 and Z3M S54. He's also local, which is a plus.
    What may be a big ask is converting (without cut/splice) E36 3 connectors to E46 2 connectors. Plug and play would be great!
    "Fear disturbs your concentration" -Sabine Schmit
    1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
    1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
    2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by Bimmerman535i View Post
    Plug & play for cluster connectors is part of my plan. There will be other wires to run/connect if you want A/C and check control on the cluster.
    Northern CA
    1998 M3/4/5
    Thanks, I should be set, have x-prog on order and M35080 spares on hand just in case.
    UT
    98 M3/4/5
    Sooo first inline for this!
    S54 swap
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Awesome info. In to see where this goes!
    Philadelphia, PA
    2005 M3 & 2004 330i
    I personally just solder to these points - don't even have to disassemble the cluster fully
    Though if the cluster comes with an M35080 V6, then an X-PROG won't work (R270 does however). My 05 M3 cluster didn't have a V6, but the 04 330i cluster did, so YMMV.
    In my experience the tamper dot doesn't light up as long as there's a VIN stored and an LSZ isn't present (or if an LSZ is present, it matches the stored VIN). Worst case you could probably just send whatever K-bus signal the LSZ sends with the VIN to eliminate the dot.
    You can also adjust the tire scaling factor with NCS Expert if you want to use the E36 ASC output (or even the diff output).
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by TerraPhantm View Post
    Thanks for the info! I was hoping to do things without removing the needles.
    Yea, I figured worst case would be query cluster for mileage via diagnostic bus and send the value back when asked for it via k-bus.
    Yes, I was looking at ncsdummy and noticed it can be coded. I haven't hooked a scope to the diff output to see if it could be wired directly but will take a look when I can.
    Getting E36 ASC output would require running another wire as that is something that is not fed to the E36 cluster. No big deal as some A/C and (optional) check control signals will need to be wired up, but my goal is to make the end product plug in as much as possible.
    One other interesting thing - the turn signal messages sent to the E46 cluster are just an off/on and the cluster takes care of the blink rate. It even makes its own clicking noise. I don't have the cluster in my car yet but I imagine it would be annoying to hear both the E36 relay and E46 cluster clicking (and blinking) at different rates. I'm thinking I can somewhat solve via interrupts & software so that each blink of the E36 lights sends the turn signal on at rising edge and turn signal off at falling edge. If there is still an annoying audible difference in the clicks I may just kill the noise in the cluster (brute force or coding? tbd)
    My next step will be the fuel level gauge. The E36 has 2 resistive sensors wired in series and the E46 has 2 resistive sensors with discrete signals to the cluster. Shouldn't be a big deal to hook up some pots to both clusters and figure equivalent voltage levels.
    Philadelphia, PA
    2005 M3 & 2004 330i
    Just to be clear, at least on the E46, the tamper dot has nothing to do with mileage despite what everyone says. It's a VIN mismatch that triggers it.
    Northern CA
    1998 M3/4/5
    Ok, great. One less thing to deal with.
    Can you tell if a cluster has M35080 V6 without disassembling it?
    Philadelphia, PA
    2005 M3 & 2004 330i
    Not definitively, but if you can read the m35080 and not erase it, it's probably a V6.
    Northern CA
    1998 M3/4/5
    My x-prog still hasn't arrived and I'm impatient, so I backup up the cluster (using pasoft), disassembled it, and replaced the M35080 with a new one. It was easy since the board didn't the coating on it. The most time consuming part was re-aligning the needles during assmembly.
    I was able to restore & write the VIN (using pasoft) and now have a 0 mile cluster with a VIN that matches my DME & MK60 ABS:
    I also re-coded it to remove the seat belt warning beep and go from SMG -> manual. Pasoft won't write the mileage so I'll probably emulate the LSZ message to set it.
    Northern CA
    1998 M3/4/5
    Setting the mileage (in KM) via LSZ message works.
  1. E46 E46 M3 or E36 S54 swap Section 1 for catless headers
    By MPWRCPE in forum Engines, Performance Parts & Software
    Last Post: 12-28-2017, 02:51 PM
  2. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 04:25 PM
  3. FS: Lots of parts - E36 radio, amp, interior switches, E46 M3 cluster, etc.
    By themadrussian in forum Car Audio & Electronics
    Last Post: 08-30-2009, 04:24 PM
  4. E36 M3 Stuff + E46 M3 Cluster
    By Braymond141 in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 07-17-2006, 11:22 PM
  5. E46 M3 Cluster Fit in E36?
    By bdifc in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2006, 11:19 PM
