Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 199
Thread: E36 S54 swap, E46 M3 cluster
  1. #101
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Will there be any difference between the bosch or moto meter units?
  2. #102
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by mitch500 View Post
    Not sure yet, I have a Bosch. Once I get it 100% done I'll probably pick up some other clusters for testing.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  3. #103
    Northern CA
    1998 M3/4/5
    Minor update - I'm about to test cluster re-coding so that we can hopefully use the E36 speedo diff sensor (9 teeth/rev) instead of ABS output (48 teeth/rev) to drive the speedometer. If it doesn't work out I believe the E36 ABS/ASC output would still work by running an extra wire but can't test on my car as I retrofitted MK60 DSC.
  4. #104
    Northern CA
    1998 M3/4/5
    Coding the E46 cluster to use the E36 diff speed sensor was a bust. They are electrically compatible but the values required for the cluster to read speed properly from a 9 tooth wheel (E36 diff) as opposed to a 48 tooth wheel (E46 & E36 ABS/DSC) is outside of the range that makes the cluster happy. This isn't a bug deal, just means running another wire so that the cluster gets speed from ABS instead of the diff.
  5. #105
    Tampa, FL
    97 E36M3 S54
    I've ran so many wires in my swap 1 more is no problem lol.
  6. #106
    Northern CA
    1998 M3/4/5
    What do people think about abandoning the E36 check control on the OBC when running an E46 cluster? The cluster pictogram would do it all with a few exceptions:
    working
    lamp monitoring
    low washer fluid
    low coolant
    outside temp
    not working
    brake light switch failure
    status in individual doors/trunk open (would only be driver's side)
    I'm going that route because it is more simple in some ways (low coolant/low washer fluid comes through CCM on E36), but things will get a little odd if you wanted the OBC and cluster CCM to work. Would get extra weird since I'm using the turn signal stalk OBC button with the E46 cluster.
  7. #107
    UT
    98 M3/4/5
    im cool with whatever works for you...
    98 Estoril ///M3 4/5
    S54 swap
  8. #108
    Tampa, FL
    97 E36M3 S54
    Quote Originally Posted by gpeterson View Post
    working
    lamp monitoring
    low washer fluid
    low coolant
    outside temp
    not working
    I think the ones you have working are the most important anyways. I plan on eventually deleting the stock OBC and only using the E46 cluster features.
    Will fuel mileage and range work?
  9. #109
    Feb 2004
    Toronto
    S54/E36 ; E30 ; Saab
    Quote Originally Posted by M52 POWER! View Post
    Yes.
    Sent from my Redmi Note 4 using Tapatalk
    #E36-S54 #CSLWannabe
  10. #110
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Will outside temp work as well?
    But really, what ever is easiest for you.
  11. #111
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Also do you think there would be any reason why a European/Canadian spec km/h cluster wouldn't work? I've had my eye on one locally and want it bad.
  12. #112
    Tampa, FL
    97 E36M3 S54
    Yes, in his list he just posted under working is "outside temp"
  13. #113
    UT
    98 M3/4/5
    what about the physical aspect of the install? what do we need to modify to get it to fit?
    S54 swap
  14. #114
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by TH3 Shifty View Post
    It requires some trimming/sanding, hope to have pictures soon.
    I actually took a short drive with the cluster connected yesterday and will be working on firmware a bit more today.
  15. #115
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Awesome work!
  16. #116
    Tampa, FL
    97 E36M3 S54
  17. #117
    Aug 2008
    Knoxville TN
    99 M3 vert
    Would love to see those pictures. I'm in the planning stages of S54/MK60 swap into my E36 M3. I think the E46 cluster would be great to include, thanks for your updates!
  18. #118
    UT
    98 M3/4/5
    i think he's traveling for work right now, but he will usually post soon.
    S54 swap
  19. #119
    Mar 2018
    Longmont, Colorado
    4 E36s, an E46 M3
    Is there any updates on this? I am about to do an S54 swap into an E36 M3 and I have a complete E46 M3 to pull from. I would like to make it as "easy" to do, and by that, I mean, a little wiring to redo while keeping the look as stock as possible. I'm happy to pull the entire E46 M3 harness, basically.
  20. #120
    UT
    98 M3/4/5
    Hey GP give us an update, it’s been a long time
    S54 swap
  21. #121
    Northern CA
    1998 M3/4/5
    No progress lately, been blocked by other things.
  22. #122
    Northern CA
    1998 M3/4/5
    The cluster is in the car and I'll be driving it that way from now on. It isn't shoved in the dash all the way or properly mounted as I'm still making software tweaks. Pictures coming soon.
  23. #123
    UT
    98 M3/4/5
    Awesome!
    S54 swap
  24. #124
    USA
    None
    What are the steps we can take to make it work?
    Id like to order an e46 m cluster and have it programmed by you if possible and if youre willing.
  25. #125
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by KnudsonsM3 View Post
    Required:
    -physical mods to cluster so it will fit in the E36 dash
    -adapter board that I'll soon be selling
    -wires for CAN high/low from DME to cluster
    -wire from ABS to cluster (for speedo)
    Optional:
    -wires from IHKA & A/C pressure switch to adapter board (for A/C)
    -wires from CCM to adapter board (for check control functions on cluster)
    -wires from external temp sensor to adapter board
  1. E46 E46 M3 or E36 S54 swap Section 1 for catless headers
    By MPWRCPE in forum Engines, Performance Parts & Software
    Last Post: 12-28-2017, 03:51 PM
  2. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 05:25 PM
  3. FS: Lots of parts - E36 radio, amp, interior switches, E46 M3 cluster, etc.
    By themadrussian in forum Car Audio & Electronics
    Last Post: 08-30-2009, 05:24 PM
  4. E36 M3 Stuff + E46 M3 Cluster
    By Braymond141 in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 07-18-2006, 12:22 AM
  5. E46 M3 Cluster Fit in E36?
    By bdifc in forum 1992 - 1999 M3 (E36)
    Last Post: 04-25-2006, 12:19 AM
