Page 5 of 5 FirstFirst 12345
Results 101 to 116 of 116
Thread: E36 S54 swap, E46 M3 clsuter
  1. #101
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Will there be any difference between the bosch or moto meter units?
  2. #102
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by mitch500 View Post
    Not sure yet, I have a Bosch. Once I get it 100% done I'll probably pick up some other clusters for testing.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  3. #103
    Northern CA
    1998 M3/4/5
    Minor update - I'm about to test cluster re-coding so that we can hopefully use the E36 speedo diff sensor (9 teeth/rev) instead of ABS output (48 teeth/rev) to drive the speedometer. If it doesn't work out I believe the E36 ABS/ASC output would still work by running an extra wire but can't test on my car as I retrofitted MK60 DSC.
  4. #104
    Northern CA
    1998 M3/4/5
    Coding the E46 cluster to use the E36 diff speed sensor was a bust. They are electrically compatible but the values required for the cluster to read speed properly from a 9 tooth wheel (E36 diff) as opposed to a 48 tooth wheel (E46 & E36 ABS/DSC) is outside of the range that makes the cluster happy. This isn't a bug deal, just means running another wire so that the cluster gets speed from ABS instead of the diff.
  5. #105
    Tampa, FL
    97 E36M3 S54
    I've ran so many wires in my swap 1 more is no problem lol.
  6. #106
    Northern CA
    1998 M3/4/5
    What do people think about abandoning the E36 check control on the OBC when running an E46 cluster? The cluster pictogram would do it all with a few exceptions:
    working
    lamp monitoring
    low washer fluid
    low coolant
    outside temp
    not working
    brake light switch failure
    status in individual doors/trunk open (would only be driver's side)
    I'm going that route because it is more simple in some ways (low coolant/low washer fluid comes through CCM on E36), but things will get a little odd if you wanted the OBC and cluster CCM to work. Would get extra weird since I'm using the turn signal stalk OBC button with the E46 cluster.
  7. #107
    UT
    98 M3/4/5
    im cool with whatever works for you...
    98 Estoril ///M3 4/5
    S54 swap in progress
  8. #108
    Tampa, FL
    97 E36M3 S54
    Quote Originally Posted by gpeterson View Post
    working
    lamp monitoring
    low washer fluid
    low coolant
    outside temp
    not working
    I think the ones you have working are the most important anyways. I plan on eventually deleting the stock OBC and only using the E46 cluster features.
    Will fuel mileage and range work?
  9. #109
    Feb 2004
    Toronto
    S54/E36 ; E30 ; Saab
    Quote Originally Posted by M52 POWER! View Post
    Yes.
    Sent from my Redmi Note 4 using Tapatalk
    #E36-S54 #CSLWannabe
  10. #110
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Will outside temp work as well?
    But really, what ever is easiest for you.
  11. #111
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Also do you think there would be any reason why a European/Canadian spec km/h cluster wouldn't work? I've had my eye on one locally and want it bad.
  12. #112
    Tampa, FL
    97 E36M3 S54
    Yes, in his list he just posted under working is "outside temp"
  13. #113
    UT
    98 M3/4/5
    what about the physical aspect of the install? what do we need to modify to get it to fit?
  14. #114
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by TH3 Shifty View Post
    It requires some trimming/sanding, hope to have pictures soon.
    I actually took a short drive with the cluster connected yesterday and will be working on firmware a bit more today.
  15. #115
    May 2009
    Pittsburgh, PA
    S54/E36, 04M3, 14 Sierra
    Awesome work!
  16. #116
    Tampa, FL
    97 E36M3 S54
  1. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 05:25 PM
  2. E46 Parting OUT S54 BMW E46 M3 Engine - Complete Motor - LOW MILES -
    By 1995AVUSM3 in forum Engines, Performance Parts & Software
    Last Post: 04-17-2015, 02:53 AM
  3. Infiniti M45 vs. e36 328i vs. e46 M3....sortof
    By AuricanX in forum Kill Stories
    Last Post: 06-23-2004, 04:46 PM
  4. To you guys who went from an E36 to an E46 M3. . .
    By frayed in forum 2001 - 2006 M3 (E46)
    Last Post: 01-04-2004, 12:14 AM
  5. E36 into an E46 M3
    By Hyperion in forum 1991 - 1999 (E36)
    Last Post: 04-18-2001, 08:51 PM
