Page 6 of 9 FirstFirst 123456789 LastLast
Results 126 to 150 of 219
Thread: E36 S54 swap, E46 M3 cluster
  1. #126
    UT
    98 M3/4/5
    awesome... well lets start with what do we need to physically modify on the cluster.. mine is just sitting here.. would like to start on it...
    98 Estoril ///M3 4/6
    S54 swap CSL
  2. #127
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Nice!
    Will it matter if my cluster is in canadian kilometers per hour and not mph?
  3. #128
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by TH3 Shifty View Post
    A fair amount of grinding/sanding, I'll pull it back out and post a picture soon.
    Quote Originally Posted by mitch500 View Post
    Nice!
    No
  4. #129
    Northern CA
    1998 M3/4/5
  5. #130
    UT
    98 M3/4/5
    that looks great!
    does the tachometer lights light up?
    S54 swap CSL
  6. #131
    Northern CA
    1998 M3/4/5
    that looks great!
    Yep, 100% functional, even MPG, the check control features, and outside temp display (I removed the OBC).
  7. #132
    Northern CA
    1998 M3/4/5
    Physical cluster mods, basically some grinding/sanding:
    Once that is done it fits with a bit of pressure. I haven't made mounting tabs because it is very solid as-is and kind of a pain to remove.
  8. #133
    Feb 2016
    Rogers AR
    1995 BMW M3
    That doesn't seem bad.
    Good work gpeterson on this project!
  9. #134
    Feb 2004
    Toronto
    S54/E36 ; E30 ; Saab
    Any reason why the E46 turn stalk? BC input can be implemented with the e36 stalk.
    Sent from my Redmi Note 4 using Tapatalk
    #E36-S54 #CSLWannabe
  10. #135
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by ZiMMie View Post
    Good eye! My original turn stalk didn't have the BC button so I was going to use one I had from an E39. Turns out it couldn't be used without additional circuitry. I just put an E36 stalk back on today.
  11. #136
    UT
    98 M3/4/5
    excellent work GP... how long do you think it will be before we you start making the swaps... also would this mean we no longer need the CAN controller?
    S54 swap CSL
  12. #137
    Northern CA
    1998 M3/4/5
    excellent work GP... how long do you think it will be before we you start making the swaps?
    At least a few weeks. The prototype board I'm running doesn't connect to CAN at all. Most people will need to board to send a few CAN messages or else the cluster's ABS and DSC indicators would always be lit.
    Yep - the cluster conversion board sends A/C messages to the cluster via k-bus and the cluster passes those messages to the DME via CAN.
    S54 swap DME flashing - $100
    S54 swap CAN interface board (for proper A/C & check engine light) - $275
    e36 SAP sim/secondary air pump simulator:
    $75 - standard or $170 - plug & play
    e36 post-cat O2 sims: $115 shipped, plug & play
  13. #138
    SoCal
    E46M3,E36M3,E90,E23,66Mu
    This is super cool you've got this working, awesome job!
    I have an SMG cluster out of a vert and I'm also installing the 6 speed trans from the donor car. Will the gear position indicator and roll over protection icon work as well?
    I may have missed it, but, as far as the connections go, do you just re-pin the mating connectors from the e36 harness to the e46 cluster connectors or does the E36 harness plug into your adapter board and that then plugs into the cluster?
    Thanks again, awesome work!
    -Brian
    -Varis-Hartge-Seibon-Umnitza-TRM--Mason Engineering-Zionsville-Mishimoto-Stewart-Conforti-BMW ///M/LTW
  14. #139
    Northern CA
    1998 M3/4/5
    Quote Originally Posted by bigpuppy View Post
    The gear position indicator won't work, with a SMG there is nothing to tell it which gear is engaged. The roll over protection icon may be possible but I'd have to figure out what message to send to the cluster.
    The adapter board will connect between the car and cluster and a few other wires will need to be run.
  15. #140
    UT
    98 M3/4/5
    just checking back... how are we looking?
    S54 swap CSL
  16. #141
    Jul 2016
    Holmdel NJ
    1997 M3 S54, 2006 M3,
    Just wanted to check to see how this is going? Just about to start my swap and interested in using this cluster as well. Shoot me a pm if you can would love to chat about a purchase if one is ready
  17. #142
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Any updates?
  18. #143
    Northern CA
    1998 M3/4/5
    Just got back from a long trip, hope to get more done on the production design this week.
  19. #144
    Feb 2004
    Toronto
    Quote Originally Posted by gpeterson View Post
    Welcome back. Did you thought of integrating the canbus Into the openobc project before starting this?
    It uses a very powerful chip which should be able to do this no problem.
    Sent from my Redmi Note 5 using Tapatalk
  20. #145
    Northern CA
    1998 M3/4/5
    Hadn't thought about it since I have no OBC in my car and my E46 cluster now has check control, range, and MPG functioning.
  21. #146
    Tampa, FL
    97 E36M3 S54
  22. #147
    Jul 2016
    Holmdel NJ
    Just wondering if we're still on schedule? Ready to start grinding this cluster to fit
  23. #148
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Same here got mine ready to go.
  24. #149
    UT
    98 M3/4/5
    dying for this.. already been ready with mine.. lets GO
    S54 swap CSL
  25. #150
    Northern CA
    1998 M3/4/5
    I'm not going to make (and break) any promises, but I started work on this again today now that my car has sold and a few other things have calmed down a bit. Once the PCB design is done it will take 2 weeks to get a batch of boards and I can begin bench testing.
  1. E46 E46 M3 or E36 S54 swap Section 1 for catless headers
    By MPWRCPE in forum Engines, Performance Parts & Software
    Last Post: 02-10-2021, 10:09 AM
  2. E36 1995 bmw m3 e36 s54 swap - Alpine White
    By blackedM3 in forum 3 series & Z Series
    Last Post: 01-17-2016, 04:25 PM
  3. FS: Lots of parts - E36 radio, amp, interior switches, E46 M3 cluster, etc.
    By themadrussian in forum Car Audio & Electronics
    Last Post: 08-30-2009, 04:24 PM
  4. E36 M3 Stuff + E46 M3 Cluster
    By Braymond141 in forum BMW Parts For Sale
    Last Post: 07-17-2006, 11:22 PM
  5. E46 M3 Cluster Fit in E36?
    By bdifc in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2006, 11:19 PM
