1995 E36 M3 Street/DE/Track Car - Norcal, Clean Title
The time has come for me to part ways with my 95 m3 track car. This car is fully capable and has been a labor of love for the past 8 years.
The car currently has 151k miles on it. It is on a clean non op CA title. The car will pass smog with installation of the original cat and stock muffler which I have. It's a bit of work to do this but I can complete the request if the buyer is in California and indeed wants the smog and registration done prior to receiving the car.
I am the 4th owner. I bought the car purley stock in San Diego in 2009 with 136k miles on it. While I have had the car it has spent most of it's life in LA from 09-2014. From 2014 until now it's been with me up in the bay area. Clean carfax, absolutely no rust. Other states the car was registered in were Texas and Florida. I have full documentation of my parts and work done including a spreadsheet of over $25k invested since I bought it.
IMG_3075 by Allen Pinkerton, on Flickr
IMG_3076 by Allen Pinkerton, on Flickr
IMG_3086 by Allen Pinkerton, on Flickr
IMG_3083 by Allen Pinkerton, on Flickr
IMG_3069 by Allen Pinkerton, on Flickr
IMG_3067 by Allen Pinkerton, on Flickr
IMG_3060 by Allen Pinkerton, on Flickr
IMG_3044 by Allen Pinkerton, on Flickr
IMG_3021 by Allen Pinkerton, on Flickr
IMG_3018 by Allen Pinkerton, on Flickr
IMG_3012 by Allen Pinkerton, on Flickr
IMG_3007 by Allen Pinkerton, on Flickr
IMG_3014 by Allen Pinkerton, on Flickr
IMG_3016 by Allen Pinkerton, on Flickr
Full Disclosure:
Car has been having what seems to be a head gasket problem for the past couple events. Symptoms are experienced while driving the car hard at events. While on the street at normals speeds like to and from the track the car does not overheat. At the last 2 events I can run 20 minute sessions before it will start to run hot. I then have to pit and cool it off 40-50 minutes until the next session. It typically will begin to run hot again toward the end of the next session. The car has full power, but this is obviously not sustainable. The cooling issue will have to be addressed. Head Gasket is the informal but likely diagnosis.
Car operates at full power. No white smoke, no chocolate milk in the oil. This is the original S50 with original head gasket.
Short Version
Please see the next post for ALL parts and services. I also have a lot of parts for sale separately or can be included as a deal. The price and descriptions of the spare parts are in that post as well.
I documented many parts of the build of this car on a blog. While my obsession has remained the time has waned. Just about everything ever done to this car is in here. Feel free to take a look. The most recent posts are probably the most important as things changed over time.
http://m3pink.blogspot.com/
Here is footage of the last track day I did with the car. Even with the HG problem I want to show the car's capability. This is one lap of a track day at Sonoma in November 2015. Sorry for the shaky camera and angle, just an iphone attached to the roll bar.
https://www.dropbox.com/s/qju25iqslg...20156.mp4?dl=0
I plan to update the thread with descriptive sale photos once I get it cleaned up. Hopefully in the next couple weeks. For the time being please see images in this flickr album.
https://flic.kr/s/aHskS5ChT8
Full Description
The car is essentially a track car you can drive on the street. Most of the amenities still remain. Car still retains power steering, working A/C and all radio wiring. No wiring in general has been removed. Original carpet is still in the car. Dash and center console original and in good shape.
Steering wheel and front seats have been exchanged for Racetech RT4009 and a Sparco 353. AKG Stage 3 Short Shifter with DSSR rounds out the touch points. Items that have been removed include the rear seats, sunroof cassette. In place of the sunroof is a S2R Tuning Carbon Fiber panel. TC Kline 4pt bolt in roll bar fills out the rear. Passenger airbag, factory seatbelts and rear interior panels have been removed but are included.
The ride is stiff but compliant. At one point there were solid motor and trans mounts, but those were ditched for AKG poly 75D motor mounts and e21 tranny mounts with AKG cups. The combination has little NVH and great performance.
Front and rear suspension have been completely overhauled. Rear subframe and all parts were blasted and powdercoated semi-gloss black. Rear subframe has aluminum bimmerworld bushings. Diff has aluminum mounts with delrin front mount from Turner. RTAB are Meyle HD with delrin limiters. Rear lower control arms are Turner Race. All other connections in the back including ball joints and rubber are OE BMW/Lemfoerder.
All reinforcements have been done. RTAB pockets, rear sway tabs and front subframe under the motor mounts.
Steering rack is the ultra quick 1.9 z3 rack with 2.7 turns lock to lock. Front control arm bushing have been replaced with new along with offset delrin TC Kline FLCA bushing. Car rides on TCK S/A coilovers that have around 5k miles on them. 450lb/500lb spring rates paired with Vorshlag camber plates for a front negative camber around 3-3.5 and rear of -2. Car has been corner balanced with driver by West End Alignment in Torrance by Chris and Darrin. Well worth the money. I'm roughly 150lbs.
Wheels are square setup 17x9 D-Force LTW5 in anthracite. 16.4 lbs a piece wrapped in Hankook RS3. Less than 1000 miles and 2 track days on the tires. A spare set of LTW5 with BFG R1 slicks are also available.
Brakes are PFC 01 all around. Turner cooling ducts with 3" high temp hose. Disconnects on fender lining. Stainless steel lines and wilwood EXP 600 brake fluid. Car is raced without ABS. All parts for ABS system are there and installed on the car.
Engine is currently running the Turner stage 1.5 chip with 21.5# injectors, and euro HFM. Eurosport carbon fiber intake with AFE cone handles induction while exhaust is taken care of by Bimmerworld 3" Race Exhaust and Y-pipe. TMS power pulleys, mishimoto aluminum radiator and stewart water pump are few more items under the hood.
Lots of maintenance, hoses, gaskets, cooling system and just about every part has been replaced or upgraded. Areas that haven't been touched are the actual internals of the motor and transmission. Clutch is stock.
This car is a solid platform and chassis to do what you wish with the engine. All bushings, suspension, reinforcements and interior pieces to go racing have been done. Car is well sorted in the chassis department, having gone through multiple shakedowns.
Besides the HG, other small items here and there are the button for the glove box, random plastic interior trim and a few exterior dings. Paint is in good shape. The car cleans up very well and can easily continue as a street car / weekend warrior car. Or you can strip it all down and go full race.
Car is located in Novato, CA
ALL SPARES INCLUDED AT $11k PRICE!
New - Odyssey PC680 and Russ Wiles Battery Box 3/3/17
Suspension F&R
BMW OE X-Brace
TCK S/A Coilovers – Bought used with 4k miles, Installed at 148,672 miles
TCK RSM
Vorshlag Camber Plates 60mm Perches
450lb Hyperco 6” Front Springs
500lb BeeHive TCK Rear Springs
Corner Balanced with 150lb driver
Front Suspension all done after 145k
12mm UUC front wheel spacers
90mm BBS studs
Lemfoeder Ball Joints Inner and Outer Front Control Arms
Lemfoeder Tie Rods Front Left and Right
Meyle HD Sway bar Stabilizers
Rebuilt Z3 Steering Rack from the Rack Doctor
AKG Front Subframe Reinforcement Kit Welded in
Rear Suspension all done after 148k
Meyle HD Rear Trailing Arm Bushing with TC Kline Delrin Limiters
Bimmerworld Solid Aluminum Subframe Bushings
BMW OE/Lemfoeder upper and lower rear control arm ball joints
Turner Motorsports rear adjustable solid lower camber arms. (Race)
Turner Motorsports differential bushings and front bolt (solid aluminum/delrin front)
Lemfoerder sway bar end links
New wheel bearing and associated hardware, snap ring, nut (***)
New boots/grease for axles R&R (GKN LOEBRO)
Weld reinforcements for the RTAB pocket (AKG)
Weld reinforcements for the rear sway bar attachment (TMS)
Powdercoat all parts semi-gloss black
Drivetrain
AKG Stage 3 Race Shifter and DSSR
98 M3 4 bolt Driveshaft - 102k miles Rebuilt Balanced by Driveshaft Specialists in Durate
99 M3 3.38LSD – 92k miles
OE BMW Center Support Bearing
OE BMW Guibo
OE BMW Shifter Selector Rod Seal, Gershift Rod Joint, Rubber Boot
AKG 75D Poly Engine Mounts
AKG E21 Tranny Mounts Aluminum Cups and Mounts
General Maintenace from 136-140kmiles
Cabin Filter
Power Steering reservoir, washers, Hoses
Fuel Filter
Valve Cover Gasket
Misc Interior Bulbs
Oil Filter Housing Gasket and orings
M-logo Floor Mats
Intake hoses from ICV to intake
A/C compressor Belt
Alternator Water Pump Belt
Engine Oil and Filter Always changed within (6 months, 2 track days or 3000 miles) Mahle Filters, LIquimoly 5w40 Synthetic
Engine
Euro 3.5” HFM
AFE 8” Cone
Bimmerworld 3.5” Silicone Boot Reducer
Freshly Serviced 21.5lb S52 Injectors
Eurosport Carbon 3.5” Intake
Conforti TMS software for 21.5# injectors and 3.5” HFM
White Powder Coat S50 Valve Cover
Drive Belt Tensioner, Adjusting Pulley and deflection pulley all replaced -140k
Intake Manifold Gaskets Replaced
Turner Power Pulley Set
(2) New Knock Sensors – 147k
New CPS sensor – 147k
VDO OEM Fuel Pump – 147k
Rebuilt Alternator
New Plugs NGK Copper
Bimmerworld 3” Race Exhaust with Y-pipe – 149k
Body/Interior
SSI Underpanel
Racetech RT4009 Seats (2) with extra cushions – Expired still good for DE/track days
Wedge Engineering Seat Brackets w/ Recaro Sliders
MA Shaw PTG EVO Carbon Rear Wing from Dan Wennerbergs IP car (OEM Trunk without spoiler included)
Sparco 353 Steering Wheel
Sparco Quick Release Bolt On
Sparco 6pt Harness –Expired still good for DE/track days
Momo Hub Adapter
Fenders Rolled to accept 17x9 wheels with 255/40/17 Tires
TC Kline 4PT Bolt in Roll Cage
S2R Tuning Carbon Fiber Sunroof Delete Panel
Fog Light Delete / Covers
Cooling
New expansion tank and level sensor
Stewart EMP Water Pump – 146k
New Upper and Lower Radiator Hoses and expansion tank hose – 146k
New Thermostat 88 and aluminum housing – 146k
New Blue and Black Sensors
Mishimoto Aluminum Radiator
Brakes
Zimmerman rear blanks -138k
UUC 6 piece Stainless Steel Brake Line Set
Front Calipers Rebuilt – 138k
PFC01 Front Pads
PFC01 Rear Pads
Currently on Willwood EXP Brake Fluid
Turner Style Backing plates for brake ducting
3” High Temp Brake Hose and associated flanges for quick front bumper removal
Wheels and Tires
1 set Dforce LTW5 in Anthracite 17x9 with Hankook RS3 255/40 – 2 track days
Spares Not installed on car - INCLUDED AT $11k ASKING PRICE.
BNIB Clutchmasters Lightweight Flywheel and Clutch Kit FX350
1 set Dforce LTW5 in Silver 17x9 with BFG R1 Slicks 255/40 – 2 track days
BNIB Ground Control Front Sway Bar Race
600lb Eibach Springs 6" 2.5" used
Eibach 2.5" 650lb Springs 6" used
BNIB - Hyperco 60mm 500lb Springs 6"
TMS Shorty Headers
BNIB 3” Race Cat
95 M3 ABS Pump
Box of spares stock M3 parts - Included
Dropbox link doesnt work. Try youtube.
GLWS!
Would you be interested in selling the S54 oil filter housing + cooler + lines separately?
Very interested in a lot of those parts but I have other things I should be spending money on right now
1993 E36 325is
2003 E46 325iT
SpeedHunters feature: http://www.speedhunters.com/2018/04/...t-dtm-tribute/
APEX feature: https://www.apexraceparts.com/blog/m...-arc-8-wheels/
If the buyer for this car is not interested in the Turner shorty headers, I will be interested in buying them. I would greatly appreciate it if you could keep me in mind!
Price drop to $11k and remaining spares. Flickr link updated. https://flic.kr/s/aHskS5ChT8
New Battery, started it up, drove around for a little bit. No overheating, but like I said it happens when you get on it for a period of time.
Let me know if you have anymore questions.
Whoever bought this. If you ever change your mind I'll more than happily pay to take this off your hands
Sent from my SM-G935V using Tapatalk
wow such a nice one
