Replaced mine on my 01 540i/6 because occasionally, I would hear a cold start rattle. It only has 119k on the clock and I thought this would be a good start before I replace the guides and vanos rebuild in the future.
Easy enough job.
Nice, but I would be wary that the extra tensioning powa would put more strain on the already aged guides. Hopefully you do not find that this speeds up the guide failure process.
Nice! Looks like you had the older version with the shorter spring so well worth it to upgrade.
I did mine on my i6 but only replaced the spring. Is there any additional benefit to replacing the piston as well?
The extra spring length is to lessen the chain slack upon cold startup. Cold startups do the most damage to the guides so the updated tensioner design should theoretically help to preserve the guides. However, my experience shows that it's mostly a crapshoot. My 2003 540i/6 had the guides go out at 194k with the original chain tensioner, and I'm working on a 2001 740i where the guides went out at 160k miles with the updated tensioner design.
1995 525i 5-speed - Thread
I replaced mine and it was the exact same as the one I took out.
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
I cleaned and polished up my 160,000 mile tensioner and reused it when I did the guides. Totally silent all the time, even on cold fire up
I got the Febi too. I keep forgetting that back in 2008/7 when the engine was replaced the car got a ton of new parts.
FWIW the Febi I took out was really snug and tight after almost 10 years and 80k miles after it was replaced. The compression and lenght of the spring was exactly the same as the new one. I measured them with a spring gage averaging readings in extension/compression and they were 1 gram appart.
Diehard E39 driver.
There's no o-ring in the chain tensioner assembly— there is an o-ring in the place that supplies oil to the chain tensioner but that can only be accessed with the upper timing cover removed. As long as you replaced the crush washer on the chain tensioner you have nothing to worry about.
I don't recall the tensioner having a crush washer. I think it's a tapered seal plug.
I mean, not tapered threads, but the shoulder of the plug has a tapered seat that seals against the timing cover.
Diehard E39 driver.
The plug that screws in with the chain tensioner always has a crush washer...
http://www.realoem.com/bmw/enUS/show...diagId=11_2264
It's #20 in that diagram.
<== Steptronic Sealbeach740
2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
E39s can read your mind and are more intelligent than 95% of the drivers on the road.
Stop worrying and they won't break.
Mine was stuck to the head and pried it off. Cleaned the surface and put new tensioner and washer.
