Results 1 to 3 of 3
Thread: Code "p1542" eml help! 2000 e46 328ci
    Feb 2017
    Galloway
    BMW e46 328ci
    Hello, I got a code p1542 for throttle pedal sensor but being since in 2000 they didn't make the throttle pedal sensor on the gas pedal so I had to replace the throttle body/TPS with a new one and I did that about a year ago, code didn't come up for about a few months.. then code P1542 popped back up.. I said the heck with it and let it sit for awhile, recently started working on the car again and was searching on forums and the people that said they did this have success with it. They said that after replacing the throttle body/TPS they needed to go on INPA ediabas and reset the throttle adaptions on the DME.. anyone have luck with this? I just ordered the inpa ediabas set up so I'm hoping it works.. thank you in advanced for the help, just trying to get out of limp mode (EML) to set up the car for a turbo this spring/summer other than that she runs beautiful when the EML light isn't on
    Feb 2017
    Galloway
    BMW e46 328ci
    Bump
    Dec 2013
    Chicagoland area
    EXOTICS
    Make sure the connection is clean, and seated properly. After replacement it's recommended to reset adaptations.
    Check for dirty, sticking IAC valve.
    Read through this thread:http://www.e46fanatics.com/forum/sho...d.php?t=848931
    Take a look at this document, pages 51-54 -http://www.beisansystems.com/misc/SE...ROL_SYSTEM.pdf
  1. E46 Bmw 2000 E46 328CI Complete interior part out
    By Cablekid in forum Interior Lighting & Body Parts
    Last Post: 06-19-2012, 09:54 AM
  2. E46 Feeler - 2000 E46 328CI Blk/Blk 5-Speed Coupe in PA
    By 328ci906 in forum 3 series & Z Series
    Last Post: 03-03-2012, 09:52 AM
  3. E46 WTB: Driver seat gray for 2000 E46 328ci
    By cutupanului in forum BMW Parts Wanted
    Last Post: 11-11-2011, 02:42 AM
  4. E36 15" wheels on 2000 E46 328ci
    By evilcat in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-09-2009, 09:55 AM
  5. Feeler.. FS 2000 e46 328CI Topaz Coupe Sports Package
    By Jammin43 in forum 3 series & Z Series
    Last Post: 02-05-2009, 02:31 PM
