Results 1 to 19 of 19
Thread: My cars vin shows i have
    Aug 2016
    st.louis mo.
    2000 528i
    cruise control,however it does not show a light on dash nor engage.Since i'm having ABS issues could this prevent it from working.?(99 Roadster,2.8 5-speed)
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    There is no light on the dash when using cruise control. My cruise control worked intermittently in the past when my brake switch was on its way out.
    Dec 2013
    Chicagoland area
    EXOTICS
    Perform a diagnostic scan with BMW scan tool/software.
    San Diego, CA
    325ci Cabrio
    Yup, Z3s have no lights indicating functionality of the cruise. If your car has it, then you'll have the lever on the right side of the steering column to activate it.
    -Dusty
    05' BMW 325ci, Sapphire Black
    14' Porsche 981, Guards Red
    17' Tesla Model-X, Deep Blue
    81' DeLorean, Stainless Steel
    Aug 2016
    st.louis mo.
    2000 528i
    I have the lever,no cruise.diag. it is then.Thanks fella's!
    San Diego, CA
    325ci Cabrio
    Yup, you've got it alright. Now to source the issue.
    -Dusty
    Jul 2004
    Houston, TX
    36 Cylinders
    Very likely to do with a wheelspeed sensor (rear right?), and/or brake light switch.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2016
    st.louis mo.
    2000 528i
    Thank you.I will look.Just drove today here in the Ozark foothills.Top down,rowing the gears.Gobs of fun.
    Jul 2015
    SoCal
    1999 BMW M Coupe
    My cruise control didn't work either. Dealer wanted $900 to fix it!
    Replaced the break switch ($50) and voila!
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    The brake light switch at the top of the pedal under the dash is most likely. Also could be the cruise control's speed sensor, which is on the differential.
    The differential sensor is for the speedo, cruise control, volume adjustment on the radio, speed-sensitive wipers, etc. The wheel speed sensors are ABS and traction control only.
    BMW MOA 696, BMW CCA 1405
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    On the 4 cyl, yes. The cluster provides the VSS signal based on the diff sensor. But that is not the case for the E46 based engines. The DME does the cruise functions, and gets a VSS from the ABS module, which uses a cooked RR wheel sensor.
    /.randy
    Aug 2016
    st.louis mo.
    2000 528i
    Great info,thank you guys!
    oskaloosa,ia
    '01 3.0 ZCoupe
    Another possibility is the clutch pedal switch. My cruise had been off and on for over a year, but I figured out if I pulled the clutch pedal all the way back with my toe, the switch will engage. Works every time. May be the same with the brake pedal for you, or it could be your clutch pedal as well.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by bionicbelly View Post
    Another possibility is the clutch pedal switch. My cruise had been off and on for over a year, but I figured out if I pulled the clutch pedal all the way back with my toe, the switch will engage...
    This answered my problem. I got the car out on the Interstate today for the first time since last summer, and the CC did not work.
    I remembered that the CC was interlocked to the pedal switches, and found that my brake lights were OK. Then I connected that last December, I had a shop install a Mason clutch pedal, and they broke and replaced the clutch switch. After reading this post, I took another drive and pulled the clutch pedal back with my toe. That made the CC work.
    So I am going back to the shop to ask them to adjust the switch.
    Aug 2017
    My ABS+ASC module originally didn't work, but the cruise worked. Had the ABS module out of the car while it was sent away to a rebuild company, and I noticed during that time my cruise stopped working. Put the rebuild ABS module back in the car, and ABS & cruise control came back to life.
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Vintage42 View Post
    ?!? You're going back to the same shop? After what they did before? You are a really brave man and that's no lie.
    Oct 2012
    Louisville, KY
    The same tech who installed the clutch pedal and switch would be most familiar with increasing the last bit of travel for the switch, and the shop should do this adjustment without charge.
    If I take the car to another shop, there will be another set of hands under the dash, and and a charge.
    Kent, Ohio
    1998 M Roadster
    Discretion is the better part of posting.
    Feb 2014
    allentown
    99 Z3MC/00' 2.8 roady
    My cruise control did not work until I replace my brake switch.
  1. My car at Show and Shine
    By Burn535i in forum 1988 - 1996 (E34)
    Last Post: 10-08-2008, 08:26 PM
  2. Replies: 4
    Last Post: 08-14-2007, 11:17 PM
  3. my car sounds like bsaints! have a question though
    By takem2church in forum BMW Rides & Events
    Last Post: 03-08-2007, 11:06 PM
  4. Why does my car still seem to have torque pull to the left?
    By UA///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2005, 01:00 PM
  5. Replies: 9
    Last Post: 05-10-2004, 01:14 PM
