I had a shop tell me one of the cats is bad. There is a rattle I hear from under the car so I'm guessing that's the catalytic converter.
So assuming the issue is the cat has anyone had any luck with aftermarket cats? Or used/remanufactured? The brand new OEM ones are >$1k a piece so I'm balking a little at paying that but will if it's the best option. I've been doing some searching and it seems a mixed bag for whether or not aftermarket ones work well or last.
Anybody with a 540i have any personal experience?
Yeah, it's not worth it to go OEM on cats, even with cheaper cars like Mazdas or the like.
My 540 has what appears to be Magnaflow cats, they are probably higher-flowing than OEM and fast-pass Colorado emissions. You basically need a good muffler shop.
I had mine gutted. Haven't had any issues. OEM Cats are very expensive.
^That option is great*
*providing you don't need them for emissions.
OE cats are expensive for a reason, they have MANY times more precious metals that do the catalyzing so work better and last longer.
My advice is to find and use good OE cats.
Your dead cats are worth more in scrap than NEW aftermarket ones cost. Nice racket for the muffler shops.
As a Californian, the cost on catalytic converters is cataclysmic. I just replaced one on my wife's Jetta for $261 and it was a generic Walker; the rest of the country pays $85 or so. OEM was like $700. On a car that isn't worth more than $2K, going OEM doesn't make sense.
My 540i has aftermarket cats and somehow passed California emissions. I would go cheap if it was me. Expensive enough to do what you need to do but no more.
PM me. I have solution for you.
________________________________
Nik
91' M5 3.9L Stroker
92' M5 3.8L
95' 540i6 Supercharged
95' 540i6 4.7 Stroker
95' 550i6 M70 Conversion
Sent you a PM.
Thanks for the replies. I'm leaning towards going with aftermarket cats. In my state we only need emissions tests when the car is first titled so it's not like I'm particularly worried but if I sell the car at some point I'd like the next owner to not have any issues with inspection/registering the car. But seems people have been able to pass emissions tests with the Magnaflow cats at least.
As far as I know only one of mine is bad but should I replace both just so both sides have the same cat?
I had a pair of 13" magnaflow universals on my car when it was b40/6spd and they did NOT pass CT emissions, no matter what i tried. They were a couple years old at that point, but the car DID pass emissions with the factory b30 cats still fitted to the b40 about 2yrs prior (that were 200k miles old at that point). I do not know how maryland emissions compare.
-Alex
Got LSD, Megasquirt coming... and a few manual 'gearboxen'. The M50 should be done this week.
https://www.summitracing.com/int/par...bmw/model/525i
Weld this on to mounts, and run SS pipe right out the back....
My plan.
https://www.summitracing.com/int/sea...illocation=int
Is there a high flow cat for 525i?
Yes. There are examples mentioned in this very thread.... (?)
Also, e34s don't need cats in NY period, fyi. (Not saying you shouldn't use them, as a NY'er I've always kept them on my OBD1 cars anyway para la tierra. . .)
Do E34 have aftercat O2 sensors? Just saying because I did put Magnaflows on E39 540 I had before and check engine would come up for cat efficiency.
No they do not. The change from e34 to e39 and OBD 1 to OBD 2 was simultaneous for 1996. OBD 1 can't tell you if your cat works or not.
Any good exhaust shop in the nyc area you would recommend
