Any belt manufacturers to stay away from, or any you can recommend--I need to purchase a drive belt for my E39 540i...
Thanks in advance.
Get the OE Genuine. It's a couple of bucks more expensive than OEM (Contitech) but's still made in Germany instead of Romania or India, lasts longer and doesn't squeal when hot like the cheaper versions.
FCP Euro has it very reasonably priced and they offer lifetime guarantee.
Diehard E39 driver.
I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
"Your momma's so ugly she makes Bangle cars look nice"
Thanks!
(your caption describes my car... (98 540i-350k and counting... :-)
You can get Contitech from RockAuto, too. Just put in the OE PN and it should show up.
And man those belts are MUCH better than the parts store versions. They look different, too. Put a set of Contitechs on my 740i last month. I had a light ticking sound like a bad lifter and it turned out to be the belt.
1987 L6
1997 840ci
2000 740i Sport
2000 M Roadster
2001 M5
2002 540i Sport
2002 X5 4.6is
2003 530i Sport
2003 M3
2003 Z3 3.0
2005 X5 3.0 Sport
Diehard E39 driver.
I put Dayco Poly Cog belts on my 540 about 90K miles ago, they still look very good. Not replacing them anytime soon.
Replace BOTH belts!
Rock Auto rocks! Got a Contitech as a spare just in case. (That's one of those parts that will leave you on the side of the road) My belts are fine but I'd rather be safe than sorry and I like the convenience of having something and not needing it rather than needing it and not having it. Especially for a bargain ;-)
Sent from my SAMSUNG-SM-G935A using Tapatalk
Juan, my A/C belt is Dayco Poly Rib 5050395.
I have underdrive pulleys on the water pump and power steering pump so that belt is longer than a standard belt.
You should be able to get the correct Dayco p/n for the standard belt from the Dayco website.
Another good belt is Goodyear Gatorback.
Diehard E39 driver.
I'd say they both are better than the OE belts. My OE belts had lots of cracks on the inside surface, think they had 70K on them. These belts now have 82K on them and still look almost new, no cracks.
