iv got two codes 005DF0 pump motor faulty,and 005DF1 pump motor connector damaged.Could a connector issue be throwing the other code,or vice versa?These codes were pulled with carly.
You really need a test plan to determine the root cause of the problems. Carly is fine for pulling basic codes, but it struggles with detailed diagnostics. ISTA-D is excellent for this, as it contains test plans to get to the source of the fault codes. I'm happy to PM you a download link if you want. It can work with just a $20 K+DCAN cable
That would be great,probably the pump as it seems i have read about problems with them.Thanks
