Ok, sorry dumb question but everything I read gives you different numbers. I'm running my car for the first time in months. It's getting hot, and although it's getting quieter it sounds like there's some noise from the bottom end. However:
I just got an oil pressure gauge and I'm able to read my oil pressure for the first time. When I'm running (hot) it sits at about 22 PSI. Is this normal? It seems really low. I put 7 quarts of oil in, if it's low I don't know why. If it's someone can please answer with the correct oil pressure at idle I'd appreciate that.
1997 BMW 328i Avus Blue - S52B32 Motor - VAC 140 MLS HG - ARP Head Studs - Supertech Inconel/SS Valves w/ 80# Springs - Standalone Megasquirt 3 - CX Racing Turbo Kit - E85 - Wally 485 Fuel Pump - 80# Injectors - 6 Puck Sprung Clutch - Lightweight Flywheel - Stewart Pump - Mishimoto Z3M Radiator & Expansion Tank & Electric Fan - H&R Cup Kit
Support my hobby by supporting my business! (myeasytek.com) - Follow me on Insta: @realjtbabin
15PSI @3700 RPM - 488 WHP, 481 WTQ @ 4600 RPM
It depends on which engine but 22 psi at idle is totally fine. Some engines will be even lower at idle when hot.
S52, thank you
Sent from my SM-G930V using Tapatalk
The low spec from the factory is like 10 psi, most of them seem to be around 20 at idle
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
